Weight Distribution hitch/airbags thread
Discussion in 'Towing & Hauling' started by lotsip, Aug 15, 2018.
Does anyone rec/ air bags for hauling a 26 foot travel trailer on my 2013 5.7 Toyota Tundra?
  1. Yes, highly recommended .
    18 vote(s)
    66.7%
  2. no, not necessary.
    9 vote(s)
    33.3%
Multiple votes are allowed.
  1. Mar 30, 2020 at 3:50 PM
    #121
    07KingTundra
    07KingTundra New Member
    Scott
    07 Tundra Limited
    King, Icon, General
    that is exactly what I was going to say. from the research I have done, I have found even pretty long-travel prerunners with rear leaf springs running the 2445 bags and the daystar cradles. they seem like the way to go if you tow with your truck.
  2. Apr 19, 2020 at 9:11 AM
    #122
    BarcelonaSX
    BarcelonaSX New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    Does anyone have experience with running firestone bags with a 1” shackle lift in rear. Will they work as is or do I need a spacer if some kind? Thanks.
  3. Apr 19, 2020 at 2:18 PM
    #123
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    My suspension lift consist of a AAL, 3 inch block and a 1 inch shackle and I had to use a 2 inch spacer. So I would say no on the 1 inch spacer. I would bolt it up first before buying the spacer. If by the slim chance you do need it, I think there about 50 dollars.
    BarcelonaSX[QUOTED] likes this.
  4. Apr 19, 2020 at 3:14 PM
    #124
    Brandenmontoya10
    Brandenmontoya10 HE > I
    Branden
    2011 Tundra Charcoal Grey
    Hey y’all! So we tow our 37’ 2018 Highland Ridge Light 312BHS with our V8 5.7L tundra.
    Roughly 7,500-8,500max
    I bought the tundra years ago with a 3” lift in the front and no lift in the back.
    This creates a really bad sag when the trailer is hooked up. I have a HUSKY TS weight distribution hitch/bars. I understand that bags and WD hitches do two very different things. But does anyone have experience with this type of lift?
    I am considering putting bags (Firestone 2445) in the rear to level the truck, re adjusting the hitch per manufacturer set up to the new level, and then leaving my bags at the level whether towing or not.
    Also, I know this trailer is heavy for this truck. We only campsite hop with this truck. If thetrailer needs to be towed the 300 miles homewe would hire or use our families truck.
    Thanks so much!
    yoshi82 likes this.
  5. Apr 19, 2020 at 6:58 PM
    #125
    JoeL A.
    JoeL A. New Member
    JoeL
    2019 Tundra Crew Cab 4x4 - TSS Off Road - Quicksand
    Good Evening..
    Im planning to buy this but i would appreciate your thoughts/comments pls..
  6. Apr 19, 2020 at 7:19 PM
    #126
    ToastyStew
    ToastyStew Tactically Compliant
    Grand Junction, CO
    2008 Tundra SR5 DC
    OME HD Coils, Airlift Airbags, 16K Warn winch, Warn Trans4mer Brsuh Guard, 305 65r18 Nitto, LED light bar, Hella Fog lights, LED Fog Light Bulbs LED headlights, Leer Topper, Basalt Gray Raptor Liner, taillight guards, step bars coming soon
    Joel I have had that air lift 5000 package for 10 years now. Now problems at all.
    JoeL A. likes this.
  7. Apr 19, 2020 at 7:28 PM
    #127
    JoeL A.
    JoeL A. New Member
    JoeL
    Good to hear that @ToastyStew .. also a follow-up question.. is there a big difference once u installed it as far as comfy ride ? i have a friend that once he installed an airlift... ride was not the same ..
  8. Apr 19, 2020 at 7:31 PM
    #128
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    Joel check yo see if these bags has the internal jounce inside the bag. From what I have read if they do i won’t buy them. Folks on here say it makes for a harsh ride. Just my opinion
    JoeL A. likes this.
  9. Apr 19, 2020 at 7:37 PM
    #129
    JoeL A.
    JoeL A. New Member
    JoeL
    actually they do have that Jounce inside the bag .. :(:(
    do you have any suggestions ?
  10. Apr 19, 2020 at 7:44 PM
    #130
    JoeL A.
    JoeL A. New Member
    JoeL
    I saw some comments this is way better than AirLift i posted awhile ago..
  11. Apr 19, 2020 at 7:44 PM
    #131
    jeremyd
    NV
    2014 SR5 CM 4X4
    I'm sure someone will chime in, but your right that bad boy does look heavy ! Lol
    I only have air bags cause I'm only towing 3000 pounds
    ColoradoTJ likes this.
  12. Apr 19, 2020 at 7:54 PM
    #132
    Creatures 1982
    2017 SR5
    I can’t speak about air lift but I think most on here prefer ride rites by Firestone. That’s what I have had for 3 years and I would recommend them.
    JoeL A. likes this.
  13. Apr 19, 2020 at 7:57 PM
    #133
    JoeL A.
    JoeL A. New Member
    JoeL
  14. Apr 19, 2020 at 7:57 PM
    #134
    jeremyd
    NV
    2014 SR5 CM 4X4
    The ride rites work great unless your a serious offroader.. As pictured with 25 psi.
    Creatures 1982 and JoeL A. like this.
  15. Apr 19, 2020 at 8:03 PM
    #135
    JoeL A.
    JoeL A. New Member
    JoeL
    jeremyd likes this.
  16. Apr 19, 2020 at 8:05 PM
    #136
    Creatures 1982
    2017 SR5
    One more thing buy daystar cradles they are a must for adding airbags. They let the bags move freely up and down when lifting truck for service.
    Might help Jeremy d also
    JoeL A. likes this.
  17. Apr 19, 2020 at 8:10 PM
    #137
    jeremyd
    NV
    2014 SR5 CM 4X4
    Definitely have to keep an eye open when in for service..Last time it was in the shop for tires, I simply told them " don't rip my bags" And they proceeded to use floor jacks..
    JoeL A. likes this.
  18. Apr 19, 2020 at 8:22 PM
    #138
    JoeL A.
    JoeL A. New Member
    JoeL
    This is the one i googled...
  19. Apr 19, 2020 at 8:34 PM
    #139
    ToastyStew
    Grand Junction, CO
    2008 Tundra SR5 DC
    No, I can't remember a big difference when unloaded - I keep it at 20 psi ( with the topper). Maybe just a smidge stiffer. When I put the airbags on I also put on old man emu heavy duty front coil overs on, so the whole suspension got stiffer. When loaded I fill to level and depending on the weight you will feel better control overall. I do have a topper on all the time though and have never not had a topper. If you don’t have any weight and run it at the lowest recommended psi (I think 10) I don’t think you would notice a difference. At 60 psi unloaded, yes....your kidneys will fall out.
    JoeL A. likes this.
  20. Apr 19, 2020 at 8:45 PM
    #140
    JoeL A.
    JoeL A. New Member
    JoeL
  21. Apr 19, 2020 at 10:26 PM
    #141
    Brandenmontoya10
    Branden
    Hopefully! Lol
  22. Apr 19, 2020 at 11:27 PM
    #142
    Well, I think there’s a couple reasons why.
    So how attached are you to the truck or the camper?
    One needs to go.
    Your hitch weight empty is maxing out your truck. The leveling kit is not doing you any favors with a huge trailer like that.
    I actually wouldn’t pull a TT that long with my 1 ton Duramax. A 5th wheel that long, no problem.
  23. Apr 19, 2020 at 11:37 PM
    #143
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I think the gross trailer weight is with fluids and everything. Unless he travels with full tanks trailer should be 8000 plus gear. Probably still close to 8500 lbs. Get airlift 5000. They give you an additional 5000 lbs support. A word of advice, if your using the airbags as part of your active suspension when unloaded the ride will suffer pretty bad. Ideally the airbags wont be activating unless theres a load. I would say level the rear with shackles or blocks and adjust the WDH to the new truck height. THen when you tow, load the trailer, and then inflate the bags to bring you back to level.
    jeremyd and ColoradoTJ[QUOTED] like this.
  24. Apr 19, 2020 at 11:41 PM
    #144
    I believe the max tongue weight is ~990 lbs on Tundras. That’s what he is maxed out on.
    jeremyd and GODZILLA like this.
  25. Apr 19, 2020 at 11:58 PM
    #145
    Tundyfundy
    Bay Area, CA
    Oh I see what your saying. THe tounge weight is for the fully loaded trailer so hes under that. Tundra doesnt have a max tongue weight persae. THe manual says the tongue weight should be 9-11 percent of trailer weight(for bumper pull and varies for fifth wheel etc...). So if you can tow 10,000lbs max tongue weight allowed is 900 to 1100 lbs. At 8500 Lbs his tongue weight shouldnt be above 900lbs which is technically still in in his capacity. Close but technically still workable. OP def needs some bags!
    Another thing to consider is tongue weight can vary depending on how the trailer is loaded. Only way to truly know is to use a scale. I bet that the trailer isn't loaded ideally adding to that number.
  26. Apr 20, 2020 at 12:02 AM
    #146
    Tundyfundy
    Bay Area, CA
    Looks like they are calculating hitch weight at 11 percent of fully loaded trailer
  27. Apr 20, 2020 at 1:21 AM
    #147
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    If those are the specs for the trailer. it's a heavy one for the tundra. Looking at your hitch set up, doesn't look quite right. Whats the height of the ball on the truck with nothing attached? Also whats the height of the trailer coupler with it sitting level?
    You said the truck has 3in. lift in the front and none in the back, weird. Anyhow if thats the case the hitch is adjusted wrong either way. Just by looking at the pic's your ball should be lower on the shank, I would suggest re-reading the first few steps of the installation procedure for the hitch. You can get a-lot closer to level.
    -Jason
  28. Apr 20, 2020 at 3:43 AM
    #148
    msmmce1
    msmmce1 New Member
    The hitch is not set up correctly. I have the exact same hitch, if you have the 1200lb bars it should be able to level the truck without bags. If you use the set-up procedure in the manual and follow it exactly it should be able to level the truck and trailer.
  29. Apr 20, 2020 at 4:15 AM
    #149
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Repeating what I said in the other thread you started...
    You don't have a "Lift" per say...you have a leveling kit as you already know, lifts the front to level out the rig with the rear. Leveling a truck and then using it for tow duty only makes the rear sag seem worse. My advise is shackle up the rear to put some "rake" back into the suspension, or remove the front spacers(leveling kit). Baring this your only recourse is to set your WDH...maybe fine tune a little with the bags and live with the squat.
  30. Apr 20, 2020 at 5:30 AM
    #150
    I could have sworn my 2012 CM had a maximum TW of 950 lbs load distributed. It could have been on the hitch, not the owners manual.
    Could be wrong, and I don’t have a Tundra to verify the hitch.
