Washer nozzle for window wash solution
Discussion in '1st Gen Tundras (2000-2006)' started by Oldrosetattoo, Oct 13, 2016.
  1. Oct 13, 2016 at 9:54 PM
    Oldrosetattoo
    Oldrosetattoo [OP] New Member
    Eric
    2001 tundra SR5 access cab
    I have a broken washer nozzle and was going to replace with a generic doorman brand part is it worth it to save a couple of bucks? A Toyota replacement runs over $30 doorman is $10 to $15
  2. Oct 13, 2016 at 10:08 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Well, Toyota undoubtedly out-sources the part and then adds their markup. Chances are its the exact same part.
  3. Oct 14, 2016 at 12:46 AM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    Depends on how ocd you are. I'm sure there will be a difference in the look of the two. I bought one for a 98 Tacoma and it was $27 or so years ago. Cheap for me as it stopped a rattle and one of the few parts that truck ever needed.
  4. Oct 14, 2016 at 7:48 AM
    So spend $30 for an OEM part vs $15 for an aftermarket one that may or may not work as it should....
