Toyota 00016-00225 integrated dual usb
Discussion in 'Audio & Video' started by ProtoJ, Jan 12, 2020.
  1. Jan 12, 2020 at 6:33 AM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    I just ordered toyota part 00016-00225 integrated dual usb. I see that it can be easily installed in the rear console....has anyone tried installing in the front?
  2. Jan 12, 2020 at 8:27 AM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    Where did you see the install info on the rear port. That’s the one I want to replace. Just want to make sure it’s plug and play. If not I’ll use the blue sea I have already
  3. Jan 12, 2020 at 3:56 PM
    ProtoJ
    I can’t find it now....but I did see it in my googling!
  4. Jan 12, 2020 at 3:59 PM
    ProtoJ
    @Roman any idea If this part will fit in either the front panel or rear panel In place of a 12V on an 18 CM with bench seat?
  5. Jan 12, 2020 at 4:00 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    8F81E9F2-5569-4FC6-A069-505F78056E4B.jpg 6B2C6516-BF0A-41FE-8F33-EA582536F9EF.jpg E41CC67F-B1AD-41FF-A04F-84ED9F7B9AC1.jpg EC01F261-D7E7-4C42-96D7-D62E8AEB09E4.jpg I replaced front and back with usb I snagged on Amazon. Pretty easy to do
    Not plug and play. I cut off the old connector and crimped on new ones
  6. Jan 13, 2020 at 8:00 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    It's possible, though I don't know for sure.
    ProtoJ[QUOTED][OP] likes this.
  7. Jan 13, 2020 at 8:18 AM
    ProtoJ
    Well I am going to find out! Stay tuned!
    Patch999 likes this.
  8. Jan 13, 2020 at 8:44 AM
    TundraBlack
    TundraBlack New Member
    It will work plan on doing the front as well. I ordered the back just to make sure it worked. The difference between the model number is the length of cord. Which you ordered. Mines was short didn't want to deal with cutting wire.
    the ER kid, King R 808 and ProtoJ[OP] like this.
  9. Jan 15, 2020 at 9:43 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Is it plug and play for the rear?
  10. Jan 15, 2020 at 10:09 PM
    TundraBlack
    Tap in. I basically removed the 12v charger port which is still behind the cover, because I didnt want to make a hole in the cover for the dual charger. Also I had to make sure I could have my arm rest wireless charger hooked up as well.
  11. Jan 17, 2020 at 2:33 PM
    ProtoJ
    This part fits perfectly into the factory 12v hole with zero modifications!
    619Tundra and Voyagermike like this.
  12. Jan 17, 2020 at 2:37 PM
    TundraBlack
    That's what I'm talking about. I like that...
    Voyagermike and ProtoJ[OP] like this.
  13. Jan 17, 2020 at 2:48 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I bought these from Amazon, i did not have to cut the wires but did had to cut the plastic to separate the wires and trim the original hole less than 1/8th of an inch.
  14. Jan 17, 2020 at 2:52 PM
    13igtymer
    Is rapid charge the same as quick charge?
  15. Jan 17, 2020 at 2:53 PM
    xj2202009
    x
    Lutz, Fl
    Yes..is the 2.1 amp vs 1.1 or lower.. make sure is 2.1 amps on each, sometimes they'll say 2.1 on one but not the other, or is 2.1 as long as there's only one device connected to the whole charger.
  16. Jan 17, 2020 at 4:30 PM
    Predator Tundra
    Fallon, NV
    2020 Platinum
    It does attach to the factory wires with taps right and not with the plug that’s there?
  17. Jan 17, 2020 at 4:53 PM
    ProtoJ
    Comes with taps to tap into the 2 wires like this.
  18. Feb 8, 2020 at 2:04 PM
    ProtoJ
    Eric104 likes this.
  19. Oct 15, 2020 at 1:54 PM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    Did the same thing today. Figured while I did the wireless charger might as well as switch out 12 volt for the oem dual USB port. Didn’t know that was an option until this post. Thank you so much. These posts were very helpful.
  20. May 20, 2023 at 9:45 AM
    rrp0968
    rrp0968 New Member
    On the rear USB Ports, does the cover open all the way. There are two versions of this kit….00016-00225 and 00016-325. The 325 kit specifies it is for a Tundra, the 225 does not. Looks like the only differences are the cover and a little longer power leads on the 225 version. I would rather have the kit with the cover to keep dust and debris out of the ports. Just curious if there is any interference with the cover.
