Wax
Discussion in 'Detailing' started by atlpinoy08, Mar 20, 2018.
  1. Mar 20, 2018 at 3:46 AM
    atlpinoy08
    atlpinoy08 [OP] Everything happens for a reason
    Rob
    Land of ATL
    2016 Gray SR5 TRD 4x4 5.7liter Tundra
    What wax do you guys recommend for light scratches throughout truck. Thanks for the feedback!
    SouthBoundSteve likes this.
  2. Mar 20, 2018 at 5:57 AM
  3. Mar 20, 2018 at 6:09 AM
    15whtrd
    15whtrd Mr. Blonde
    For a good off the shelf wax I suggest Maguires NXT 2.0 tech wax. Give the truck a good cleaning along with a Claybar to remove the contaminants. I use Maguires light swirl remover. They have a more professional version in the bodywork section at the auto parts store. It comes in a tan bottle. They have numerous different grits depending on the severity of your scratches. Always finish with the finest grit or a glaze. Then a wax or sealant. Or both. I’m no professional but this is what I do, my truck turns out pretty damn nice. I’m sure you can get even better advice from Steve.
  4. Mar 20, 2018 at 11:27 AM
    blizz86
    blizz86 New Member
    can you recommend a few good quality towels for regular drying after wash, for polish removal, for wax buffing?
    I've been using these kind of all around https://www.amazon.com/gp/product/B01CW1R8VI/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
  5. Mar 20, 2018 at 11:59 AM
    blizz86
    blizz86 New Member
    I have a water softener for my interior water... does it make much of a difference?
  6. Mar 20, 2018 at 12:43 PM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    what does the water softener do/not do?
  7. Mar 20, 2018 at 1:42 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
  8. Mar 20, 2018 at 4:08 PM
    15whtrd
    15whtrd Mr. Blonde
    The downside is if you use warm water the hot water tank is still full of soft water. Hopefully you either have a tankless or you use cold only when you shut the softener off. Either way it sounds like you’re having better results.
  9. Mar 20, 2018 at 4:24 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Should I plan to wax my truck this summer in top of using Hydro2?
    I had planned to clean it well, ironX, clay bar, and use car pro eraser before doing a coat of the hydro2. Any recommendations other than my plan? I considered ceramic application but I don't have the time, skill, patience, or cash to do any paint correction.
  10. Mar 20, 2018 at 4:37 PM
    Pudge
    CT
    Thanks @SouthBoundSteve, you're the best buddy. I'll pick up some of that soap. Seems to be just what I need. I will do some research about doing a polish, I really should do it instead of being so lazy.
    Oh and 25% off at detailedimage the next 2 days :)
    Maybe I'll get some new clay and lube too. I do have a new mother's clay bar though ...
  11. Mar 20, 2018 at 4:41 PM
    TheBeast The Beach
    NewImprovedRon and Prostar 190 like this.
  12. Mar 20, 2018 at 4:44 PM
    Pudge
    CT
    You're going to LOVE the defenders. Well I sure as hell hope you do after all I have talked them up so much.
  13. Mar 20, 2018 at 4:51 PM
    Pudge
    CT
    Yeahhhh buddy!
  14. Mar 20, 2018 at 5:10 PM
    I like this also.
    Pudge likes this.
  15. Mar 20, 2018 at 5:22 PM
    atlpinoy08
    Rob
    Land of ATL
    Steve, thanks for the feedback! Haven’t gotten to a regular washing routine yet with the truck. When I do it probably gonna be every other weekend like I did my accord! Like I said before when I bought the truck it was used. They tried to cover it up with a light wax but when it rained I could see every scratch known to man all over the truck. I usually do all my waxing by hand but recently bought a little ryobi buffer. Gonna try products you recommended! I use microfiber towels as well. Let you know once this Georgia weather makes up its mind if it’s gonna be cold or hot!
    Pudge and SouthBoundSteve like this.
