water coolant disappearing in 3 to 4 days.
Discussion in '2.5 Gen Tundras (2014-2021)' started by msen, May 23, 2019.
  1. May 23, 2019 at 8:25 AM
    msen
    msen [OP] New Member
    2008 toyota tundra 5.7L
    I have 2008 Toyota Tundra 5.7L, it has 265,789 on it. Found no water coolant in the radiator or in the reservoir, I fill it up in 3 or 4 days it gone again. Need help.
  2. May 23, 2019 at 8:57 AM
    msen
    no overheating
  3. May 23, 2019 at 9:09 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Mine had a tiny tiny crack in the radiator.
    It would blow out while at operating temp, but the crack was too small to leak in the driveway
  4. May 23, 2019 at 9:12 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Check color of oil. Then check for wet area at front of engine behind and below the fan hub.
    Watt maker likes this.
  5. May 23, 2019 at 9:18 AM
    msen
    okay, thank you, I will check it I get home after, didn't want to keep adding coolant to drive.
  6. May 23, 2019 at 10:12 AM
    Get underneath and take a look at your water pump for the pink ooze that might be leaking out. My 07 water pump has been seeping for over 4 years causing a pink crust to form around the lower part of pump gasket. I have to add a couple oz's every few months. I have a new spare pump in waiting.....
    15Yota likes this.
  7. May 23, 2019 at 10:13 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You should be able to smell the coolant if it's hitting the engine. Kinda a sweet smell
    15Yota likes this.
  8. May 23, 2019 at 10:36 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Unfortunately, the temp sensor doesn't register properly when the water level drops below the sensor level.
  9. May 24, 2019 at 11:09 AM
    msen
    It was the radiator leak. First time replacing the radiator.
    Watt maker and 15Yota like this.
  10. May 24, 2019 at 11:10 AM
    msen
    My 2008 tundra has 268,786 on it, radiator gave up on me.
    Smiley likes this.
  11. Feb 8, 2020 at 9:04 AM
    esbailey
    esbailey New Member
    eric
    2007 5.7L Tundra
    My 2007 5.7L Tundra is using coolant - no overheating (197,000 miles). I can sometimes smell the coolant but there is never any signs of leaking on the floor. do you start with replacing the radiator cap, then to a shop to check the radiator?
  12. Feb 8, 2020 at 9:11 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    I’d start by replacing the radiator cap with a quality cap, like Stant. If that doesn’t solve it,
    take it to a radiator repair shop and have it pressure tested. Shouldn’t cost much and is a good starting point if you can’t see anything visible.
    Recently the wife’s mini was leaking coolant. Started with the cap, and was told by the radiator shop, that Murray caps have a decent failure rate out of the box, and Stant was the way to go. Ended up being the thermostat housing, which I ended up replacing myself.
    JimboSlice413 likes this.
  13. Feb 8, 2020 at 9:18 AM
    The water pump is known to weep. My 07 pump was weeping for some time but I never had to add more than a few ounces of coolant occasionally. You need to remove skid plate and take a gander at the bottom of the pump. If it is weeping you will see a pink crust forming around the seal. I'd check this first since this weeping is usually the primary cause of coolant loss with the 5.7
  14. Feb 8, 2020 at 9:34 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    When mine did Exactly that, the heater valve needed replacing, it was leaking just a little bit at at time, only when the heater was turned on, the small leak would drip down the firewall and evaporate before it ever dripped onto ground, so no evidence left. Luck.
