Weird question; how to make Tundra feel less ginormous?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MountainMan, Mar 2, 2024.
  1. Mar 5, 2024 at 12:01 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I'm not a hardcore off-roader, but I've driven the truck with TRD sways on this trail.
    https://youtu.be/Hia21xsWChU?si=92FdiU7Su0m_DRNx
    she did ok.
    op, also one thing, perhaps try the fancy schmancy UCAs, I bought the Icon billet UCAs and it really changed the way the truck drove, I'll most likely get the coachbuilder's steering kit.
    grant.ducckk likes this.
  2. Mar 5, 2024 at 1:34 PM
    2mchfun
    After looking back at the pics, it seems that the heavy camper shell is causing some rear sag, and that is probably part of the problem. It's screwing up the perspective from the driver's seat.
  3. Mar 5, 2024 at 3:16 PM
    Sciosh98
    Sciosh98 ¯\_(ツ)_/¯
    Stephen
    Tennessee
    2020 Black Tundra 1794 TRD
    Would that typically be enough to change the driving experience to a noticeable extent? I threw a smartcap on (200ish lbs) and haven’t noticed a change in handling at all. Granted, I do have the sway bar added to my 1794.
  4. Mar 5, 2024 at 4:02 PM
    2mchfun
    That fiberglass cap with all that glass is quite a bit heavier, my guess is nearly 300. Then, add whatever is inside it. After a long period of flexing from that weight, the springs probably lost some arch. Once you get the truck in a front up/,rear down position, it will certainly change how it feels and drives. OP could probably benefit from a Roadmaster Active Suspension HD kit to remove the squat and improve handling too. Much better than spending on a rear sway bar.
  5. Mar 18, 2024 at 9:01 PM
    Riverfisher
    Riverfisher New Member
    2022 Double cab TRD Off Road
    I hear you having made the transition from a Gen5 T4R to a Gen3 Tundra. It IS bigger (and mine has a modest lift), but it just takes some getting used to. In the first month I added some custom Rocky Mountain Pinstripes from brush on a narrow trail (4” IS a lot wider) and nearly tore the rear bumper off dropping down into a wash (departure angle oversight on my part). All good now, though. I love it, have figured out all of my angles and dangles, and it feels great both on and off road.
  6. Mar 18, 2024 at 10:34 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    It used to feel huge to drive but then my eye prescription changed a lot in a weird way. The glasses shrink everything horizontally so much I can see out every mirror simultaneously without moving my head at all. Tundra feels like a Tacoma now but the roads are all narrow strips of pavement.
    It also made most women look like supermodels but that's not helpful at all.
    Something that's always helped when there's no passengers riding along is moving the passenger seat forward so its profile lines up with the B-pillar as viewed from the driver's seat, and flip down the rear headrests. If visibility is good through all windows it can do good things. Just switching from a tonneau to a full cap does the opposite and makes the truck feel 2x bigger because when you can't see where you are the brain assumes a much larger safety factor.
  7. Mar 19, 2024 at 9:06 PM
    Gusman2424
    Gusman2424 New Member
    Get a Jeep Gladiator! Just kidding. I have 2019 Tundra ... love it.... but it's a pavement queen! Feels like driving a sofa down the road but tows like crazy. Perfect.
    My wife has a Jeep Gladiator Mojave... a beast of a truck but a little more snug for this short chubby guy. Can't beat driving on a nice day with the top down though... and probably the most capable off-road vehicle ever. Ok... maybe Range Rover or those $259,000 Mercedes SUVs!
    Cheer...
  8. Mar 20, 2024 at 5:17 AM
    TRLDD
    TRLDD New Member
    2018 Cement Tundra CrewMax SR5
    Traded my 2017 4Runner on my 2018 Tundra CrewMax. I love the size for a 1/2 ton PU. It reminds me of my F250 Crew. I've had buddies with Chevy 1/2 tons sit in it and be amazed at the size of the interior.
