What a difference!!! Seat jackers
Discussion in 'General Tundra Discussion' started by 2mchfun, Nov 23, 2021.
  1. Nov 25, 2021 at 5:08 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    So this would work with power seats as well? Compared to my ford the tundra seats suck and compared to my tundra my highlander platinum seats are even worse
    2mchfun[OP] likes this.
  2. Nov 25, 2021 at 5:19 AM
    2mchfun
    2mchfun [OP] Cool story, but did your new TTV6 tow a shuttle?
    I beleive they will, call Steve at Desert Does It to confirm. After you get confirmation please post it here for others. My drivers seat is powered and it's fine with them.
    SWIPE and Smokingloon like this.
  3. Nov 25, 2021 at 5:53 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    That’s exactly what they do. The seats will go waaay too low in the front from the factory so these essentially put “comfortable” in the middle of the range.
  4. Nov 25, 2021 at 7:03 AM
    2mchfun
    So Steve just reached out and confirmed all of his products will work with either manual or power seats.
  5. Nov 25, 2021 at 7:11 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you buy a set for the passenger seat too?
    I'm thinking about trying these out.
    Hightide[QUOTED] and 2mchfun[OP] like this.
  6. Nov 25, 2021 at 9:05 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Just ordered a set for both front seats. Thanks for the discount code!
    DesertDoesIt and 2mchfun[OP] like this.
  7. Nov 25, 2021 at 11:07 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    only drivers side.
    With the molle panel.
    1lowlife[QUOTED] likes this.
  8. Nov 25, 2021 at 11:17 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Is the jacker primarily a tilt only or does it actually raise the seat height? I would love more angle, but don't want to sit too much higher. (long body, short legs here)
    Jackstraw likes this.
  9. Nov 25, 2021 at 11:20 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I wonder if they are enough with back added to fit a compressor under there with a Gen1
  10. Nov 25, 2021 at 11:22 AM
    alb1k
    Left Coast
    It's good
    If you only do the front, your butt is basically in the same spot I would think.
  11. Nov 25, 2021 at 11:25 AM
    2mchfun
    They raise the front and that provides the much needed tilt. A bit short here too with a 32" inseem and I have zero complaints.
  12. Nov 25, 2021 at 1:44 PM
    Casper421
    In the woods
    06 DC
    Possibly under the passenger seat.
  13. Nov 25, 2021 at 1:58 PM
    alb1k
    Left Coast
    It's good
    I think that is the only possibility as I think about the room/lack of under the driver. I'll have to check it out.
  14. Nov 25, 2021 at 2:01 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Here's my dumb question.....
    Does 1 set come with 4 spacers to life the entire front driver or passenger seat (front bolts and rear bolts), like in the installation video?
    The descriptions says it lists the FRONT. If so, you need 2 sets to lift each seat?
  15. Nov 25, 2021 at 2:33 PM
    2mchfun
    I used 1 set on the front of each. Raised the front of both about an inch to give a recliner type of comfort. Sooo much better!
  16. Nov 25, 2021 at 2:57 PM
    alb1k
    Left Coast
    It's good
    The front and the rear are different spacers. Most every one is getting front only. 2 per seat.
    So if you ordered one set (or pair) of front spacers, like most are talking about, you would tilt one seat.
  17. Nov 25, 2021 at 3:05 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Thanks.
    I thought the video showed the guy installing under the back of the front seat too, but he just loosened those bolts during installation and then tightened after the front seat jackers were installed.
    Now I got it. :thumbsup:
  18. Nov 25, 2021 at 3:05 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    This is what the website says. So one set per seat and only install in the front brackets. It sounds like your use case may be to LIFT the entire seat up?
    Sick and tired of that sliding forward feeling when you're driving your Tundra or Sequoia? Or are you are struggling to find that comfortable seating position? You might be suffering from a lack of leg support.
    The Tundra front Seat Jackers will lift and tilt the front of your driver or passenger seat to provide that much-needed leg support. In many cases this has alleviated lower back stress felt during longer drives.
    These will put that perfect recline in your seat cushion and will help you find that seating position that just isn't available in a stock Toyota.​
  19. Nov 27, 2021 at 7:13 AM
    #49
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Just placed my order for both seats.
    2mchfun[OP] and BravoDeltaRomeo like this.
  20. Nov 27, 2021 at 8:11 AM
    #50
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Don't go start thinking now....
  21. Nov 27, 2021 at 8:27 AM
    #51
    RusPro21
    Don
    Pa.
    I did test it out first. Stuck a one inch piece of wood just see to see how it was. Made the move.
  22. Nov 27, 2021 at 5:15 PM
    #52
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Ended up ordering a set. Dang this site, twisting my wrist again!
    Wallygator, 2mchfun[OP] and Do58 like this.
  23. Nov 27, 2021 at 5:20 PM
    #53
    Do58
    Do58 New Member
    Just did the same thing last night lol
  24. Nov 27, 2021 at 7:20 PM
    #54
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Do you have a set for the rear seats of a Double Cab Tundra?
  25. Nov 27, 2021 at 7:20 PM
    #55
    alb1k
    Left Coast
    It's good
    I didn't see those on the site
    619Tundra[QUOTED] likes this.
  26. Nov 27, 2021 at 7:22 PM
    #56
    619Tundra
    I need some for the rear seats due to my subwoofer box install. I need 1 inch.
  27. Nov 27, 2021 at 7:25 PM
    #57
    alb1k
    Left Coast
    It's good
    Longer grade 8 bolts and washers may get you there. I don't know that setup.
  28. Nov 27, 2021 at 7:26 PM
    #58
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    So to clarify, what exactly do these seat jackers do?
  29. Nov 27, 2021 at 7:29 PM
    #59
    619Tundra
    These also have a guide pin or dowel along with the bolt. I'm machining some out of 1"x 1" T6 Aluminum. If these guys have them, I rather buy them to save me time.
  30. Nov 27, 2021 at 7:57 PM
    #60
    2mchfun
    They raise up the front of the seat to give a more comfortable semi reclined position.
    IsaiahCanada[QUOTED] and alb1k like this.
