Water Charcoal Canister Tundra TSB
Discussion in '2nd Gen Tundras (2007-2013)' started by rons23, May 10, 2015.
  1. May 10, 2015 at 6:10 PM
    rons23
    rons23 [OP] Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Water Charcoal Canister Tundra TSB | Tundra Headquarters Blog
    http://www.tundraheadquarters.com/blog/water-intrusion-charcoal-cansiter-tsb/
    Has anyone had this problem. I just found out through a friend and co- worker that has a 2007 and is dealing with this problem. My engine light is on and pulled 2 trouble codes, but they don't match the codes on write up. It says you must have the 5 codes. This is not covered and is pricey fix, from 1-2 k. Any thoughts or comments would be great. Thanks
  2. May 10, 2015 at 6:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What codes are you getting?
    Haven't heard of the water charcoal canister tsb
  3. May 10, 2015 at 7:03 PM
    Mike Tread lightly.
    south carolina
    2x what are the codes
  4. May 10, 2015 at 7:13 PM
    rons23
    Ron
    Kill Devil Hills
    My codes are p0455 and p0441. The codes deal with the charcoal canister and evaporation system, but there not the codes their referring to.
  5. May 10, 2015 at 7:15 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What kind of shape is your gas cap and seal?
  6. May 10, 2015 at 7:25 PM
    rons23
    Ron
    Kill Devil Hills
    I changed my gas cap, that was my first check, but not it. The service guy at my semi local Toyota dealership said that it didn't necessarily have to be them codes referenced, but couldn't give me a definite answer. I would have to bring it in. My good friend who's a mechanic said it was more than likely a leak and not a big issue, but would have to do a smoke test. I know there are some legit dealerships out there, but I just hate bringing my truck in. My friend who's 2007 has that problem said he told Toyota he shouldn't be liable for a poor design, which they revised or modified for the 2009. Toyota is picking up the tab, so that's encouraging.
  7. May 10, 2015 at 7:27 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Do a basic visual inspection. You should be able to see 90% of the hoses no? Isnt the canister just located underneath, follow up the lines to the purge valve then to the intake. See if a fitting is loose or if you can see any tears in any of the hoses.
    Wouldnt hurt and could end up saving you money in the long run.
  8. May 10, 2015 at 7:32 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah that's a good call, thanks.
