Water Pump
Discussion in '1st Gen Tundras (2000-2006)' started by 1kTyy_1, Jan 10, 2022.
  1. Jan 10, 2022 at 5:15 PM
    1kTyy_1
    1kTyy_1 [OP] New Member
    2001 Toyota Tundra SR5 V8 4.7L 2WD
    Is it best to go head and spend $100 on Asin water pump from rock auto? Already got Asin fan clutch and Frostbte full aluminum radiator. Price is nothing, just want to know if it would be the same quality as the $40 one?
    Already replaced thermostat and both hoses.
  2. Jan 10, 2022 at 5:19 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I personally always try to use Toyota Genuine parts. They tend to be more expensive but last longer and are less likely to fail prematurely (in my experience). However, you have to do what you have to do if your on a budget. I am not familiar with Asin products. I know I didn't answer you question but figured I'd throw in my 2 cents.
  3. Jan 10, 2022 at 5:43 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    You can get an Aisin water pump and timing belt kit from Rock Auto, just a thought. https://www.rockauto.com/en/moreinfo.php?pk=3290529
    The Aisin water pump is the quality of what came on your truck from the factory. I'd spend the money for it.
    Rock Auto even has a 5% off code on the forum here: https://www.tundras.com/threads/rockauto-com-discount-code-expires-february-24-2022.98550/
    Aisin is a member of the Toyota group and the OEM manufacturer for many of our parts.
  4. Jan 10, 2022 at 5:52 PM
    1kTyy_1
    Thank You for the help. Just ordered.
    des2mtn[QUOTED] likes this.
  5. Jan 10, 2022 at 6:18 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    Good to know, thanks. :D
    jerryallday and des2mtn[QUOTED] like this.
