What’s the adversity to having a rake?
Discussion in 'General Tundra Discussion' started by doggiecareman, Aug 21, 2021.
  1. Aug 24, 2021 at 4:24 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It was meant to get a rise and apparently it was quite effective. :rolleyes:
  2. Aug 24, 2021 at 4:26 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You could have got away with a Tacoma. It has better gas mileage and a longer box for your bulky items. It would also be better off road.
    Cpl_Punishment likes this.
  3. Aug 24, 2021 at 4:29 PM
    r1ch999999
    r1ch999999 New Member
    Rich
    I was up in Maine and some local guys were talking about leveling their trucks in order to plow/get through the snow. I like the look of it leveled, or closer to level, but I do truck stuff often enough that it would probably squat if I did that.
    doggiecareman[OP] likes this.
  4. Aug 24, 2021 at 4:56 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    I like the leveled look, in fact my last truck was almost perfectly level. However that was a 2500 and even leveled it took 2000lbs in the bed to squat to a perceptible degree.
    I’m keeping my Tundra stock until I get my camping setup squared away. The Escape 19 I’m picking up next month only weighs 3800lbs dry and has a max GVWR of 5k but I don’t want to be nose high.
  5. Aug 24, 2021 at 5:50 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    besides (opinions) that level looks better than rake , you get some advantages like higher front bumper witch makes it easier to park on Honda's. keeps doors from swinging hard forward when opened do to gravity also level steps to get in and out of truck with out slipping into the door. also takes the strain off your neck from your head leaning forward and cocked back to look at the road. I do use my my Tundra a lot for Truck things like hauling loads , Towing Cars or any thing that seems to be what my day is giving. also pulling out stuck Jeeps , Chevy's or Fords :D. the level also helps a lot of the times with winch angle's when I need to move big heavy things.
    I do have Air bags in the rear to keep level with certain heavy loads also Picked up Daystar Bag cradles that I've yet to installed but will allow the bags to float off the axle under hard articulation.
    Darkness likes this.
  6. Aug 24, 2021 at 6:14 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Or I can drive what I want because I can.
    r1ch999999, RobertD, des2mtn and 3 others like this.
  7. Aug 24, 2021 at 6:21 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    I don’t worry about what others like, but seems a lot of leveled trucks eventually end up with a permanent squat, not deliberately. Why is that?
    doggiecareman[OP] and Pbed85 like this.
  8. Aug 24, 2021 at 6:32 PM
    NueveTundra
    Planet Earth
    probably never readjusted hight for added things or rear leaf wear/sag
  9. Aug 24, 2021 at 6:33 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    That is me!
    Zero use for a truck.
    Money not an issue.
    I wanted it. I bought it.
    I smile.
  10. Aug 24, 2021 at 6:53 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sure can princess.
    Pbed85 likes this.
  11. Aug 24, 2021 at 7:20 PM
    doggiecareman
    doggiecareman [OP] YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Admittedly when I posted this thread and the way I stated it was somewhat instigative and tongue in cheek. It definitely worked on instigating with some and hope it is all taken in good over opinionated fun for everyone.
  12. Aug 24, 2021 at 7:21 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Congrats on successfully disturbing the $h1t without a ban. :D
  13. Aug 24, 2021 at 7:28 PM
    doggiecareman
    Eric
    North Central CT
    Lol, it's the little pleasures in life that make it all worth while :)
  14. Aug 24, 2021 at 7:47 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Once I saw Discount Tire stretching the shit out of my bags I installed Daystar cradles. They work great.
  15. Aug 24, 2021 at 8:04 PM
    this one time...at ban camp...
    little pleasures do add up.
  16. Aug 24, 2021 at 8:11 PM
    No funny bones tonight? :rofl:
    doggiecareman[OP] and landphil like this.
  17. Aug 24, 2021 at 8:12 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wouldn't call that a rise
    I don't think anything was instigated here. Usual different opinions and mild banter, nothing that rocked the boat.
  18. Aug 24, 2021 at 8:29 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I had to do a double take on that one.
  19. Aug 24, 2021 at 8:32 PM
    #49
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    Yes, yes it is
  20. Aug 24, 2021 at 8:35 PM
    #50
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Keep your flute to yourself! :rolleyes:
  21. Aug 24, 2021 at 8:40 PM
    #51
    You might not have seen that I banned the OP for a minute...as a joke.
    I'm not sure why some people get so worked up. If you don't pay my bills, didn't walk down the isle with me, or whole heartily ask and value your opinion....No FG.
    Cpl_Punishment, Boerseun and landphil like this.
  22. Aug 24, 2021 at 8:45 PM
    #52
    More of a trombone guy huh? :D
  23. Aug 24, 2021 at 8:58 PM
    #53
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I did see it. I went to the ban thread to see why and when I got back the stripe was gone.
    landphil and ColoradoTJ[QUOTED] like this.
  24. Aug 25, 2021 at 12:26 AM
    #54
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Did anyone let BJ know he's not supposed to be doing truck things with his truck setup like this?
  25. Aug 25, 2021 at 12:57 AM
    #55
    NueveTundra
    Planet Earth
    I'll let you in on a secrete about why pick up trucks come stock with rake , its cause the OEM is to cheap to make the rear auto level like a big rig or a real truck. But then again 80% of people who tow or haul loads never do it correctly , nothing funnier than seeing a non level trailer being towed do to not either having the proper drop hitch or raises hitch. :rofl:Talk about real danger.
    landphil and Hbjeff like this.
  26. Aug 25, 2021 at 3:13 AM
    #56
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    I hear ya! Limited truck stuff usage...taking brush to the dump, Lowe's runs...etc
    I could make do without it. After many years of driving manual transmission sedans and coupes I gave the Tundra a try. I love driving this beast:thumbsup:
    doggiecareman[OP] and Boerseun like this.
  27. Aug 25, 2021 at 3:38 AM
    #57
    That is one sweet GM truck.
  28. Aug 25, 2021 at 6:57 AM
    #58
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I back into my sloped driveway and to date have not had my doors swing open.
  29. Aug 25, 2021 at 10:26 AM
    #59
    OnespeedTRD
    Don
    San Diego
    Tell me Toyota didn't drop a GM motor in there? Its a Toyota backed team, and nearly everything on these trucks is made by some third-party fabricator, so all you can really go by is the powerplant and the badges/decals on the outside.
  30. Aug 25, 2021 at 10:27 AM
    #60
    r1ch999999
    Rich
    Which isle are we walking down? Are we headed to the beach?
