Washer fluid wiper issue
Discussion in '1st Gen Tundras (2000-2006)' started by Billybefishin, May 9, 2019.
  1. May 9, 2019 at 2:20 PM
    Billybefishin
    Billybefishin [OP] New Member
    Billy
    2001 Toyota tundra access cab
    I recently bought a 2001 tundra access cab. I'm having an issue with the washer pump or the switch I'm not sure which one. The switch says to pull out. As I do so nothing at all happens. Are the wipers supposed to activate as u pull the switch? Also no fluid is coming out. I either have a bad switch or pump. I just need to know if the wipers are supposed to activate while pulling said switch.
  2. May 9, 2019 at 4:01 PM
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    Yes, they are supposed to. If your pump is bad, the wipers will activate but no fluid will come out. If your switch is bad nothing will happen.
  3. May 9, 2019 at 4:18 PM
    Can you or have someone "hear" the pump working?
  4. May 9, 2019 at 4:21 PM
    Billybefishin
    Billy
    I can't here it run at all. But the wipers will not come on when I pull the switch out. Another thing I noticed the switch really doesn't move very much outward when pulled. The wipers work fine if I turn them on but not when I hit the wasger switch
  5. May 9, 2019 at 4:25 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Silly question but are you trying to pull it towards the passenger door or are you trying to pull it back towards the drivers seat? You want to pull towards the drivers seat if you aren't.
  6. May 9, 2019 at 4:25 PM
    Their a fuse for it? Wires connected to pump? Bad pump maybe?
  7. May 9, 2019 at 4:25 PM
    Hope you get it resolved
  8. May 9, 2019 at 4:32 PM
    Billybefishin
    Billy
    Alright I'm an idiot! I was pulling towards the passenger side! I thought the end of the lever pulled outward! I see now you gotta pull towards yourself. I was about to waste alot of money on a bunch of non working switches hahahaha.
  9. May 9, 2019 at 4:38 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Glad it was an easy fix.
    I've had plenty on vehicles where you pushed in the end to wash so I can see where pull could be the misinterpreted.
    Billybefishin[OP] likes this.
