What’s your MPG and tire size??
Discussion in 'Wheels & Tires' started by TundraLLama, May 29, 2021.
  1. Jun 2, 2021 at 8:25 PM
    #61
    Redcon41318
    Redcon41318 New Member
    Stock 255/70/18, highway 17-18mpgs, streets anywhere from 10-13mpgs.
    TundraTeddy likes this.
  2. Jun 2, 2021 at 10:59 PM
    #62
    jwatt
    jwatt I heart men
    Jack
    Oregon
    ^^This^^
  3. Jun 7, 2021 at 6:57 AM
    #63
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Alright, check my logic here... It would make the computer calculate to the low MPG side of reality, right? Since I've clocked mine at about a 7% decrease in MPH from reality. I could be completely inverted on my logic as well!
  4. Jun 7, 2021 at 9:52 AM
    #64
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Your decrease in MPGs as a % should = the increase in diameter as a %. So if your MPGs are now 15 and you increased diameter by 5% your actual MPGs would be 5% higher or 15.75
    frichco228 likes this.
  5. Jun 7, 2021 at 9:56 AM
    #65
    Elduder
    Elduder New Member
    Currently lifted 2" with 315s that weigh 98lbs, average to work, which is a 20 mile trip is 13.4. Calculated for the tire size change comes out to 14.2. Stock I was getting 15, so just about 1 mpg loss. Made a trip down to central Oregon last week on the 35s and managed 16.8 which calculated out to 17.8mpg. Driving style has a lot to do with outcome. I use cruise often and typically set it 60 or 65 to match the speed limit. If I drive 70 or more there is a considerable change in fuel economy.
  6. Jun 7, 2021 at 7:30 PM
    #66
    AtomicToyo
    AtomicToyo New Member
    Ontario, Canada
    35x12.5, 3 inch lift. Average 16L/100kms which is around 14.5mpg.
    just a reminder if you put on bigger tires and are using the on board calculator without using a speedometer corrector then your mpgs are going to be way off (on the low side)… I was showing 12mpg before the fix.
  7. Jun 7, 2021 at 10:24 PM
    #67
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    285/65r20 Michelin Agiles
    18.8 avg mpg 70/30 City/Highway with some light weekend towing in there too.
    Sorry I know it's irrelevant :p
    TundraLLama[OP] likes this.
  8. Jun 7, 2021 at 11:07 PM
    #68
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
    Been towing a lot the last few days and my mpg shows 9.8 now
  9. Jun 8, 2021 at 6:44 AM
    #69
    rt_tundra_co
    '15 SR5 CM TRD
    How did you correct your speedo? Was it a hardware or software fix?
  10. Jun 8, 2021 at 10:36 AM
    #70
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    It is a software fix these days
  11. Jun 8, 2021 at 2:02 PM
    #71
    AtomicToyo
    Ontario, Canada
    I used a rough country speedometer calibrator. Program it to your new tires and it plugs inline to the instrument cluster.
    that’s a software fix. You can unplug it and go back to oem. Lots of guys use it
  12. Jun 8, 2021 at 5:21 PM
    #72
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    yeah i don't get it. not sure what I am doing wrong
  13. Jun 8, 2021 at 5:44 PM
    #73
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    37's, 6" lift, stock gears. 11.3-12.5mpg. 13mph with a tail wind....
  14. Jun 10, 2021 at 8:50 PM
    #74
    rt_tundra_co
    '15 SR5 CM TRD
    Where did you get it done? Cost? Thanks!
  15. Jun 10, 2021 at 10:01 PM
    #75
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    37X13.50X20 Patagonias with 5:29's gets me 12MPG around town, hand calculated.
    I don't remember what I got last time I ran a tank on the interstate but I "think" it was 17+, I'll check it next week
  16. Jun 11, 2021 at 1:27 AM
    #76
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I’m interested too. I recently picked up a 2013 Crewmax lifted 12” on 38’s. Getting around 11 according to the dash. But my speed is off 5 - 10 mph depending on how fast I’m driving.
  17. Jan 24, 2024 at 6:22 PM
    #77
    Solar Jerm
    Solar Jerm New Member
    2018 Grey Tundra TRD Sport
    2" leveling Kit
    275/60/20 BFG KO2. 55psi. I average 11-12city,
    14-15, hwy. I do like the prr tho.
    Race all them "pretty" Chevys. Ones that don't do nothing with there trucks.
    When my wife drives. 13city, 16-18 hwy. Mostly 16tho.
  18. Jan 24, 2024 at 6:27 PM
    #78
    Solar Jerm
    2" leveling Kit
    Sounds like the Ford was a V6.
  19. Jan 24, 2024 at 6:30 PM
    #79
    Solar Jerm
    2" leveling Kit
    How? I have 175/60/20 BFG KO2. 55PSI. and I get 10-12.city, 12-14hwy.
  20. Jan 24, 2024 at 7:35 PM
    #80
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I coast to red lights to avoid completely stopping. Getting the pig moving from a dig is killer. I also keep my throttle position under 30% as much as possible. It's not easy and requires a style of driving change. If I don't pay attention and drive like it's my wife hybrid then my numbers are like you are seeing. Also when u take off to high speed don't lug it, get it to speed quick then take it easy.
