Wash set-up
Discussion in 'Detailing' started by Breathing Borla, Jun 1, 2023.
  1. Sep 24, 2023 at 9:49 AM
    Breathing Borla
    Breathing Borla [OP] I'd rather be fishing
    AZ
    Any sap remover recommendations? I got a wad on there from my vacation and it’s not coming off easy
  2. Sep 24, 2023 at 9:53 AM
    I would use a non abrasive MF towel with some warm water on it and let soak on it for a bit before trying to remove
  3. Sep 24, 2023 at 9:58 AM
    Breathing Borla
    AZ
    I did that but the outline and residue is still there
  4. Sep 24, 2023 at 6:07 PM
    briarpatch
    briarpatch New Member
    unscented hand sanitizer
    Chucksmith07 likes this.
  5. Oct 23, 2023 at 8:01 PM
    Breathing Borla
    AZ
    I just order my first new set of crspotless filter cartridges
    went with the cartridge exchange they offer so they will send my a new set of cartridges and I then send them these spent ones back
    120 bucks shipped , not bad since they lasted a while, I may order bulk next time instead
  6. Oct 23, 2023 at 8:47 PM
    Breathing Borla
    AZ
  7. Oct 24, 2023 at 1:08 AM
    War Machine
    War Machine SSEM # 5 3MW
    Shipped quickly and works great. No issues. I just refill the cr cartridges.
  8. Oct 24, 2023 at 4:00 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Nice set up op. I’m a fan of Chemical Guys products as well. I bought a generic foam cannon from ebay that does a great job with my power washer. Complete foam coverage with the CG soap. I also use their Hydro Slick Ceramic Coating Hyperwax and their Hydro Speed Spray Detailer.
  9. Nov 12, 2023 at 3:48 PM
    Breathing Borla
    AZ
    I seem to have wound up with spider webs in the clear coat , I’m wondering if they didn’t use enough lube when they clay bar. I’ve never been through a car wash and have all brand new stuff so not sure something I did .
    Anyway , only noticeable when it’s clean and sun hits it right
    I’m guessing nothing I can do
    also , so far I think I like the coating I put on the van better myself rather than the glass coat product they used . We’ll see how it turns out in the longer run
  10. Nov 12, 2023 at 3:50 PM
    Is it already ceramic coated? If so, you’d have to use a good microfiber pad with maybe a one step polish, then re-prep, and add ceramic back.
    ToyoMafia likes this.
  11. Nov 12, 2023 at 4:14 PM
    Breathing Borla
    AZ
    I’ve never polished a paint job before , is this something I should have a shop do?
  12. Nov 12, 2023 at 4:47 PM
  13. Nov 12, 2023 at 4:54 PM
    Breathing Borla
    AZ
    T-Rex266[QUOTED] likes this.
  14. Nov 12, 2023 at 5:31 PM
    You can definitely paint correct yourself. It’s a lot of work if done right. If you’re going to do the entire truck, and want to break it into pieces, just do one side each weekend. You can make it 4 weekends long if needed.
  15. Nov 19, 2023 at 6:31 PM
    briarpatch
    pics would be helpful if possible
  16. Nov 28, 2023 at 4:01 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    did you just run the spotless without the filters to get your baseline ppm or did you buy a meter? I just bought a used Spotless and was figuring i'd get a baseline.
  17. Nov 28, 2023 at 4:05 PM
    War Machine
    I got this meter from Amazon.
    Professional TDS ppm Conductivity Meter - Quick and Easy EC TDS and Temperature Test Pen | 0-9999 ppm with ± 2% Accuracy | Perfect 3-in-1 Tester For Ro Water Aquarium Hydroponics Coffee Pool etc. https://www.amazon.com/dp/B01FPG89CE
  18. Nov 28, 2023 at 4:08 PM
    Danimal86
    Daniel
    Sacramento, CA
    Thats not too bad. Maybe i'll grab one just to know.
    How did that bulk resin end up working? My meter is showing 7 or 8ppm so the resin is toast.
  19. Nov 28, 2023 at 4:08 PM
    #49
    Breathing Borla
    AZ
    just buy a meter such as below and test your tds from anywhere in the house , then you’ll know your base levels, mine are kinda high at 300-350
  20. Nov 28, 2023 at 4:11 PM
    #50
    Danimal86
    Daniel
    Sacramento, CA
    ordered a cheapo meter
  21. Nov 28, 2023 at 4:16 PM
    #51
    War Machine
    I’ve only done a couple of washes with it so far but it works fine.
  22. Nov 28, 2023 at 4:19 PM
    #52
    Danimal86
    Daniel
    Sacramento, CA
    I'll be interested to see what it is at the tap. I found last years water report for the treatment station that feeds our neighborhood. Looks to be 79 for surface and 156 for groundwater (not sure what the difference really is, or how that differs from what comes out of the tap)
  23. Nov 28, 2023 at 4:20 PM
    #53
    Danimal86
    Daniel
    Sacramento, CA
    Looks like the resin you linked is OOS. I might just do the cartridge swap for my first one since i dont know what shape they're in.
  24. Nov 28, 2023 at 4:23 PM
    #54
    Breathing Borla
    AZ
    I just did my first cartridge swap with crspotless, worked great
    back to 0 ppm
  25. Nov 28, 2023 at 4:25 PM
    #55
    War Machine
    I’ve done that plenty. Works great and easy, just more expensive in the long term.
  26. Nov 28, 2023 at 4:34 PM
    #56
    Danimal86
    Daniel
    Sacramento, CA
    So its $119 for the swap? The person i got it from said that they refund you money once you ship the old cartridges back.....or is 119 with the core exchange or less?
    Cant really tell on the site.
  27. Nov 28, 2023 at 4:58 PM
    #57
    Breathing Borla
    AZ
    119 total OTD
  28. Nov 28, 2023 at 6:00 PM
    #58
    Danimal86
    Daniel
    Sacramento, CA
    Thx!
  29. Dec 2, 2023 at 3:58 PM
    #59
    Danimal86
    Daniel
    Sacramento, CA
    Well i got my TDS meter in the mail, at our kitchen sink the tds is reading at 82
    I checked the water out of our refigerator that has a filter on it and it was at 69. I guess we've got decent water.
  30. Dec 2, 2023 at 4:07 PM
    #60
    Breathing Borla
    AZ
    your spotless will last a long time with that input water reading
    Danimal86[QUOTED] likes this.
