Welding/fab help
Discussion in 'Off-Topic Discussion' started by Omohundro, Mar 4, 2021.
  1. Mar 4, 2021 at 6:22 PM
    Omohundro
    Omohundro [OP] 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I’m looking to add a carbon fiber heat shield to the titanium exhaust on my bike. Sounds dumb but I keep melting my shoes on the pipe nearest to the shifter. So my question to any fab guys, how would you do it? My first idea was to weld small nuts in place and simply bolt it on..not much luck finding someone with much interest in welding it for me.
    Second idea was to drill and install revnuts, haven’t gotten a lot of good feedback on that.
    I need help.
    A8D10C43-92B9-4E37-BCDF-E69D96018E32.jpg 9561A59E-423F-4488-A007-6A015278B166.jpg
  2. Mar 4, 2021 at 6:28 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    People don't want to weld it since it's titanium, and probably most flat out can't or haven't ever done titanium. I'm not a fan of rivnuts but that'd maybe work. I'd probably do like a hose clamp that holds a tab or it bolts to the hose clamp. Then it's not permanent or messing with your fancy exhaust.
  3. Mar 4, 2021 at 6:33 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    This. You want tubing clamps with standoffs. Or split ring hangers. If you want dirt cheap then use a standard exhaust clamp with a stud welded to the bridge.
  4. Mar 4, 2021 at 6:37 PM
    pickeledpigsfeet
    Kings & Icons
  5. Mar 5, 2021 at 2:49 AM
    Omohundro
    Jody
    McMinnville TN
    Thanks for the help, those heat shield standoffs may work great if I can get some long enough to go around both pipes. The shield came with some very cheesy hose clamps with a nut welded to them that would “work” if long enough but they are not. The shield needs to go right where the two pipes collect into one
  6. Mar 5, 2021 at 3:46 AM
    Mike_P
    Mike_P New Member
    2017 Quicksand Tundra SR5
    Why not just wrap in in header wrap? I did it on my Dyna with a thunder header and it helped...
  7. Mar 5, 2021 at 4:24 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Tundra2 and Omohundro[OP] like this.
  8. Mar 5, 2021 at 4:32 AM
    Omohundro
    Jody
    McMinnville TN
    I would like to keep as much of the exhaust exposed as possible and think wrapping part of it would look odd.
