Went Camping, not stoked on saggy backend
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by dhbrown, Apr 19, 2021.
  1. Apr 28, 2021 at 7:48 AM
    dhbrown
    dhbrown [OP] New Member
    2019 TRD Pro, black
    So, after looking around, chatting with a few "off-road" shops, I've pulled the trigger on Deaver U748 springs. A little more pricey than I was hoping, especially w/ new shackles and all, but I think this will set me up for any build moving forward -- and if I end up towing a mega trailer or pop in a camper, I can always ad airbags or sumos... But for now, I say build the base right, and don't look back.
    DoublePro, rdiddy5, 2mchfun and 3 others like this.
  2. Apr 28, 2021 at 9:16 AM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    I would say that’s the right decision. If you’re going to mess with the leaf spring, either replace the whole thing or don’t touch it.
    rdiddy5 likes this.
  3. Apr 28, 2021 at 9:32 AM
    Wallygator
    dhbrown[OP] likes this.
  4. Apr 28, 2021 at 9:57 AM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Good choice! I was going to recommend taking a look at the Icon RXT pack that has 3 different spring rates. You may have researched this option. You won't be disappointed with the Deavers. I personally don't have them, but haven't heard a negative review.
    After all, who likes a saggy rear end ;)
    dhbrown[QUOTED][OP] likes this.
  5. Apr 28, 2021 at 10:01 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Get an AAL. I was very pleased with the minimal amount of sag.. Pretty sure this tongue weight was more than the gear you mentioned.
    rdiddy5, IndianaGeologist and MrJonnb like this.
  6. Apr 29, 2021 at 3:51 PM
    dhbrown
    2019 TRD Pro, black
    What do you have up front? I'm afraid the front end may looks super low now. The shop I'm going with recommended going with a spacer kit. They (the owner) and I NEVER go that route, but i figured the Pro Suspension isn't clapped, so why spend money if I don't have to. I'm just a little worried I may trash the front end with my aggressive driving.
  7. Apr 29, 2021 at 5:04 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You do not want to put a spacer with your pro shocks. Never add bottom tier products to a very good product for no gain
    Backslider likes this.
  8. Apr 29, 2021 at 7:50 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm late to the party but I'll post. Do you want your rear end to remain the same height when you are NOT towing or loaded? If yes, airbags is what you wanna get.. Shackles, AAL, or a new leaf pack will either change your ride comfort in the rear or leave your ass stuck up in the rear when your unloaded..
    edit: you shouldn't have any air in the bags unless your loaded. With the exception of 5 psi that Firestone recommends.
  9. Apr 29, 2021 at 7:53 PM
    Backslider
    Tooele, UT
    Fox 2.5s with adjusters. My whole setup is in my build thread if you click the link and check it out.
  10. Apr 29, 2021 at 8:14 PM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    Most folks with non trd pros who lift the front 2-3” will lift the rear with shackles like has been mentioned. Check out coach builder, toytec , or bossoffroad (along with poly bushings for whichever). It won’t make the truck ride harsher when unloaded like oversprung leafs or inflated airbags would, but keeps the sag to a reasonable amount of up travel when weighed down. Lots of options depending on your needs, priorities, and budget. Good luck!
    dhbrown[OP] and TunBrun like this.
  11. Apr 29, 2021 at 8:31 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Can you feel the 5psi in daily driving?
  12. Apr 29, 2021 at 8:32 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    no
    Hbjeff[QUOTED] likes this.
  13. May 3, 2021 at 2:41 PM
    woofhauler
    woofhauler New Member
    Pacifica, CA
    I added a Leer Topper and a Prinsu on the topper noticed almost an inch of sag, add my three dogs (~250lbs) and I felt like I was repping the Carolinas. I had a ReadyLift +2 that I was debating selling and just put the rear two inch blocks on, now I sit at about one inch rake and almost level again when the doggos are in the back. I'll probably switch the blocks out to bags or shackles someday.
    Hbjeff and TunBrun like this.
  14. May 4, 2021 at 5:12 PM
    dhbrown
    2019 TRD Pro, black
    For all you haters, lovers and/or appreciators, here's what I ultimately went with: my original add-a-leaf (two to be exact) and keeping the front as is stock. I know have 2 1/4" rake completely empty (essentially looks like an sr5 rake but 4" taller). Weighted down doesn't change much -- maybe an inch. Pretty stoked on how it looks and doubly stoked I didn't spend three time what I paid for a new leafs pack.
    ** New leafs are 2nd and 4th from bottom.
  15. May 4, 2021 at 5:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Hows the ride
  16. May 4, 2021 at 5:43 PM
    dhbrown
    2019 TRD Pro, black
    It feels great! Took a few big hits on the freeway coming home and the suspension ate it up and snapped right back into place.
  17. May 26, 2021 at 12:26 PM
    TorinWallace
    TorinWallace Yota Addict
    2020 TRD Pro, DoubleCab, Army Green.
    CB Shim + Shackles | 305/70r18 KO2's | 18" Method NV's | Firestone Airbags | Tow Mirrors | Marlon Sleddeck | Spyder smoked taillights.
    I've run the same set of firestone riderite airbags and airlift compressor for 4 years on 2 tundras with thousands of miles towing a camper and hauling sleds on a sled deck with no issues. Given I also do have CB shackles, but the air bags are what really holds the weight. I highly recommend them.
    Gaston, n0rth, bulldog93 and 6 others like this.
  18. May 26, 2021 at 1:19 PM
    Kanobi13
    Kanobi13 New Member
    Man that army green really changes colors in the sun light lol
    AggiePhil and 2mchfun like this.
  19. May 26, 2021 at 1:34 PM
    #49
    TorinWallace
    hahaha sure does!
  20. Jun 3, 2021 at 4:43 AM
    #50
    2mchfun
    IMG_20210515_201800_2.jpg Dobinson's HD leaf packs, yellow Sumo springs for bump stops, Roadmaster HD active suspension to keep my nice curvature for a long time on the leaf packs. Bilstein 5160s with res. for the shocks. This truck isn't squatting much regardless of what you load on it, rides nice, much like stock but higher of course and it has the ability to carry the payload and keep the headlights in focus.
    Edit: Ironman greasable shackles and bushings, brake relocate, carrier bearing drop. Dobinson's u bolts. BDS traction bars to control axle wrap.
    AggiePhil, Bad Cow, Bikeric and 3 others like this.
  21. Jun 4, 2021 at 4:55 AM
    #51
    2mchfun
    I have a whole bunch of spring, no harsh ride, just as good as stock, it's all about good shocks coupled with the springs.
  22. Jun 4, 2021 at 6:44 AM
    #52
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I finally ordered a second set of sumo springs, cut them down to bumpstop height. Now happy! I can swap them in 5 minutes to the full height set when we hook up the trailer
    honestly sumos are brutal for daily driving when empty. I would do RAS if i could start over
    2mchfun likes this.
  23. Jun 4, 2021 at 7:22 AM
    #53
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    I’ve really enjoyed this thread. Curious if I could chime in for advice based on comments from my mechanic:
    1) Told me NOT to add shackles under any circumstances. Didn’t really have a chance to get into why. Any thoughts? This is an off-road truck shop, so they do have some clout in my mind.
    2) They told me to just add a leaf or two. Everyone on here (most, anyway) have said that adding a leaf is pretty much guaranteed to get squeaking. I hate things like incessant squeaking. Currently thinking I’ll add the icon RXT rear leaf spring set, but of course would love to save money if the add a leaf concept can be done confidently.
  24. Jun 4, 2021 at 7:28 AM
    #54
    2mchfun
    My Dobinson's HD leaf packs don't squeak. They are not a whole bunch of fun to install, quite heavy, that said I am very much pleased. Expensive, yes, good things are not cheap, cheap things are not good.
    Wallygator likes this.
  25. Jun 4, 2021 at 7:44 AM
    #55
    2mchfun
    RAS is kicking ass, don't throw in the towel. I have it and Sumo springs, plus HD leaf packs. You can achieve greatness with a Tundra.
    AggiePhil likes this.
  26. Jun 4, 2021 at 8:29 AM
    #56
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    for my 4k lb trailer and full bed, i really like the light sumos, perfect for smoothing out the weight. They just suck for daily.
  27. Jun 4, 2021 at 8:37 AM
    #57
    2mchfun
    In my case, they are like bump stops, I have a 2" gap to the frame. That means, they don't suck as a daily, and they are actually better because it's not a solid bump stop, slowly compresses so there is no harsh impact at all regardless of the load. Truth is, I think my truck probably rides even better than stock again regardless of loaded or empty. I expected stiff, nope, Cadillac all day.
  28. Jun 4, 2021 at 10:19 AM
    #58
    shakey_jake
    shakey_jake New Member
    Jake
    Virginia Beach
    2012 Tundra 5.7 TRD 4x4
    6" lift. 35s on 20s
    Serious off-roaders, like guys that beat on truck suspension shy away from longer shackles because they are a weak point and the longer they are, the weaker they are.
  29. Jun 4, 2021 at 12:01 PM
    #59
    jeremyd
    NV
    2014 SR5 CM 4X4
    Sometimes the info on these forums can be tricky on what to believe, lots of people only read and don't post... I've had an AAL since 2014 and I don't have any squeaking..
    2mchfun likes this.
  30. Jun 4, 2021 at 12:39 PM
    #60
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    coach builder shackles are so much heavier duty than stock. The difference between a twig and a 2x4
