Water/gas sloshing sound when driving
Discussion in '2.5 Gen Tundras (2014-2021)' started by aturp34, Jun 28, 2019.
  1. Jun 28, 2019 at 7:19 AM
    aturp34
    aturp34 [OP] New Member
    2018 mesquite brown tundra 1794 TRD
    Stock. For now
    I have a 2018 Tundra and just noticed that I can hear a water sloshing sound coming from behind me when I turn. I only notice it if the windows are up and stereo turned off. Could it be gas moving around in the tank? I have about 1/4 tank left right now. thanks
  2. Feb 21, 2020 at 6:29 PM
    Fire13
    Fire13 New Member
    2018 Tundra Crewmax
    Hi Aturp34, did u ever figure out what the sound was? I have the exact same sound when I start or stop and turn like there is water sloshing and almost grinding like ice is in there? Sounds coming from passenger side I believe. I also have a full tank of gas so that isn’t the problem. Thanks for any info!
  3. Feb 21, 2020 at 6:41 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
  4. Feb 22, 2020 at 6:53 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    On Fords this can happen if the 3rd brake light leaks, water gets trapped in the cab corners. Not sure if tundra seals those or not.
  5. Feb 22, 2020 at 7:38 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Could always try putting a camera around that area if you have one. Or put someone in the bed and see if they can hear it out there. Incidentally, what size tank? I have the 38gal and have never heard it at any fuel level. Maybe it has thicker walls than a standard tank, made of different materials, baffles, etc..., tho.
  6. Feb 22, 2020 at 9:23 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    I have this as well. 99% sure it’s the gas tank.
    Nothing to worry about.
  7. Feb 24, 2020 at 6:26 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    Does it happen when tank is full?
    Be curious to hear outcome. I had a Dodge Ram van that had this same thing happening. Turns out the right side frame tube was full of water. Took it 10 minutes to drain once I popped a plug out of it.
  8. Mar 8, 2020 at 7:30 AM
    Texas New Member
    Brett
    2018 TSS
    None
    I just had this issue and fixed it. There is a drain hole between cab and bed. If leaves or mulch gets down in there water won’t drain. I used a small screw driver to loosen leaves and the floodgates opened.
    Nm6300'asl likes this.
  9. Mar 8, 2020 at 7:52 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Are you draining the cab or bed, where was the water...
  10. Mar 8, 2020 at 7:57 AM
    Texas New Member
    Brett
    2018 TSS
    None
    Water sloshing sounded like it was in cab in walls behind back cab seat. I assume in back window compartment. This was definitely not water in truck bed
    NewImprovedRon likes this.
  11. Mar 8, 2020 at 8:02 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Thanks, it was like I thought. I guess the entrance is either the 3rd brake light or sun roof. If your head liner is dry around where the 3rd brake light is, then likely the sun roof. I have heard of cowls leaking but that usually sloshes around in the rocker panels. I'm glad you figured this out so we can periodically check ours. Can be a source of rust if they don't drain.
    beerreason and NewImprovedRon like this.
  12. Nov 8, 2020 at 7:15 PM
    beerreason
    beerreason New Member
    Bill
    2010 CrewMax TRD Off-road (purchased 2020), 2002 Access Cab (owned 2002-2020)
    I bought my 2010 this summer, and I've begun noticing some of this sloshing at times, independent of the amount of fuel in my tank. I'm willing to accept that it's possibly in the rear window compartment - I don't have a sunroof. How do I drain this area? That was unclear from the comments above.
    Thanks!
