What’s the charger to usb part called?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TheBlackPearl, Oct 23, 2020.
  1. Oct 23, 2020 at 9:48 AM
    TheBlackPearl
    TheBlackPearl [OP] Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    I’ve been searching on eBay and Amazon but keep getting the ones that plug in to this.
    I’m looking for the part that replaces this with 2 usb inputs.
    Thanks in advance
  2. Oct 23, 2020 at 9:52 AM
    RobertD
    Robert
    DFW, Texas
  3. Oct 23, 2020 at 9:59 AM
  4. Oct 23, 2020 at 10:21 AM
    TheBlackPearl
    La Gulf Coast
    Thank you!
    Zero One Actual and Jim LE 1301 like this.
  5. Oct 23, 2020 at 10:36 AM
    :hattip:
  6. Oct 23, 2020 at 11:11 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
  7. Oct 23, 2020 at 11:47 AM
    jrd347
    jrd347 New Member
    2018 Tundra Limited 4x4
    TheBlackPearl[OP] likes this.
  8. Oct 23, 2020 at 12:10 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  9. May 6, 2021 at 6:14 PM
    Pisbill
    Pisbill New Member
  10. May 6, 2021 at 6:30 PM
    biebs96
    PA
    You could always add a usb and leave the 12v plug in case you have a passenger from 2003.
    That is the route I went.
  11. May 6, 2021 at 7:13 PM
    cuaround
    cuaround New Member
    I have just been using a usb outlet with 2 ports that just plugs into the current outlet as shown by the op. I really like the above outlets and a much cleaner look. Are these just a plug and play or is some rewiting required? Also how do you get to the current outlet in the back of the center console?
  12. May 6, 2021 at 7:18 PM
    cuaround
    cuaround New Member
    Sorry, just looked at the oem usb port mentioned above and it sounds like they just plug into the current wiring. How do I get to the wiring and back of the current port? Any info would be appreciated.
  13. May 6, 2021 at 7:27 PM
    biebs96
    PA
    The back of the console just pulls off.
