What annoys you about your truck?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bentarm13, Mar 19, 2022.
  1. Feb 17, 2023 at 10:54 AM
    #511
    PermaFrostTRD
    Northern NY
    I dont know. I'm in the last of the key bangers.
  2. Feb 17, 2023 at 10:56 AM
    #512
    PermaFrostTRD
    Northern NY
    People complained of hearing the motor run (assuming) but definitely a noise after the window had either rolled up to stop, or rolled down. I've never heard the noise or anything. I would have never thought to listen for it, until I read folks complain. I think they've got it dialed pretty good.
  3. Feb 17, 2023 at 11:40 AM
    #513
    a_double
    a_double New Member
    Door auto unlock when shifting to Park. It's convenient a lot of times but could be a huge security issue when in the wrong part of town.
  4. Feb 17, 2023 at 11:54 AM
    #514
    seydou
    seydou Distinguished Member
    I can choose a different option in my settings. I have it set to unlock driver's door only.
  5. Feb 17, 2023 at 12:21 PM
    #515
    be_unscared
    be_unscared Not a truck doctor
    Brendan
    Central Cal
    21 Army Green w/skewp 4x4
    For sure. This is completely customizable in your settings, though…unlike the remote starting cutting off when the door is unlocked
  6. Feb 17, 2023 at 12:43 PM
    #516
    a_double
    a_double New Member
    Thanks, I'll dig into my settings make the change.
  7. Feb 17, 2023 at 2:06 PM
    #517
    a_double
    a_double New Member
    I just went through my USA market, 21, TRD Pro, and couldn't find the setting. Please let me know where this is.
  8. Feb 17, 2023 at 2:49 PM
    #518
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Lack of upgrade path to CarPlay on 2018s
    fuzzamungus likes this.
  9. Feb 17, 2023 at 3:04 PM
    #519
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Yes, this only works for 2010 thru 2017 but truck will not shut off according to 12 volt
    • To Start: Press lock 3 times on the OEM key FOB
    • To Stop: Press lock 3 times on the OEM Key FOB
    • Parking Lights will illuminate during remote start mode
    • Run time is 15 minutes
    • All doors, hood and hatch/trunk must be closed
    • The vehicle will NOT shut off when the door is opened. You can get in and go without having to restart your vehicle.
  10. Feb 17, 2023 at 3:08 PM
    #520
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I have a 19, but it should be the same.
    hit vehicle
    vehicle customization
    door locks
  11. Feb 17, 2023 at 3:32 PM
    #521
    Fitzf15E
    Fitzf15E New Member
    2021 Limited DC TRD OR Cement
    OK, so the Tundra only gets driven every 2-3 weeks during the winter because we have a couple other vehicles that are much more capable on snowy/icy roads (and the stock TRD OR tires suck), but that’s not the point.
    The minimal driving apparently caught up with me on Wednesday since when I went out to start the truck it wouldn’t even unlock the doors. Tried the start button anyway and just got a couple clicks from the starting solenoid before it gave up. Awesome (not!). Since I was headed out of town for a couple days I decided to just grab the battery tender from another vehicle, thinking it would get a gentle charge while I was gone. I come back two days later, battery still dead. WTFO? At this point I grab my regular battery charger and hook it up. As soon as I do the lights start flashing and the starting solenoid is clicking. Seriously? Something I did not know about the smart key/push button start: as per the owner’s manual it “memorizes” the last command from the start button, so even if the battery is completely dead, or even if it’s removed, charged and put back into the vehicle, if the last command was “start” the starter will engage as soon as the battery is connected again (or in my case a battery charger is hooked up). What kind of dumbshit engineer thought this was a good idea?
  12. Feb 17, 2023 at 5:22 PM
    #522
    be_unscared
    Brendan
    Central Cal
    Need that same fix for the 18-21 :monocle:
  13. Feb 18, 2023 at 5:52 PM
    #523
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    2019 tundra sr5 with physical key you just have to remember not to start it when you get in.:canada: 2020 was the year with keyless and that’s why you have engine shut down with remote start afaik.
  14. Feb 18, 2023 at 5:54 PM
    #524
    a_double
    a_double New Member
    Key FOB lock/unlock function not working after engine start.
  15. Feb 19, 2023 at 4:17 AM
    #525
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I like the fact that the locks don't work with the keys in the ignition. When I am at the hunting ranch I just leave the keys in the ignition. I know where they are and noone can accidently lock the doors.
  16. Feb 19, 2023 at 5:31 AM
    #526
    hainesfive
    hainesfive New Member
    MD
    2020 Black TRD Sport Crewmax
    TRD Dual Exhaust Weathertech rear floor liner Black out badging Linex sprayed bed TRD PRO Wheels VLED Interior and exterior Drivers side grab handle Front drivers and passenger window tint Focal speaker upgrade with amp and 10" sub Retrax pro bed cover Falken tires
    That it makes me smile every time I get in it
    1UP, Tundrastruck91 and Mike59 like this.
  17. Feb 19, 2023 at 11:03 AM
    #527
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    The seat belt rattle against the door pillar when fully retracted, dashboard rattle, door squeaks, transmission never happy with its gear, blower fan squeaks. Only one door with a key slot. No rear door pockets.
    But the motor is fun over 3.5k rpms.
  18. Feb 19, 2023 at 1:23 PM
    #528
    Tundrastruck91
    lol can't comment further without a ban
    Same ! Looked at 3rd gen and just couldn't do it.
  19. Feb 19, 2023 at 8:18 PM
    #529
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Ok, so I didn't think it would bother me as much as it bothers anyone else here but man was I wrong. I cant stand the automatic shut off when opening the door after remote starting the damn thing. Its really annoying.
  20. Feb 21, 2023 at 6:16 PM
    #530
    be_unscared
    Brendan
    Central Cal
    This is something that someone needs to go Erin Brokovich on. Just scorched earth until some nerd somewhere at corporate flips a switch that allows it to be disabled. It’s easily the most mentioned annoyance and so easily fixable if they just allowed a bypass.
  21. Feb 22, 2023 at 2:26 PM
    #531
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    Probably been said before, but the location of the rear mirror adjustment switch is hard to see and it is not lighted, Impossible to reach, without moving to the backseat, rear sliding window on the DCs.
    Mike59 likes this.
  22. Feb 23, 2023 at 6:57 AM
    #532
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Doesn't bother me since I am only driver. I set and don't have worry about it unless I wash my mirrors. What bothers me is even Prius's have a back-lit switch.
