Welcome to Talons Garage!
Discussion in 'Talon's Garage' started by Talon2006, Sep 20, 2022.
  1. Sep 18, 2023 at 9:01 AM
    #211
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Incredibly common, but lazy of them to say there's nothing to be done about it. Buy some cheap nylon or rubber washers to stick between the cat shields, the skid plate and the crossmember, and you're going to get rid of it.
    txtundra311[QUOTED] likes this.
  2. Sep 18, 2023 at 9:26 AM
    #212
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    You may also need to install a thin separation between the cat plates and the trd skid plate and or where it contacts the frame. I added rubber between all contacts points and this fixed the noise issues.
    txtundra311 and RusPro21 like this.
  3. Sep 18, 2023 at 9:42 AM
    #213
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    IMG_1513.jpg IMG_1513.jpg IMG_1513.jpg 23 Platinum, just got it installed, easy install, great company, fast shipment, went with the steel skid plate instead of the Aluminum one, just going to change the M-8 Allen head bolts to Hex head.
  4. Sep 18, 2023 at 10:24 AM
    #214
    machd08
    machd08 New Member
    CLARENCE
    You will use all 4 on the front. I had to read and re-read the install instructions, now gotta go out and correct mine.
    1. Install the front part of the engine skid plate first. The two threaded holes on the front will line up with two threaded holes on the radiator support. Two round aluminum spacers will go between the shield the radiator support on each hole.
  5. Sep 18, 2023 at 10:41 AM
    #215
    Talon2006
    Talon2006 [OP] New Member Vendor
    The other BIG thing I have seen, is property tightening of the TRD pro plate.
    https://www.tundras.com/threads/2020-trd-pro-skid-plate.92186/
    https://www.tundras.com/threads/annoying-sound.88582/
    Bergy24 and txtundra311[QUOTED] like this.
  6. Sep 19, 2023 at 3:35 AM
    #216
    txtundra311
    txtundra311 New Member
    Why didn’t they come with them as part of the install? This is so annoying to have it installed per instructions at dealer which results in tons of squeaking noises, and then go back and install proper parts they should’ve included in the first place. Great shield but no customer wants to have creaking noises all over his truck, this is common sense.
  7. Sep 19, 2023 at 3:37 AM
    #217
    txtundra311
    That was first thing i mentioned and they showed me exactly where noise is coming from by pressing at certain points on the shield.
    Please include nylon washers for future customers so they dont have this issue, hopefully dealer doesn’t charge me to go back for third time and install those washers.
    What size washers are needed ?
  8. Sep 19, 2023 at 4:13 AM
    #218
    MedCityMoto
    Toyota claims the use of material between the truck and the skidplate can cause failures of some kind, though it's hard to imagine what, so they wouldn't likely do it. But if they're willing to install aftermarket cat shields then they might be, it's worth asking. But it's worth doing yourself if you can, because it's truly just a few bolts in and out, one at a time, no lifting involved, and it's done.
    Sizes I don't recall off the top of my head, probably... M8 internal diameter and 1.5" outer and at least a 1/8" thickness would do the trick, you'd need a minimum of 4 - two to go between the skidplate and cat shields, two between the shields and crossmember, and I think that's it. Washers are probably like $1 at a local hardware store, and I'd pick rubber over nylon if available for durability.
  9. Nov 3, 2023 at 9:29 AM
    #219
    iforceAZ
    iforceAZ New Member
    so I’m coming up on my first oil change. I’ve got the round hole in the skid plate to access the oil drain plug. Has anybody done an oil change with this skid plate yet? Is the oil actually going to shoot out that hole or am I going to end up with a mess everywhere?
  10. Nov 3, 2023 at 10:16 AM
    #220
    machd08
    machd08 New Member
    CLARENCE
    Yes it’s going to go everywhere, took me longer to clean everything than to change the oil. I talked to them about it, they advised that I use fumoto valve, which is why I was waiting to put one on, should have taken it down.
  11. Nov 3, 2023 at 10:54 AM
    #221
    iforceAZ
    iforceAZ New Member
    E
    Exactly what I needed to know. I’ll take it down for oil changes
  12. Nov 3, 2023 at 11:16 AM
    #222
    machd08
    machd08 New Member
    CLARENCE
  13. Nov 7, 2023 at 8:38 AM
    #223
    Talon2006
    399799248_698873428871232_69067314092378_aa350bffba149dfddbbc90d573b8d6dcbea69ccb.png
    Doing a little bed rack design today!
    Bprose, Bergy24, SAGE63 and 1 other person like this.
  14. Nov 8, 2023 at 9:38 AM
    #224
    MedCityMoto
    "Hey, nice rack!"
  15. Nov 8, 2023 at 12:30 PM
    #225
    Talon2006
  16. Dec 5, 2023 at 1:00 PM
    #226
    tuansmith
    tuansmith New Member
    Tuan
    2023 Tundra Limited TRD-Offroad
    Will the standard skid clear any 3" lift kit? Or do I need to select the trd 3" lift option?
  17. Dec 5, 2023 at 2:42 PM
    #227
    machd08
    machd08 New Member
    CLARENCE
    You need to get the one for 3” lift, thats what I had to do.
    tuansmith[QUOTED] likes this.
  18. Dec 13, 2023 at 9:18 AM
    #228
    Talon2006
    It will not, we are having a few issues with the TRD Pro 3" lift front skid, and are working those out.
    We are considering doing a change that will let the skid go above the sway bar.
  19. Dec 28, 2023 at 10:45 AM
    #229
    Talon2006
    CFD375AA-8E76-4CD5-8E03-04B0A40A4A27.jpg Little something my wife made earlier today! This doesn’t include our Lexus Ford, Chevy and Nissan offerings either.
    To think I started with the 4 Runner, F-150 and Tundra!
  20. Jan 1, 2024 at 7:38 AM
    #230
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    What happened to the gas tank skid?
    Tundar the Barbarian likes this.
  21. Jan 3, 2024 at 9:11 AM
    #231
    Talon2006
    I still need to get a scan of a truck with the TRD Fuel tank mounts.
  22. Jan 3, 2024 at 9:20 AM
    #232
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    What's involved in a scan? Do you need to be hands on? If not, I'll volunteer mine! :)
  23. Jan 3, 2024 at 9:28 AM
    #233
    Talon2006
    Show up, put the truck on the lift. Chat, and let me scan it.
    Do you have the OEM TRD fuel tank skid?
  24. Jan 3, 2024 at 11:31 AM
    #234
    Aw, man! I would, if it were closer! You're in Texas, I'm in North Carolina...think that takes me out...
    Somebody local needs to volunteer!
  25. Feb 3, 2024 at 1:36 PM
    #235
    Talon2006
    Did some load testing on the bed rack today. Wife and I got ontop of it for a total load of 1260 pounds!
  26. Feb 4, 2024 at 12:01 PM
    #236
    Salescartundra
    Salescartundra New Member
    2022 black SR5
    Just picked up a tundra, and was unimpressed with the felt “skid plate”
    found you guys on here and just placed order to fix the issue
    thanks-
    grant.ducckk, Bergy24, SAGE63 and 2 others like this.
  27. Feb 12, 2024 at 3:24 PM
    #237
    Salescartundra
    2022 black SR5
  28. Feb 13, 2024 at 8:03 AM
    #238
    Talon2006
    That's Pretty!
    tundznoff likes this.
  29. Mar 8, 2024 at 8:39 AM
    #239
    Talon2006
    33B9A3A9-4EF2-41AA-9662-67E3229D4AD2.jpg 6D3203FE-891F-472B-B261-553712E5EB4A.jpg
    Lots of Tundra plates going into powdercoat today.
    How are we able to ship our parts so fast? By continuously investing back into ourselves, and keeping everything in house!
    BabyMoose, mfelton18, SAGE63 and 4 others like this.
  30. Mar 12, 2024 at 3:47 PM
    #240
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    Looks awesome and I will be ordering soon. I have a 2014 tundra SR5 can my truck be of any help for product development? I am in the San Antonio area.
    Talon2006[OP] likes this.
