Welding
Discussion in 'Sports, Hobbies & Interests' started by TruckyTruck, Mar 17, 2014.
  1. May 14, 2020 at 8:00 AM
    #61
    kevine0001
    kevine0001 New Member
    Kevin
    I've been welding for about 7+ years, all mig. Have a 220 gas mig welder and a 220 plasma cutter. But looking to get into TIG to make a few things for my truck. I'm actually considering the HF vulcan. Wondering if anyone has any thoughts on it, and also any tips on setting the machine up. I know I'll be watching a ton of videos, but curious of others personal experiences.
  2. May 14, 2020 at 9:05 AM
    #62
    Warreng
    Warreng New Member
    I would buy a used lincoln or miller over a new something or other.
    There is a welding thread “anything welding” on tacomaworld and a few people have the HF welders. Maybe chime in there.
  3. May 14, 2020 at 1:39 PM
    #63
    kevine0001
    Kevin
    for the price, even the used millers and lincolns are over a grand from what i've seen. or they are beat to hell. the vulcan is about $600. if figure i can get tank and reg for $100. i have everything else i'd need. the 220 mig i've been running since 2014 is the Harbor Freight 220 mig welder. it has done surprisingly well. so much so that even a friend who is a certified structural welder used it a few times and said it laid down very nice welds for a HF welder. I suppose current is current, wire is wire and gas is gas. those three components aren't going to be significantly different brand to brand...biggest factor - the person doing the welding.
  4. May 14, 2020 at 1:45 PM
    #64
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I just picked up a weldpro 2020. It’s a multiprocess welder. So far very happy with it for stick and mig. Haven’t tried tig w it yet. It’s not a real tig, it’s a lift tig. Just got an argon bottle so gonna play w it soon. To do aluminum I’ll need a spool gun. Again, so far very impressed
    kevine0001 likes this.
  5. May 14, 2020 at 1:59 PM
    #65
    Warreng
    Warreng New Member
    I believe anyone can make a welder these days, and you are right, its wire and electricity, pretty hard to mess it up. I think a lot of these no name machines are great for the hobby welder, there were not many options when I bought mine.
    Having said that, my 18yr old lincoln will still be pounding long after I leave this planet, and its so fucking smooth.
  6. May 14, 2020 at 2:04 PM
    #66
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm lightweight thinking of getting a stick welder.
    I have yet to really need a welder, but when i was building my outdoor kitchen it would have been nice. it would probably get used only a couple times a year. Or should i go straight to mig?
  7. May 14, 2020 at 2:10 PM
    #67
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  8. May 14, 2020 at 2:16 PM
    #68
    kevine0001
    Kevin
    Yeah, definitely a lot of stuff out there for hobbyists, like myself. If you're doing it for a job, even a side hustle, I'd say go get a Lincoln or Miller. Don't mess around. But for the weekend guy fixing stuff around the house, making offroad stuff for his own vehicle, the less expensive welders will be more than enough.
    Daniel - if it's your first welder, learn on a MIG. Way cheaper and IMO, likely easier. You can do all sorts of mild steel stuff.
  9. May 14, 2020 at 2:22 PM
    #69
    Danimal86
    Daniel
    Sacramento, CA
    I figured that would be the answers i'd get. I like the idea of not having to deal with shielding gas tanks. I wouldn't be trying to win any awards for prettiest weld, just trying to put two pieces of metal together.
  10. May 14, 2020 at 2:39 PM
    #70
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm also trying to jump on this train.. I've been looking at those HF Vulcan migs, but I'll probably follow this guidance.
  11. May 15, 2020 at 4:22 AM
    #71
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    As mentioned in this thread, the Weld Pro 2020 is a good choice for a mid tier tig welder. Also look into the Esab fabricators line of multi process welders. You would have to buy the tig torch separately, but you will be getting a solid torch vs what you get with other machines. You definitely need to be hooking up 220 for your machine. Here's a link to one of Esabs welders, figure in the torch your around a grand. If your gonna spend $700, mind as well spend $300 more for the better welder.
    Whatever you decide, make sure your using 2% Thoriated Tungsten, it has a red band around one end. It's the best out there, just remember to wear a mask or cover your face when sharpening Tungsten. Tight Beads!
    https://www.weldingsuppliesfromioc.com/esab-fabricator-141i-multi-process-welding-system-w1003141
  12. May 15, 2020 at 8:40 AM
    #72
    kevine0001
    Kevin
    The esab stuff is really nice. And I agree with Ron's advice, definitely get 220 put in your garage. I had an electrician friend who installed mine with a 50 amp breaker. He was the electrical supervisor of a huge property up in Nor Cal. He had a 40' 220 pig tail cord in the shop that had been laying there with both male and female connectors. He cut the plug off my welder, put the male end on it, and installed the 40' pig tail cord with female plug into the wall. It's great because now I can run my welder any where in my garage and even down to the sidewalk to weld stuff.
    If you are going to the expense of putting a 220 plug in your garage, get some sort of 220 extension cord, that way you're not limited to welding just the length of the welding machine's cord. You may wish to invest in a spider box too. I ended up getting a 220 plasma cutter. Plug was different. I got a spider box that my wall cord plugs into, and the spider box has several different 220 plugs, for any 220 tool I may end up getting. Link below is very similar to what I ended up with.
    https://www.larsonelectronics.com/p...ydkZ034dv_4b_eTCiz2tlXMni_-6KhCIaAljNEALw_wcB
  13. May 15, 2020 at 8:53 AM
    #73
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    sigh. too much stuff i want to do and too little funds to do it.
    i had been looking at a miller multimatic 220 along with a plasma cutter. i'd like to be able to make/fix stuff for the truck but my other idea was to be able to make frames for the metal based prints i've been doing. thought it'd be pretty to cool to make a shadow box frame and have the print "float".
    i like the spider box idea but i had been considering adding outlets to a welding table i would have made.
  14. May 15, 2020 at 9:01 AM
    #74
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I got a 40’ 220 extension cord and a dryer adapter. My laundry is right next to garage door. Sort of a pain in the butt, but with how often I actually use it it’s easier than running a new circuit up from basement.
  15. May 15, 2020 at 9:02 AM
    #75
    kevine0001
    Kevin
    I know I may get some slack, but the basic 220 harbor freight welder has served me well for the last 6 years. i thought i was going to upgrade last year to a miller, but the HF one just keeps on going and putting down good welds. I posted in the 3rd gen tundra forums recently, about the rock sliders that I made for my truck. It's an inexpensive way to get started. As far as plasma cutters, I got the Lotos 50D from Home Depot...$350. Once you figure out what settings work with various steel thickness, you're in like Flynn. https://www.homedepot.com/p/Lotos-5...e-110-220V-1-2-in-Clean-Cut-LT5000D/205438858
  16. May 15, 2020 at 9:02 AM
    #76
    kevine0001
    Kevin
    Here's the finished sliders
    300BLK, Warreng, TXTundra2722 and 2 others like this.
  17. May 15, 2020 at 9:04 AM
    #77
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    what are you using for air on the cutter?
  18. May 15, 2020 at 9:10 AM
    #78
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    No slack if you end up with a product your hoping for!
    I’m the poster boy for a straight farmer 110v mig welder. I’ve built two trucks and various other goodies for about 7 years now. Anything works if you stay within the operating envelope and proper procedure. Weld for 2 minutes-drink beer for 15 while it cools off for another round haha
    kevine0001[QUOTED] likes this.
  19. May 15, 2020 at 9:11 AM
    #79
    kevine0001
    Kevin
    I have a 21 gallon compressor with a 50' hose further back in my garage. I run it at about 70-75 psi per the manual on the plasma cutter. I've only used it on steel up to 1/2" thick, but I've seen videos of guys cutting 3/4". I'm fairly certain it would work fine up to 1", but you'd have to run it maxed out, go super slow, and you'd have to shut it down every 15-20 minutes for duty cycle. But it would probably work. The highest setting was too much for the 1/2" that I did.
    Mountun Goat likes this.
  20. May 15, 2020 at 9:11 AM
    #80
    kevine0001
    Kevin
    I would echo Dan's comments. Beer, welding...for me that's a productive Friday night...ha ha
  21. May 15, 2020 at 9:12 AM
    #81
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Sounds like a wicked fun Friday night.
  22. May 15, 2020 at 10:31 AM
    #82
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I bought a Miller 211 MIG a few years back, honestly not that impressed. It welds great, but there were issues with the internal breaker off the bat and I just learned the other day that Miller changed their consumable design and don't even sell tips for their previous welders (granted, there's aftermarket). On the flip side, 9 months ago I bought a super cheap Tig on Amazon: https://www.amazon.com/AHP-AlphaTIG...1&keywords=ahp+alphatig&qid=1589563439&sr=8-2
    It's called an AHP, and it's a 200A, AC/DC machine for $800 (was $700 when I got it). 100% duty cycle @ 150A, and came with everything from the torch and a bunch of collets and cups to a foot pedal and finger trigger. I've had 0 issues with it, and it has a lot of good reviews. Food for thought if you're looking for a budget TIG that can do aluminum. I'm just a guy in a garage and don't need it to make a living though, and bought it for fun.
    kevine0001, dcsleeper408 and saybng like this.
  23. May 15, 2020 at 11:58 AM
    #83
    rons23
    Ron
    Kill Devil Hills
    Sean, Miller's rule when it comes to GTAW Process. Downside is your gonna pay for what you get, which is expensive any way you swing it. I have used them for welding major hull cuts with UT Inspection to reactor work. Top of the line, but definitely not recommended for a weekend warroir or hobbyists. I've been wanting the Dynasty Tig Runner for years, complete unit, which you can also tig aluminum. Comes with water cooling capabilities. Only thing is it's around 8-10 k give or take how many options you want:D That's why I suggested the Esab. It's a good little unit for the money :thumbsup:
    smslavin[QUOTED] likes this.
  24. May 15, 2020 at 12:04 PM
    #84
    rons23
    Ron
    Kill Devil Hills
    The Alpha Tig is another great choice for the money. It's very nice having 100% Duty Cycle @ 150. :thumbsup:
  25. May 15, 2020 at 12:13 PM
    #85
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i've looked at them. the multiprocess machines seem to run about the same price as the millers. at least over at cyberweld. i don't have a lot of space so the multiprocess machines just seem to make sense. we'll see what happens. i've got a lot of other stuff to figure out before i can get back to thinking about welders.
    always appreciate your input though.
    rons23[QUOTED] likes this.
  26. May 15, 2020 at 12:16 PM
    #86
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I’m not a professional welder but i like to play with projects I have a snap on mig welder and a HTP America invertig 221 at home set up at 220v
  27. May 15, 2020 at 1:42 PM
    #87
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    Check out everlast welders as well they have some great welders.
    rons23 likes this.
  28. Jun 27, 2020 at 9:17 AM
    #88
    longhornfan2324
    longhornfan2324 New Member
    I was just given a Snap-On FM140A mig welder that wasn't feeding wire, motor would kick on with 12-volts applied. Replaced the bridge rectifier on the wire feed circuit board and got everything running again. Need to go get a bottle of shielding gas and start practicing. Any tips to start. The welder is already setup properly as the guy who gave it to me works for a bodyshop and welds on steel and aluminum.
    snivilous likes this.
  29. Jun 27, 2020 at 9:32 AM
    #89
    snivilous
    SW UT
    If you have time I'd watch one or two YouTube beginner videos. If not, clean metal (flappy disk, grinder, scotch Brite, etc preferred), get a tight fit on whatever you're welding, use 75%Argon25%CO2 (standard mix, called C25), make sure the tip (a consumable) matches your wire diameter (I prefer .030" for mig), have your gas pressure at 15-20psi, make sure the machine settings are set to what the machine recommends, have most 0.5" of wire stick out (distance from tip to the weld), and then go to town. Just move slow, watch the puddle and build it up and then move a little. A common technique is drawing cursive "e"s, like a little repeating spiral.
    As someone who's not a formal welder, the biggest issues I see is way too much stick out so the tip is far from the metal, and moving too fast. Don't watch the arc, watch the puddle and move the puddle. Like I said too, a few YouTube videos here and there can help a lot also.
  30. Jun 27, 2020 at 11:04 AM
    #90
    rons23
    Ron
    Kill Devil Hills
    You don't need shielding gas to weld. Just buy a spool of innershield flux wire NR-MP for the time being to practice till your able to get setup like you want. :welder:
