Water Feature- how much?
Discussion in 'Home Improvement' started by Navi, Jul 17, 2021.
  1. Jul 17, 2021 at 4:10 PM
    Navi
    Navi [OP] New Member
    2019 CrewMax Limited
    I ran power to a workshop I have in my backyard, did the trenching, the conduit all of that stuff. So at least I have good power source in place
    rockmup and 2mchfun[QUOTED] like this.
  2. Jul 17, 2021 at 4:14 PM
    2mchfun
    Cal pump makes pretty decent pumps, one of those good things aren't cheap, and cheap things are not good.
    Navi[OP] likes this.
  3. Jul 17, 2021 at 4:18 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Rocks are cheap where you live but you'll spend every bit of your 5K even doing it yourself
    Navi[QUOTED][OP] likes this.
  4. Jul 17, 2021 at 4:25 PM
    2mchfun
    Whatever you do, don't buy anything aside from water garden plants at the pond shop. All hard goods have very high mark ups. Plants are even worse, they multiply like mad and are actually a nuisance in many places. However, you can't buy them many other places, but you can offer to pay cash and ask for the "cash discount".
  5. Jul 17, 2021 at 4:55 PM
    Navi
    even one of the kits from Aquascapes is around $3K
    rockmup[QUOTED] likes this.
  6. Jul 17, 2021 at 5:49 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    In the 15 years we've been installing Aquascape products I have not had to replace a pump, or had a leak in a liner. We used one of their liners on a mock wetland area at a local college. I was sceptical in that application but it has held up, it's been in place for 8 years.
  7. Jul 17, 2021 at 6:49 PM
    Navi
    what do most folks want installed? just the waterfall or the pond + waterfall? i'm thinking to do waterfall only
  8. Jul 17, 2021 at 8:07 PM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    Most want pondless waterfalls. Easier maintenance and less liability. We did a rehab, had to fill an existing waterfall pond with cobbles to a depth of 18" for their insurance to cover them. It's at a local community college. Local codes may dictate depth ... i.e. may fall under swimming pool regs.
  9. Jul 17, 2021 at 8:34 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    If it’s fall under swimming pool code, that’s mean you can’t have a pond more then 18” without sign and fence around it…
  10. Jul 17, 2021 at 8:58 PM
    Craigslist the hell out of rocks. Only thing I have paid for is diesel….
    1B86BBA1-C36A-4E45-83BC-C8BA6382DD0A.jpg 9ACEFE99-C059-4005-BFC4-FBA5EE18C101.jpg C05A2B20-1AD8-4043-8476-71B10CC77D00.jpg A3C934B8-DDEB-494D-8DDD-77725BD73BA2.jpg
    Pump size, layout, and some good ideas…boom. You will have a nice pond/water feature. You surely don’t sound lazy…so that will save you thousands.
  11. Jul 18, 2021 at 8:52 AM
    2mchfun
    Don't forget evaporation is going to be a big factor if you have much length to the stream.
    Navi[OP] and ColoradoTJ like this.
  12. Jul 18, 2021 at 9:04 AM
    Excellent point. Hell, just our water fountain will evaporate 50% of the pond basin in a couple days. (50 gallon basin).
    I will say this, glad I am on a well and only pay for electricity for the amount of water we go through.
    2mchfun[QUOTED] and Navi[OP] like this.
  13. Jul 18, 2021 at 9:04 AM
    Navi
    wow, impressive
    how long did the long rock wall take? do you just keep adding to it as you find more rocks?
  14. Jul 18, 2021 at 9:05 AM
    Navi
    did not even consider evaporation. being in the south will make some more of a difference I’m sure. I have a lot of shade in my backyard but it still is very hot
    ColoradoTJ[QUOTED] and 2mchfun like this.
  15. Jul 18, 2021 at 9:20 AM
    2mchfun
    You could buy a small pump and build a scale model to test different options
    ColoradoTJ likes this.
  16. Jul 18, 2021 at 11:18 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Everyone’s advice on here has been pretty Spot on.
    I do this in Alabama.
    A water feature of that size and nature would run 10k-20k depending on the contractor.
    It’s easily doable yourself for 5k.
    A water feature is fun to look at, splash around in and listen to.
    But it does require regular maintenance.
    Sometimes, more so than a pool or spa.
    There are a number of factors to take into account that haven’t been mentioned.
    Depth
    Use
    And level of sound effect.
    You’ll also have to consider your existing plantings as well.
    The more plantings that weep, drop debris, exfoliate bark or are deciduous, the more you have to tend and clean.
    If it’s small, stick with UV, however, when small, it’s much easier to control certain factors with the correct plants and fish species.
    These guys can easily be your filters and cleaners, if done properly.
    Natural stone should be widely abundant around the Atlanta area, and lot coming off of building projects, that could be had for free or next to nothing.
    Make sure when sourcing stones from places like this that you are picking out the actual stones and not chirt.
    Source your liner online and use roofing liners.
    They’re all EPDM and are basically the same.
    Do be careful with your adhesive material if you have to join pieces together.
    DO NOT SKIP THE LINER!
    From top to bottom.
    Many people think it’s not necessary on the waterfall part itself.
    It is.
    Make sure to get accurate measurements and order a large enough liner to hang at least a foot over all sides.
    Many pool companies will have spoils that they’re going to simply transport to a local “stone” company.
    They are charged for this.
    Call a few places and see if they will let you source some materials from the spoils.
    It’s usually very dirty and you will need to clean and pic through to find the good stuff.
    Sourcing stones from a local supplier is probably not as expensive as you would think.
    You can get a tri axel dump load for around $350-700 according to size and style.
    The expenses come in labor.
    Moving earth and stones are labor intensive.
    Having the design eye to puzzle together stones for a beautiful feature can be challenging for some as well.
    find some designs online and pick one you feel comfortable doing.
    Always remember, the farther the drop, the louder the sound.
    For every foot of waterfall rise you can increase sound levels a few Dbs.
    Louder water drowns out surrounding noises but can also do the same with the conversation you’re having.
    In turn, the louder the conversation, the more your neighbors hear.
    https://youtu.be/lvnN5JHUViw
    This has 2 falls, one fall drops into a small catch basin, while the next drops into the koi pond.
    It was not completely done at the time, but you can hear how loud a couple of 1-2’ drops can be.
    Another time and cost saver is if you can use your existing topography for layout.
    Utilize a hill that’s there.
    https://youtube.com/shorts/POWKJT7xuuI?feature=share
    These are the first two waterfalls I did years ago.
    Hope this helps.
    Navi[OP], ColoradoTJ and 2mchfun like this.
  17. Jul 18, 2021 at 12:28 PM
    Nice work @Hightide
    After watching that video, I have to take a piss. :rofl:
    slowpokepete, 2mchfun and Hightide like this.
  18. Jul 18, 2021 at 12:31 PM
    Hightide
    Abalama
    Magic School Bus
    Ha!
    Thank you!
    They’ll do that.
    Better than Flomax.
  19. Jul 18, 2021 at 12:32 PM
    #49
    Colorado Wobbly pops don’t help either.
    2mchfun and Hightide[QUOTED] like this.
  20. Jul 18, 2021 at 2:03 PM
    #50
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That looks sweet!
    FirstGenVol[QUOTED] likes this.
  21. Jul 18, 2021 at 2:19 PM
    #51
    Navi
    @Hightide this helps a huge amount. thanks for taking time to drop all of this knowledge.
    i’ll have to research chirt, i’m not familiar with that but I’m guessing it’s not good.
    I like the double waterfall effect that’s a good look. i’ve got some natural fall in my backyard, nothing too aggressive so I think I’ll be able to use that like you described
    i’ll refer back to your description several times, lots of good information in there
    Hightide[QUOTED] and 2mchfun like this.
  22. Jul 18, 2021 at 3:10 PM
    #52
    Hightide
    Abalama
    Magic School Bus
    I apologize for the misspelling.
    It’s chert.
    https://en.wikipedia.org/wiki/Chert
    it looks like stone but it’s high silica content makes it degrade at a much faster pace.
