Weather stripping on roof keeps coming off.
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Californian, Oct 6, 2020.
  1. Oct 6, 2020 at 10:32 AM
    The Californian
    The Californian [OP] Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Anyone else have an issue with the weather stripping on your roof coming off whenever you go through a car wash? There’s a junction where it connects to another piece right above the rear door (Crewmax), and it keeps popping out and flopping around like one of those “Wacky Wavy Inflatable Arms Man” things. I went to the dealership immediately after it happened the first time, and the advisor gave me a long analogy about the Space Shuttle Challenger explosion, and how it was a series of perfect coincidences that caused it to happen - and how that’s what causes this to happen as well. He said it should never happen again, and he was wrong. It’s going to be at the dealership for 10K miles service on Saturday, and I’ll bring it up then - I’m just curious if anyone else has had this issue too. Here are come up close photos of the junction, I didn’t take any pictures of the whole strip - but can if anyone wants to see it.
    yoshi82 likes this.
  2. Oct 6, 2020 at 10:34 AM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    yes, just happened the first time a couple weeks ago. The small weather-stripping between the windshield and roof was also coming off and flopping against the roof -- luckily no scratches. I'm nearly due for my 5k service, so I plan to bring it up then.
  3. Oct 6, 2020 at 10:54 AM
    The Californian
    Eric
    Glad I'm not alone, I also noticed that the weather stripping around my drivers door was peeling away, looks like some kind of foam adhesive behind it, there's no adhesive on the roof though.
  4. Oct 6, 2020 at 11:06 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    It has happened 2x to me also on the roof. Only happens when I go through an automatic car wash. I go through a hand wash place now so no more problems.
    The automatic car wash was pretty soft also.
    dorton likes this.
  5. Oct 6, 2020 at 11:09 AM
    timsp8
    NY
    I had the issue before installing roof tracks. I used some loctite weatherproof glue to fix it.
    yoshi82 and The Californian[OP] like this.
  6. Oct 6, 2020 at 11:36 AM
    The Californian
    Eric
    Unfortunately, I don't have any hand wash places around me - and just haven't had the time to wash it myself lately. Regardless, I should be able to go through an automatic car wash without this problem.
  7. Oct 6, 2020 at 11:37 AM
    The Californian
    Eric
    That's what the dealership told me they would do as well, did you just loctite it at the junction? Not the whole strip, right?
  8. Oct 6, 2020 at 11:49 AM
    timsp8
    NY
    I put a thin line down for a foot or so if I remember right, and then a little more at the end.
    The Californian[OP] likes this.
  9. Oct 6, 2020 at 11:51 AM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    Same happen to me, the problem with mine is that the Weather Strip on the driver side came off. Need to order a new one i guess
  10. Oct 6, 2020 at 12:55 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The loose roof molding problem is not new, but was supposed to have been solved by a TSB years ago. Required new molding part numbers, etc., etc. Sometimes the magic works.
  11. Oct 6, 2020 at 5:27 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Happened to my 2019 a few weeks ago... has never happened to my 2017.
  12. Oct 6, 2020 at 8:27 PM
    The Californian
    Eric
    Thanks, this will be a good thing to show to the advisor - even though it’s for previous years.
    JohnLakeman[QUOTED] likes this.
  13. Oct 14, 2020 at 11:10 AM
    The Californian
    Eric
    So the dealership looked at it during my 10K service; all they told me was that they had ordered the part and that the parts department would call me when it arrives. I didn't even think to confirm that it'll be covered under my warranty, but did notice there were prices on my service report.
  14. Oct 14, 2020 at 11:31 AM
    timsp8
    NY
    I remember seeing prices on my warranty repairs before. The only one that matters is the price at the bottom.
  15. Oct 20, 2020 at 8:43 AM
    The Californian
    Eric
    Toyota replaced both trims, and the trim around my drivers door window. No hassle at all.
    GODZILLA likes this.
  16. Oct 20, 2020 at 9:03 AM
    ejhenry001
    ejhenry001 New Member
    I had the same thing happen on my 2015 - brushes in the car wash took it right off. Had to order another from dealer at $80+. I glued the new one in and so far still there.
  17. Oct 20, 2020 at 9:51 AM
    timsp8
    NY
    Did they glue it or secure it in any way? If not, it might come off again. Might want to put a little weatherproof glue under it.
  18. Oct 20, 2020 at 10:04 AM
    The Californian
    Eric
    The tech did note the cause of the issue was "insufficient adhesive"; so I'm hoping they used someting. I'll check, and put some loctite if there's nothing.
    timsp8[QUOTED] likes this.
  19. Jul 31, 2021 at 12:54 PM
    seattle1218
    seattle1218 New Member
    2021 CrewMax, Cement Gray
  20. Jul 31, 2021 at 12:55 PM
    seattle1218
    This has happened twice to my 2021 CrewMax
  21. Jul 31, 2021 at 1:15 PM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    This happens to me everytime I go through the car wash. It a really annoying.
  22. Jul 31, 2021 at 1:36 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I've just left them off...the amount of times I'm ever on top looking or anyone else for that matter looking, is too low for me to remotely care...weight reduction and speed grooves are what it gave me doing nothing about it...Ha! :homer:
    Tundratoofun likes this.
  23. Jul 31, 2021 at 2:15 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I see a trend here sure sounds like God is telling folks to stop using automatic car washes.
  24. Jul 31, 2021 at 2:30 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Noticed one side almost flapping off after stopping at a grocery store, I peeled both up and Gorilla glued them down, that was maybe 2 years ago. Have never gone through a car wash.
  25. Aug 1, 2021 at 3:52 PM
    wdw67
    wdw67 New Member
    2021 trd pro
    it happens to tacoma to
  26. Aug 1, 2021 at 6:41 PM
    jimmycapp
    jimmycapp New Member
    Just replaced mine today. Noticed it popped out a few times. Last time the whole piece was gone. 9k miles. Just ordered one off trdshop. Hope it lasts longer than stock.
  27. Aug 1, 2021 at 7:03 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    This happened on my 2008. I have purchased new weather stripping for it and will affix with 3M VHB tape.
  28. Jan 2, 2022 at 9:46 AM
    scottb2240
    scottb2240 New Member
    Scott
    2015 Tundra SR5 Black
    For those of you that have glued the strip down, how did you prep the paint? Did you just clean it with some alcohol wipes?
  29. Jan 3, 2022 at 4:36 AM
    Hostage81
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    I had 5 new tundras and this happened to all of them going through the car wash.
    I removed the entire affected area weather stripping from front to back. I cleaned lightly with soap and water and used alcohol wipes for final cleaning. Then I used clear double sided 3m tape from front to back and placed the stripping ontop and applied pressure. I never had this happened again and Im a guy that goes through the wash 3-5 times a week because I have a membership.
    Im not a fan of glue because I tried it with the first Tundra and it didn't work at the car wash and it didn't sit right with me to glue stuff together.
    I hope that helps and good luck
    icodeintx and Barrett50 like this.
  30. Jan 3, 2022 at 1:10 PM
    scottb2240
    Scott
    Did you use the standard double sided or high bond or very high bond? Or was it something else?
