Weight Distribution hitch/airbags thread
Discussion in 'Towing & Hauling' started by lotsip, Aug 15, 2018.
Does anyone rec/ air bags for hauling a 26 foot travel trailer on my 2013 5.7 Toyota Tundra?
  1. Yes, highly recommended .
    18 vote(s)
    66.7%
  2. no, not necessary.
    9 vote(s)
    33.3%
Multiple votes are allowed.
  1. Sep 20, 2020 at 11:23 PM
    #211
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You're correct. Loading your airbags after setting up the weight distribution actually adds more load on the back axle. What you need to do is set your airbags to the desired psi, and then calibrate your hitch to that height. Before hooking up the trailer in the future just add Air to predetermined psi and hook up the trailer. Loading airbags after WDH is calibrated and set up is a common mistake but it’s the wrong way to do it.
    szabo101 likes this.
  2. Sep 21, 2020 at 6:15 AM
    #212
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    WDH then airbags is what the field rep from Andersen told me at an RV show. He considered the airbags more cosmetic once the WDH was properly setup and the weight it adds to axle is negligible. If it was a lot of weight, you didn’t setup the WDH properly to begin with.
    Someone needs to the the math!
  3. Sep 21, 2020 at 6:33 AM
    #213
    Tundyfundy
    Bay Area, CA
    https://www.youtube.com/watch?v=XBZu39pQ8Gg
    somebody did the math. Rear axle weight almost doubled compared to just WDH.
  4. Sep 21, 2020 at 6:47 AM
    #214
    Tundyfundy
    Bay Area, CA
  5. Sep 21, 2020 at 7:09 AM
    #215
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    Tundyfundy...
    :monocle: Is this what you were mentioning?
    “For vehicles with air springs, air shocks or automatic leveling system, check vehicle owners manual. Unless otherwise specified, level the vehicle with the vehicle loaded as it will be when towing before setting ball height and attaching trailer.”
    I was thinking if I add airbags or summo springs it will be to support the back of the truck/suspension in case of a bump. I was planning on using the WDH to do most of the work so as not to increase the weight on the rear axle. These directions are confusing!
  6. Sep 21, 2020 at 7:10 AM
    #216
    Tundyfundy
    Bay Area, CA
  7. Sep 21, 2020 at 7:26 AM
    #217
    Tundyfundy
    Bay Area, CA
  8. Sep 21, 2020 at 7:33 AM
    #218
    Tundyfundy
    Bay Area, CA
    Yes! The concern is changing the height of the ball after calibrating WDH. You will change how the load is distributed and add more weight to the rear axle and possibly exceed your ratings. The hitch working properly is directly related to the height of the trailer and the height of the hitch ball during set up and calibration. If you do all this just to change one of those measurements with airbags then your not getting the maximum weight distribution out of the hitch. You can use airbags but make sure you calibrate the hitch to the final height of the hitch ball by inflating airbags before final calibration. As in the video I posted you can load the trailer onto the ball and then fill the airbags to roughly level the truck, then make all your final calibrations of the WDH. Once the final calibration is done you don't want to mess with the airbags.
    Sumo springs are different because they don't change the ride height. They wont increase pressure after the hitch is set up. With sumo springs you can just hook up the WDH per manufacturer recommendations as normal
    Hbjeff likes this.
  9. Sep 21, 2020 at 8:12 AM
    #219
    Dodger46
    Dodger46 New Member
    Thank you the videos really clarified what you we trying to say. I was debating the airbags because I was told they could impact the unloaded ride. Others have said not to worry it’s only 5 lbs. I was going to look into cradles.
  10. Sep 21, 2020 at 8:18 AM
    #220
    Tundyfundy
    Bay Area, CA
    I have the airlift 5000 with jounce bumper and I notice them very much when the suspension compresses. It’s more rigid the longer the upstroke of the bump, if that makes sense. It feels more rigid. If I didn’t have a travel trailer I would for sure sell them and just get some sumo springs.
  11. Sep 21, 2020 at 8:48 AM
    #221
    mountainpete
    Good job on clarifying this @Tundyfundy - I'll adjust my approach.
    Hbjeff and Tundyfundy like this.
  12. Sep 21, 2020 at 10:32 AM
    #222
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    This is the understanding I now have as well. I feel like there is so much conflicting information out there. I get that some of it is because every situation is different, especially with these automatic systems some vehicles have. I have about an inch and a half of leeway with my current ball height, so I think I will try to air my bags up to 30-40PSI and see if it's within spec. If not, I have another hole I can drop the assembly to on the shank to lower by another 1.5"
    I get the cosmetic feeling, but for me it's more than that. I noticed they make the ride quality a lot better, though I haven't tested again after adding lift with my shackles
    I had airbags on for about a week without cradles. This is my do-everything truck and I don't want to lose the articulation for the mild offroading I do. Ordered cradles the same day I installed my airlifts.
    I noticed the same thing. With my block lift in the rear I was basically sitting on the jounce bumpers when riding unloaded. I just installed Toytec shackles at 1.5" to give them more space and it's a world of difference riding around unloaded
    Tundyfundy[QUOTED] likes this.
  13. Sep 24, 2020 at 12:55 PM
    #223
    cwilbeck
    cwilbeck New Member
    My 2020 4X4 CrewMax tows 9800 pounds. We are purchasing a Winnebago 172BH with the following specs: 4000 GVWR, 3400 Dry Weight, 620 Dry Hitch Weight. Which Equal-i-zer hitch do I need?
    There will be approximately 800 pounds of passengers and cargo in the truck itself too to factor in.
    Thank you in advance!
  14. Sep 25, 2020 at 8:27 AM
    #224
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You will need the 10K Equalizer. I have the 6K Equalizer and pull 5.5K with a hitch weight around 550lbs and I'm borderline with my 6K hitch.
  15. Sep 25, 2020 at 8:28 AM
    #225
    cwilbeck
    cwilbeck New Member
    Thank you!
    Ruggybuggy likes this.
  16. Oct 19, 2020 at 12:12 PM
    #226
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Do I need a weight distribution hitch while hauling my Tacoma with this trailer?
    I got a 2018 CM, 4X4.
    Trailer Weight Specs
    • GVWR: 9,900 lb
    • GAWR: 5,200 lb per axle
    • Manufacture Capacity: 7,240 lb
    • Empty Weight: 2,750 lb
    Trailer Dimensions
    • Bed Length: 18'
    • Width Between Drive-over Fenders: 83"
    • Total Width of Trailer Including Rub Rails: 101"
    • Bed Height: 25.5"
    • Fender Height from Ground: 33"
    • Fender Height from Bed: 8.5"
    • Dovetail Length: 2'
    • Dovetail Height from Ground: 19.5"
    • Front Rail Height: 6.5"
    • Ramp Length: 61.5"
    • Hitch Height: 18"
    • Tongue Length: 53.5"
  17. Oct 19, 2020 at 12:18 PM
    #227
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I usually go with the rule that if my towing weight is over 50% of max trailering weight I use a hitch. Better to be safe than sorry
    BravoDeltaRomeo likes this.
  18. Oct 19, 2020 at 12:21 PM
    #228
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How much does the tacoma weigh? Your trailer is pushing 7500lbs when loaded right? I would do a WDH
  19. Oct 19, 2020 at 12:23 PM
    #229
    Rakso
    Oskar
    By max trailering weight you mean max towing capacity?
  20. Oct 19, 2020 at 12:25 PM
    #230
    Rakso
    Oskar
    I'll find out the weight of the tacoma this week. But looks like I'd need a WDH.
    Next question is should I buy one or rent?
    Any recommendations?
  21. Oct 19, 2020 at 12:28 PM
    #231
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Craigslist
    also, is this a 1 time tow or a regular thing?
  22. Oct 19, 2020 at 12:34 PM
    #232
    Rakso
    Oskar
    One time, weekend trip... I was just told by the trailer rental guy I wouldn't need a WDH with this trailer.
    Thoughts?
  23. Oct 19, 2020 at 12:48 PM
    #233
    Lake.Life24
    Shawn
    Upstate, NY
    Yes or anything over 5K I would use a WDH
    ColoradoTJ likes this.
  24. Oct 19, 2020 at 12:51 PM
    #234
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, that's what the owner's manual recommends, if I recall correctly.
  25. Oct 19, 2020 at 12:51 PM
    #235
    timsp8
    NY
    How far are you towing? If it’s just across town, you wouldn’t need one. If it’s across the country, one would help. Is your truck stock?
    Hbjeff likes this.
  26. Oct 19, 2020 at 12:57 PM
    #236
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    One time in town I wouldn’t sweat it
    ColoradoTJ and timsp8 like this.
  27. Oct 19, 2020 at 2:52 PM
    #237
    Rakso
    Oskar
    Yeah stock.
    200 miles round trip.
  28. Oct 19, 2020 at 3:31 PM
    #238
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Don’t speed and you’ll be fine for 1 trip imo. Not worth the money
  29. Oct 19, 2020 at 3:42 PM
    #239
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    I tow my tractor without a WDH a couple times per year without any issues but its only 140 miles or so each way. Around 7500#. I drive like a grandma, keep it under 65mph. The last trip was through our latest 40-50mph windstorm (whoops) and even then, zero issues.
    I have a WDH for my camper though because its a giant wind sail with the aerodynamic prowess of a cinder block. Itll yank the truck around pretty good if its windy out at all.
    If you take it easy on the trip you should be able to manage it just fine. That said, a WDH will make it more stable if that gives you peace of mind.
    kittyhawk likes this.
  30. Oct 19, 2020 at 5:24 PM
    #240
    timsp8
    NY
    Yeah I wouldn’t waste money on it for a one time 200 mile trip. Just don’t try to drive fast. Keep it at or under 55.
