Water leaks at roof of cabin of 22 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by Mezadgo, Aug 4, 2022.
  1. Aug 4, 2022 at 11:22 AM
    Mezadgo
    Mezadgo [OP] New Member
    Elias
    2022 Red SR5 Tundra
    Has anyone had any leaks when it rains into cabin coming from bed light?
    My truck is a 2022 SR5 Tundra.
    Every time it rains it leaks into cabin. I have stains of water coming in, and dealer keeps saying its from window.
  2. Aug 4, 2022 at 11:31 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    The 3rd gen Tacoma's had this issue. Hopefully yours is just a one off. Sorry, OP.
    Robbsolid and Taco-Spike like this.
  3. Aug 4, 2022 at 11:35 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have the dealer close the window then spray it with a garden hose. Then have them fix it under warranty.
    Taco-Spike likes this.
  4. Aug 4, 2022 at 11:43 AM
    Taco-Spike
    Two Trucks
    They eventually issued a recall for this but it took years for them to do it.
    I never had an issue in my Tacoma but got the recall done anyway
  5. Aug 4, 2022 at 11:52 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Back to dealer and have them fix it??? Yet another thing on the list?? Best of luck.
  6. Aug 4, 2022 at 11:56 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Several have had leaks around the drive side grab handle, related to the sunroof pan/drain. Ive not seen this one yet. You need to notify your dealer.
  7. Aug 4, 2022 at 12:35 PM
    trazerr
    trazerr New Member
    Oregon
    Yup, I got the recall done as well. I live in the PNW and didn’t want to risk it.
    Taco-Spike[QUOTED] likes this.
  8. Aug 4, 2022 at 8:09 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Wow, the hits keep on coming. Hope you can get the dealer to act. If not, call Toyota and get a case manager assigned. I've done it twice so far. My truck had been in the shop for about 5 weeks and a case manager got some heads rolling and had my truck repaired and back 3 days later.
    Good luck!
  9. Aug 4, 2022 at 9:09 PM
    Robbsolid
    Robbsolid New Member
    Puyallup, WA
    2022 LTD HV WCP.
    Was a wide known Tacoma issue, probably will have a TSB
  10. Aug 15, 2022 at 8:58 AM
    Mezadgo
    Elias
    2022 Red SR5 Tundra
    Unfortunately this is one of many other issues this truck has had!
  11. Aug 15, 2022 at 9:06 AM
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Yep, not a single regret on passing on my '22 build. Maybe I'll revisit in '24 if the the bugs are ironed by then...
    Unfortunate that you're dealing with this!
  12. Aug 15, 2022 at 9:28 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    My brain keeps reading your original post and it keeps saying, "Sooooooo what?"
    Your dealer says it's the window. Fine. Whatever. Either way they should see the problem and immediately want to fix it. Windows aren't supposed to leak when closed. So, unless they're claiming you're leaving the window open, then they should move to fix it.
    Also...not to sound like an a-hole, I promise...it might be worth giving your dealership service writer & technician a reminder on basic hydrology. Water flows down and almost always follows the path of least resistance. If it were leaking from the window, it would flow down the window. Not flow up into the headliner like that. Sure, there might be some "soaking" of the headliner, but not like what you've pictured.
    Any person can see that it's likely coming from the brake light...which is above the headliner. Any person with a water hose can test this. I'm sorry, but your dealership sounds dumb.
    Side note: I'm assuming you don't have a sun roof since it's an SR5. As a result, when you say "window" I'm also assuming that your dealership is referring to the back window and not trying to blame this on a sunroof.
