Water in Tail light? Anyone had this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by divinguy, Feb 26, 2021.
  1. Feb 26, 2021 at 6:48 PM
    divinguy
    divinguy [OP] New Member
    P@t
    2017 Tundra CrewMax Platinum
    Bull bar w/integrated light bar. NFAB Podium Running boards Vision Fury Wheels Front window Tint Dual DVD Players Century Canopy w/integrated lock, and Thule Crossbars
    Hello all,
    I was wondering if anyone else has gotten "standing" water in their tail light.
    Everything I've found says to let the tail light dry as much as possible. But, while I was trying to figure out the root cause, it looks like the bulb didn't seal to the light correctly.
    Which was okay, that's my bad for not putting it on tight enough.
    However, when I tried to place the bulb back in correctly, it wouldn't flush, or seal all the way.
    These lights are the Smoked OEM Style.
    Everything inside the tail light seems to match the bulb assembly, but it just won't seem to get all the way in there.
    Has anyone else had this sort of trouble getting a bulb to seat?
    Thanks in advance, if anyone has any thoughts.
  2. Feb 26, 2021 at 6:51 PM
    divinguy
    P@t
    I actually don't think so, I pulled the tail light, and section that had water in it, is the section where the bulb wasn't seated correctly, and now won't seat.
  3. Feb 26, 2021 at 6:55 PM
    divinguy
    P@t
    Yeah, all three bulbs have their gaskets, I checked the seam on the light's lens too. I am certain it just wasn't seated correctly, and now it *really* won't seat correctly.
  4. Feb 26, 2021 at 6:56 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Is it loose when you insert the bulb and twist, or can't you twist it to get it tight?
  5. Feb 26, 2021 at 7:01 PM
    divinguy
    P@t
    The part that holds the bulb, with the tabs won't totally go into the tail light. They line up and all, but I can't seem to get them to sit flush so that I can twist to complete the seal.
  6. Feb 26, 2021 at 7:07 PM
    TILLY
    Massachusetts
    Do you still have your old tail lights to see if the notches are exactly the same?
  7. Feb 26, 2021 at 7:10 PM
    divinguy
    P@t
    Yeah, I'm going to dig out my originals tomorrow to check them out. They're in my "take-offs" box in the rafters.
  8. Feb 26, 2021 at 7:12 PM
    TILLY
    Massachusetts
    Let us know how you make out.
    divinguy[QUOTED][OP] likes this.
  9. Feb 27, 2021 at 8:52 AM
    2mchfun
    Silicone is an option.
