Went for an oil change…..
Discussion in 'New Member Introductions' started by raspy87, Dec 30, 2021.
  1. Dec 31, 2021 at 8:47 AM
    blanchard7684
    blanchard7684 New Member
    Any chance the window sticker was sent with truck?
    Otherwise a dealer parts dept can check the vin and tell you.
    Or the hard way: mark drive shaft and tire. jack up rear and see how many turns the drive shaft does before one rev of tire.
    Or if you have a 2019 and a 5.7 then you have 4.30 gears.
    or if you have 4.30 gears and you floor it in tow haul mode, it will trigger some form of a fright response.
    Or cruise in S4 and at 40 mph you'll be near 2k rpm.
  2. Dec 31, 2021 at 8:49 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  3. Dec 31, 2021 at 9:19 AM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
  4. Dec 31, 2021 at 9:25 AM
    Mr Badwrench
    Mr Badwrench New Member
    Nice! Our trucks are twins. Of all the trucks I've owned throughout the years, this is by far my favorite. You can run 275 65 18 tires too, they make the truck look a little bigger, when you need rubber.
    Enjoy it.
  5. Jan 1, 2022 at 2:26 PM
    raspy87
    raspy87 [OP] New Member
    Andrew
    RI
    ‘19 DC SR5 Cement
    second to last for the win.
    I just had dealer order tires. BFG All-Terain T/A. I’m hoping they’re they ko2. I wish I’d know about the tire size 72 hours ago. Lol.
    And thank you all again for the welcomes. Day 2 of Tundra ownership and loving every moment so far!
  6. Jan 2, 2022 at 2:56 AM
    Welcome from Ohio
  7. Jan 7, 2022 at 7:31 AM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    So, if I tow maybe 3-5 times a year, should I consider having it re-geared?
    Mine is a 2021 CM 5.7L with 4.30 gear
  8. Jan 8, 2022 at 12:30 PM
    raspy87
    Andrew
    RI
    ‘19 DC SR5 Cement
    I finally turned off Nannie’s and turned up the beast!
    Wow! Is about all I have to say. Figured I’d mess around with it before I put the new treads on. I’m having so much fun with the truck.
