Waxes
Discussion in 'Detailing' started by Keepontrying, May 19, 2022.
  1. May 19, 2022 at 6:03 AM
    Keepontrying
    Keepontrying [OP] New Member
    da Burgh
    2022 TRD OR, CM 6.5 ft. bed, Blueprint (aka Black, Blue or Purple)
    Any suggestions for a wax that will sheen the water off the hood and not cause the water to bead? Water spots get baked on the paint when the sun finally shows up in western pa. I have a 2022 tundra in blueprint. Any suggestions are appreciated.
    Thanks,
    Ron
  2. May 19, 2022 at 6:10 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I've used Collinite 845 in the past with good results. For sheer protection you should consider getting a ceramic coating. All my vehicles are now coated with Opti-Coat Pro Plus.
  3. May 19, 2022 at 10:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have a black truck and have had great results with Megs Ultimate, then a top coat of beadmaker. Keeps the paint dark, glossy and protected for 4 months. Does bead, but it is protected and water or stains do not etch into the paint.
    RitcheyRch likes this.
  4. May 19, 2022 at 11:27 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
  5. May 20, 2022 at 7:13 AM
    briarpatch
    briarpatch New Member
    A ceramic coating would be your best bet, although it is still possible to get water spots with one. The benefit is that they do not etch into the paint as easily as with a non-coated vehicle. The key to any protection is proper maintenance. I'm a firm believer in topping any LSP periodically. I currently have a spray coating (Dr Beasleys LS10), which gets topped monthly with Sonax Ceramic Detailer. Water spots have not been an issue.
    Saltyhero13 likes this.
