Water leak
Discussion in '1st Gen Tundras (2000-2006)' started by Kolya CM, Feb 5, 2025.
  1. Feb 5, 2025 at 3:54 PM
    Kolya CM
    Kolya CM [OP] New Member
    Kolya
    2000 Red Tundra SR5
    There is water coming in from in between the seem that connects the rear window to the cab on the top. The carpet on the drivers side is getting wet somehow to but I can't find any leaks over there. Can anyone help me out on how to fix these problems? I've gotten a quote on a professional job finding and fixing leaks but if possible I'd like to do it myself.
    Thanks!
  2. Feb 6, 2025 at 8:39 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    You could try to run a silicone bead around the rear window .
  3. Feb 6, 2025 at 9:21 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Sure it is the window leaking and not the 3rd brake light? 3rd brake light has been an area that has had some leaks.
    Remove it, install a new seal and then reinstall. Id try that first unless you are sure it is the window. If it is the window, get a windshield shop to fix, remove it, new seals, reinstall.
  4. Feb 6, 2025 at 9:28 AM
  5. Feb 6, 2025 at 1:53 PM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    Since it's the rear window I'd start with the brake light seal.
  6. Feb 6, 2025 at 1:57 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
