Westscott in the front... what in the back
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by cctxquicksand, Jan 24, 2021.
  1. Jan 24, 2021 at 3:36 PM
    cctxquicksand
    cctxquicksand [OP] IG - TRDistheWrd
    Coach builder +1?
    coach builder +2? +3?!?
    icon rxt? Been hearing these aren’t so great
    deavers? Other???
    looking to lift the 21 pro just a bit, I’m set on westscott lift for the front but I definitely don’t want to use the block in the back because I play to wheel a bit. Looking for a level look with no rake. What do you guys think the beat route would be?
  2. Jan 24, 2021 at 8:24 PM
    Tundrafan23
    Tundrafan23 New Member
  3. Jan 24, 2021 at 9:21 PM
    cctxquicksand
    I considered that kit but it only lifts the front an inch, the westscott is 250 and lifts 1.5 inches
    I do see that kit uses the +3 shackles so I may go with that and deal with a bit of rake. thanks for the reply
  4. Jan 24, 2021 at 9:35 PM
    1015K9
    1015K9 Austin
    Temecula, California
    2013 Rock Warrior
    In the same boat. I like the idea of westcott up front with the CB +2 or 3 in the rear.
  5. Jan 24, 2021 at 9:56 PM
    Jmn
    Jmn New Member
    Could you share more about why you think westcott isn't a good idea on the rear?
  6. Jan 24, 2021 at 10:17 PM
    cctxquicksand
    The rear is just a one inch block. While it will lift your rear I hear that it also tends to flatten your leaf spring.
    Basically there are better options out there
  7. Jan 25, 2021 at 1:40 PM
    Bootleg
    Bootleg New Member
    Brandon
    2020 MGM TRD Pro
    I'm working w/ Main Line Overland to try to solve this problem for me. I want to keep the stock shocks in the back but also need to be able to handle more weight (600-700lbs) and compensate for the 1.5" up front. I'll keep you posted as to what they suggest. I got tired of asking for help on forums and FB groups. I couldn't get an answer that didn't further muddy the water so I decided to go to experts and let them guide me. Sounds like we'll be doing CB +1 with Dobinsons 121 leaf packs but we haven't nailed it down quite yet.
  8. Jan 25, 2021 at 1:42 PM
    Jmn
    Jmn New Member
    I got the Westcott installed at factory, on the rear as well.
    Thinking of adding RXT Leaf pack on option 3 that add 4" unloaded - 2" with 750 lbs.
    I also have the front piece, truck sits level.
    Wondering if when I put the leaf pack in if I should then remove the 1" block on the rear?
  9. Jan 25, 2021 at 1:55 PM
    1015K9
    1015K9 Austin
    2013 Rock Warrior
    smart. Keep us posted.
  10. Jan 26, 2021 at 7:30 AM
    cctxquicksand
    I ordered +2 shackles last night. I will update once installed
  11. Jan 27, 2021 at 9:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I like a little rake... don’t plan on lifting the front but looking at getting those shackles for the back
  12. Feb 6, 2021 at 11:56 AM
    hefemi
    hefemi kifaru overland - Qi Fuh Rou
    Kifaru
    > 1794 - Kifaru
    following up on this as well.
  13. Feb 6, 2021 at 12:48 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    I have Westcott on front and rear. Right at 18,000 miles now. Spring has not deformed any.
    ryanwgregg and cctxquicksand[OP] like this.
  14. Feb 6, 2021 at 12:59 PM
    cctxquicksand
    Good to know, I kinda wish I would have went this route. I ordered +2 shackles on the 25th and they haven’t shipped yet :confused:
  15. Feb 6, 2021 at 1:14 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Good to know... I’ve been thinking about just adding +2’s to give it a little rake
  16. Feb 9, 2021 at 5:05 AM
    KC.Tundra
    KC.Tundra New Member
    Kevin.
    Kamloops, BC
    2019 SuperWhite Platinum Tundra CrewMax SB
    20’ KMC Grenade OR. TRD Skid Plate. TRD Rear SwayBar. Toyota Door Sill Protectors. Toyota Hardflip Tonneau cover.
    I know it’s not a tundra, but I had the westcott designs lift in the front, icon rxt leaf pack in the rear, and timbren bump stops. I had zero issues and complaints about both or all three products. The Tacoma rode great and had a nice look to it. The improvements helped towing the heavier weight. Definitely planning on going with a similar set up on the Tundra just with different suspension this time around. Trd pro take offs don’t seem to be as common with the tundras.
    DadduMan likes this.
  17. Feb 9, 2021 at 6:10 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Have you tried sending a message to the CB guy on here? I did after 3 days of no shipping update. He never replied but maybe that got the ball rolling for me.
    The leafs on my previous Tundra were flattened after 50k+ miles with blocks. Maybe the added weight of the canopy helped cause it, I don't know. I don't recommend them personally.
  18. Feb 9, 2021 at 6:22 AM
    cctxquicksand
    I’m pretty sure I talked to him directly on the phone last week. David, he’s the guy that told they would be shipped last by Thursday of last week. Still no update, if these weren’t the Ferrari of shackles I’d have cancelled already
  19. Feb 16, 2021 at 4:39 PM
    cctxquicksand
    Finally received them today. I will updates with pictures after install
  20. Mar 27, 2021 at 9:17 AM
    TundraJeff305
    TundraJeff305 New Member
    Jeff
    2021 TRD Pro
    I’m planning on the Westcott up front and CB shackles in rear definitely want the level look. Are you happy with the +2’s?
  21. Mar 27, 2021 at 10:45 AM
    cctxquicksand
    I was happy until a put some weight in The bed and now I’m a touch nose high. Likely going to get some icon rxt to help me relevel and handle loads better (no pun intended)
    TundraJeff305 likes this.
  22. Mar 28, 2021 at 10:26 PM
    Mf32
    Mf32 New Member
    2020 TRD Pro Super White
    Will be adding CB +3 in back and Westcott up front in the next week or so. Will post after
  23. Mar 30, 2021 at 10:37 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Just curious I know the group buy is done on the coach builder. That plus 3 will keep the tundra Pro level correct. Why did you choose that route instead of using the whole westcott kit? Thanks.
  24. Mar 30, 2021 at 10:52 AM
    Mf32
    Mf32 New Member
    I’m not a mechanic but the back of the Westcott kit is a block, and for the most part everyone says to stay away from blocks. I’ve also heard quite a bit of negative feedback on add a leafs. I don’t think I’ve read anything negative about the shackles other than it’s difficult to fit a 35 spare between them.
    I’m just going to roll the dice and see how everything goes!
  25. Mar 30, 2021 at 11:00 AM
    TundraJeff305
    Jeff
    2021 TRD Pro
    From what I learned in the research I did thru this forum and people I spoke to the shackle is a better option for the rear lift than block supplied in the Westcott kit. I honestly don’t think you can go wrong either way you just have to do some research and go with your gut. I plan on doing a larger lift later on and this just gives me the ability to increase my tires size and keep the expense fox shocks I paid for. When I get my monies worth out of it I’ll move on to bigger and better things. Good luck with whatever path you choose I’m sure it’ll be awesome regardless.
  26. Mar 30, 2021 at 11:17 AM
    RusPro21
    Don
    Pa.
    Thank guys I figured that’s what you would say about the coach builder being better than the blocks. Yeah I would not add the blocks. When I had my 15 Tacoma years ago I had the bilsteins 5100’s and add a leaf in the rear. I had no issues in the rear and it rode and handled good. I assume if you guys are going with the Westcott kit your going with 295’s, And I assume the plus 3 will make it level with the Westcott.
  27. Mar 30, 2021 at 11:21 AM
    grichg
    grichg New Member
    rich
    If you are in So Cal go to Deaver Direct and get something for YOUR truck and use. No brainer
  28. Mar 31, 2021 at 7:46 AM
    Bootleg
    Bootleg New Member
    Brandon
    2020 MGM TRD Pro
    We ended up going with Westcott up front, Toytech add a leaf, CB +1 shackles, and firestone airbags w/ daystar cradles in the back. So for I'm really happy with it. Ride is great with only my Decked drawers and some gear inside but it gives me adjustability for heavy loads and towing the trailer. As it sits I have just over an inch of rake.
  29. Apr 18, 2021 at 9:56 PM
    Mf32
    Mf32 New Member
    Westcott front and CB +3, poly bushings and Cb drop kit is now installed. My guy who does installs for a major Toyota dealer was super impressed. He had never heard of either.
    Rides better now. Not so floaty but not too stiff.... and is better around turns. Should be the stock set up IMO.
  30. Apr 18, 2021 at 9:59 PM
    1015K9
    1015K9 Austin
    2013 Rock Warrior
    Got any pics?
