What are the best detailing products?... Maybe I can help.
Discussion in 'Detailing' started by 1BadTundra, Dec 15, 2016.
  1. Apr 16, 2020 at 9:42 AM
    #121
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Is Carpro Essence considered an all in one product?
  2. Apr 16, 2020 at 9:54 AM
    #122
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Polish and sealant, yup. It would be best to add something over it, like reload for more longevity. It's also a primer, meaning you can apply cquartz ceramic right over it after you polish without an extra wipe down step
  3. May 5, 2020 at 7:19 AM
    #123
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Whats the best window/glass cleaner that everyone is using. My big jug of Pinnacle glass cleaner is finally empty and I need to replenish.
  4. May 7, 2020 at 9:13 PM
    #124
    Pudge
    CT
    I like stoners invisible glass
    degs and What the!? like this.
  5. May 8, 2020 at 12:21 PM
    #125
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    My friend owns a glass factory. They use sprayway glass cleaner. I get it from them. Bottom line though, use too much of anything and it'll streak and be a pain to clean up. You need to use just enough, and no more. Yup, glass is a pain.
    War Machine likes this.
  6. May 8, 2020 at 4:37 PM
    #126
    briarpatch
    briarpatch New Member
    For anyone looking for a good sealant (only, not an AIO).....consider a new product from Wolfgang......SIO2 Paint Sealant. I decided to try it, mostly because of the good reviews I was reading. Stuff is stupid easy to use, and leaves the surface very slick and very glossy. It is pricey (39.99/16 oz bottle), but I can tell you that I used less than two ounces on the CrewMax, and it came out awesome. I fully expect to get 6 months (or more) out of this application.
    CaptainGrumpus, Pudge and War Machine like this.
  7. May 8, 2020 at 8:51 PM
    #127
    owb2gp
    owb2gp New Member
    ID
    Put it on my wishlist.
    Autopia has it for $29.99
    https://www.autopia-carcare.com/wol...3FIWdrrx3s35IYc4tIAaAmBZEALw_wcB#.XrYojdBME0M
  8. May 9, 2020 at 2:22 PM
    #128
    briarpatch
  9. May 9, 2020 at 4:38 PM
    #129
    owb2gp
    owb2gp New Member
    ID
    Was last night when I posted it.
  10. May 9, 2020 at 5:26 PM
    #130
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Sounds great. When I finish burning through my Hydro2, I’ll have to give this a whirl.
  11. May 9, 2020 at 6:47 PM
    #131
    briarpatch
    Oh well.....still worth every penny of 39.99
  12. May 18, 2020 at 3:56 PM
    #132
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    Still on sale for $29.99 when I used your Link
  13. May 18, 2020 at 4:26 PM
    #133
    owb2gp
    owb2gp New Member
    ID
    @briarpatch
  14. May 19, 2020 at 5:28 AM
    #134
    briarpatch
    Autopia has a 25% off sale on Wolfgang products right now.....just checked
  15. May 23, 2020 at 6:35 AM
    #135
    CaptainGrumpus
    Maine
    With all the Memorial Day sales going on right now, can I get some help with my current regiment.
    Wash with Mr Pink
    Wolfgang Claybar
    Griots Fast Correcting Cream
    and then what...
    I bought some Meguairs M205 but I’m not 100% satisfied with the results. What would be my next step? I was thinking a wax and then sealant but am I wrong?
    will be applying with a HF D/A with some LC Orange and Black Pads.
    TIA!
  16. May 23, 2020 at 10:43 AM
    #136
    briarpatch
    In what way are you not satisfied with M205? Are you using the same pad(s) with the FCC as you are with M205?
    Your sequence would be sealant first, then wax. Some folks insist on a wipe down/panel prep after polish, to take away any of the polishing oils....others say it isn't necessary. I do it because it doesn't take that long....and I'm certain of the sealant bonding correctly. I've never compared results with one process versus the other.....so I might just be wasting time. I look at it this way...any time spent detailing my truck is not wasted.
  17. May 23, 2020 at 10:56 AM
    #137
    CaptainGrumpus
    Maine
    I just felt like the M205 didn’t give me that buttery feel that I really like to get when I wax.
    I didn’t even think about applying a sealant first. Which would you recommend?? Thanks!
  18. May 23, 2020 at 11:00 AM
    #138
    Pudge
    CT
    M205 is a polish, not a wax so thats why it doesn't feel like wax.
    Trooper2 likes this.
  19. May 23, 2020 at 11:16 AM
    #139
    CaptainGrumpus
    Maine
    So after the m205. Should I do a wax? Where does the sealant come into play? Should I ditch the m205? Thanks for all the help btw.
  20. May 23, 2020 at 11:32 AM
    #140
    Pudge
    CT
    M205
    Wipe
    Seal
    Wax if you want
  21. May 23, 2020 at 12:18 PM
    #141
    CaptainGrumpus
    Maine
    Off to buy a sealant And wax. Thanks once again.
    Pudge[QUOTED] likes this.
  22. May 23, 2020 at 1:16 PM
    #142
    briarpatch
    Pudge beat me to answering the question about M205......if those were your expectations, then I'm not surprised that you were disappointed.
  23. May 23, 2020 at 2:55 PM
    #143
    CaptainGrumpus
    Maine
    It’s definitely a learning experience for sure!
  24. May 23, 2020 at 3:30 PM
    #144
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    What is the best product for restoring the black in weathered plastic exterior trim.
  25. May 23, 2020 at 3:41 PM
    #145
    briarpatch
    If it's really bad....Solution Finish.....it's effectively a dye and lasts about a year. Once it's dry, coat it with Car Pro Dlux and you may get longer out of it. If it's not too far gone, Wolfgang Exterior Trims Sealant.
    Rex Kramer[QUOTED] likes this.
  26. Apr 2, 2021 at 10:05 AM
    #146
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    DONT BUY FROM AUTOGEEK
  27. Apr 2, 2021 at 11:27 AM
    #147
    briarpatch
    Dude....you've been busy
    ToyoMafia[QUOTED] likes this.
  28. Apr 2, 2021 at 11:34 AM
    #148
    Tundy19
    Tundy19 New Member
    Devin
    Kailua-Kona
    2019 Black Platinum
    Please elaborate? I placed an order on the 17th and it finally shipped the 30th :rolleyes: so I can see why that would be a problem... it was a rather large order and the customer service was subpar at best... but why else?
  29. Apr 2, 2021 at 11:36 AM
    #149
    ToyoMafia
    Magic carpet.
    I like to keep busy.
  30. Apr 2, 2021 at 11:38 AM
    #150
    ToyoMafia
    Magic carpet.
    Ok so I just got an email from autogeek and guess what! They won’t make it right! Screw them they sent me an email saying they showed CarPro the video I sent and CarPro said it wasn’t a manufacturer defect. Well that’s funny because I spoke to CarPro and they said if autogeek did not make it right they would. Again I will never buy from autogeek ever again and I will purchase all CarPro from sky’s the limit
    jpod and Tundy19[QUOTED] like this.
