Weird Trac light issue. need input
Discussion in 'General Tundra Discussion' started by stujaspermma, May 26, 2015.
  1. May 26, 2015 at 9:24 PM
    stujaspermma
    stujaspermma [OP] New Member
    California
    2011 TRD CRewMax Tundra
    As posted previously I installed a pro comp leveling kit and 34s with 18" wheels. Since I have a weird issue and have no Idea what's causing it. When I do right hand turns such as getting on a wrap around under bridge on ramp to a freeway....a small rub sound occurs from front left tire area, the truck surges some, and the "trac off" light blinks off and on. Once on the freeway everything is fine. Haven't noticed it on lefthand turns. But won't happen say in slow right hand turns in residential etc. As for the rub, seems to be little on the plastic in fender well (no bigger & shouldnt cause that....i think)Anyone have any ideas???
  2. May 26, 2015 at 9:30 PM
    Pm returned
    After market UCA's and / or VSC mod
    UCA's should work though...and less stress on steering components
  3. May 26, 2015 at 9:46 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I'm sure Sean got you hooked up via pm. Tire is rubbing UCA or front sway bar can trick the ECU.
  4. May 26, 2015 at 9:51 PM
    Def the tires rubbing on UCA's. I almost guarantee it.
