What’s the most hitch weight
Discussion in 'Towing & Hauling' started by DM 2018 Tundra, Feb 25, 2020.
  1. Feb 27, 2020 at 6:42 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    From the standard, section 3.2.1 for Tow-vehicl trailering weight (TVTW)
    3.2.1 Tow-vehicles Under 8500 lb GVWR
    TVTW is the weight of the tow-vehicle used for EPA emissions and fuel economy certification including all options in
    excess of 33% sales penetration plus one 68.0 kg (150 lb) driver and one 68.0 kg (150 lb) front seat passenger, plus the
    tow-vehicle manufacturer’s available trailering package and/or any required trailering content (if not included in the 33%
    option penetration weight) plus representative aftermarket trailering equipment as specified in 5.2. In the case where a
    trailering package is not available from the tow-vehicle manufacturer or it does not include a trailer hitch component, the
    representative aftermarket trailering equipment as specified in 5.2 shall include a trailer hitch component.
    This is simply specifications for setting up the tests defined in the standard. It does NOTHING to increase the actual load capacities that are stamped on your truck.
    ColoradoTJ and Tundyfundy like this.
  2. Feb 27, 2020 at 6:47 AM
    Atomic City Tundra
    Devin
    New Mexico
    From later in the standard, section 5.4:
    5.4 GVWR/Rear GAWR and Tongue Weight/Kingpin Weight Considerations
    The tow-vehicle shall be able to accommodate appropriate trailer tongue and/or kingpin weight to attain a particular TWR
    without exceeding Rear GAWR and/or GVWR. Required minimum conventional trailer tongue weight shall be 10% of
    TWR and required minimum fifth wheel or gooseneck trailer kingpin weight shall be 20% of TWR. For purposes of this
    standard, fifth wheel or gooseneck trailer kingpin weight shall be applied directly over rear axle centerline unless a
    fixed-ball hitch is available from the tow-vehicle original equipment manufacturer (OEM) in which case it shall be at the
    OEM position. Conventional trailer tongue weight shall be applied at a longitudinal connection point as indicated in 5.5.
    This is the part that people seem to skip over. You still have to be under your GAWR and/or GVWR!! No free lunch.
  3. Feb 27, 2020 at 6:49 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    *mic drop*
  4. Feb 27, 2020 at 6:55 AM
    Atomic City Tundra
    Devin
    New Mexico
    I agree with almost all of this. Heavier tires do take away from your payload. Payload is GVWR minus curb weight. The curb weight of your vehicle includes your tires. Now, I can see the point of saying that they are just "unsprung" and that the suspension is not carrying them, so from that sense it seems that it shouldn't affect your payload. However, it is still more weight that you have to be able to stop and control.
    Vizsla and Tundyfundy like this.
  5. Feb 27, 2020 at 8:19 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You are correct. I am using "payload" and "Vehicle Weight Capacity" interchangeably, and that is incorrect.
    Owner Manual defines GVWR this way:
    "The (GVWR) is the total weight of the vehicle. When towing a trailer, it is the sum of the vehicle weight (including occupants, cargo and any optional equipment installed on the vehicle) and the tongue weight.
    "Vehicle Weight Capacity" is what load Toyota says the truck will carry: tires/wheels would not count against the "Vehicle Weight Capacity" number unless they were in the bed of the truck. Apparent confirmation of that is the warning sticker on my 2017 TSS which indicates "load carrying capacity reduced by....51 kg or 112 lbs". The truck has port added spray-on bedliner, and TSS package which includes 275/55R20 tires/wheels and tube steps. The reduction in "load carrying capacity" seems too low to include anything for the larger 20" tires and wheels. If the reduction does include the tires/wheels, maybe the increase over 255/70R18 and standard SR5 wheels is less than I think.
    Bottom line, you can not exceed "Vehicle Weight Capacity", GVWR, GAWR, GCWR, or TWR. If the cargo load causes the GVWR to be exceeded because of tires and wheels you added, then you DO lose "Vehicle Weight Capacity" (your point). Toyota has given very detailed information on towing in the owner manual, and as shown above, multiple conditions will have to be met. At least you won't have to do the calculations but once if you don't significantly change your setup. In spite of detailed tabulation of GCWR, TWR for every model number in the owner manual, GVWR or GAWR is apparently listed only on the doorjamb certification label. And, those ratings will be on the original equipment tires.
