WARNING [Rear differential oil]
Discussion in '2.5 Gen Tundras (2014-2021)' started by Marine Corp 1371, May 28, 2019.
  1. Jun 1, 2019 at 2:22 PM
    RonW
    RonW New Member
    Wonder how long I can drive it if I never change it.
  2. Jun 1, 2019 at 3:19 PM
    Professional Hand Model
    Hand Protectors
    Same with 1st Gens. The stealer, when asked directly about what they use for the rear diff which requires straight 90w, says they use 75w-90.
    Black Wolf and Watt maker like this.
  3. Jun 1, 2019 at 3:26 PM
    RonW
    RonW New Member
    I had a 2004 GMC with over 230 on it. Never changed anything but the oil. Was still going strong until a drunk guy hit me. I figure the Toyota should hold up even better.
  4. Jun 1, 2019 at 3:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    From working at the dealer I can tell you the ws transmission fluid usually is dark by 30k miles. Is it bad then? No. But it discolours quick. Pay for a drain and fill. Don’t do a flush because almost all the dealers won’t flush the transmissions because it’s a hassle
    Watt maker likes this.
  5. Jun 1, 2019 at 3:28 PM
    empty_lord
    05 rollover special
    I had 270k on the original gear oil in my Tacoma when I changed it. Nothing alarming.
    The tundra I bought hand to had it changed in 170k and it also looked dark. But nothing alarming
  6. Jun 1, 2019 at 4:42 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Probably 300k miles
  7. Jun 1, 2019 at 4:53 PM
    Stig
    Stig New Member
    Plenty of Ti
    Yep. This is being blown out of proportion here.
    Just follow the maintenance in the owners manual
  8. Jun 1, 2019 at 5:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I went to three different parts stores around here and NO ONE has the 75w-85 GL5 stuff. Of course, it's online for 24k gold prices....
    yoshi82 and (deleted member) like this.
  9. Jun 1, 2019 at 9:45 PM
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    RedLine makes a 75w85. The Toyota stuff is pricey but really good oil. I’ve delved deep into this rabbit hole..here’s my plug at 10k miles.
    Black Wolf likes this.
  10. Jun 2, 2019 at 4:34 AM
    Beni36ti
    Beni36ti New Member
    2017 SR5 CrewMax
    After the change and when the oil was bad, do another change after 2-300 miles, it will clean the whole stuff oit and therefore you will see your new oil being dity again....
  11. Jun 2, 2019 at 7:15 AM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Has anyone tried Ravenol in their transfer case? Apparently it's a 75w replacement for the Toyota 08885-81080 (it has Toyota 08885-81081 on the front of the bottle, which is supposedly the European designation for the US 08885-81080) and is a whole lot cheaper at $18.32 per quart on Amazon. https://www.amazon.com/gp/product/B00QPCL7ZE/ref=ox_sc_saved_title_1?smid=A3NWHGHN360KCD&psc=1
    Dave
  12. Jun 2, 2019 at 7:31 AM
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    I haven’t, but I’ve seen VOA of both and the add pack in the Ravenol is very very weak compared to the Toyota 75WLF.
  13. Jun 2, 2019 at 7:44 AM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    Good to know...thanks. In the end, it doesn't make sense to risk a $50K+ truck by trying to save a couple hundred bucks. When the time comes, I'll probably just get the Toyota fluid.
    Dave
    SRM18TRD[QUOTED] and jtwags like this.
  14. Jun 2, 2019 at 8:09 AM
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    No problem, FYI every Toyota dealer I’ve talked to just uses whatever bulk 75w90 they have in Diffs and T/C. Only time the good stuff gets used is on warranty work. Most of the time the parts guys have no clue what this stuff is. Just didn’t want you to think by just going to a dealer would ensure you’re getting the right stuff. The old school cans probably great for shelf life but are a nuisance. E6CF40DF-E52B-401C-94D5-E8217E0BBAC3.jpg
    texasrho83 and Wynnded like this.
  15. Jun 2, 2019 at 11:46 AM
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Did you also buy new drain plugs? Also do they use crush washers I’m about todo mine just so I get all the parts before. How many of the old school toyota cans did it take? My dealer said 4?
  16. Jun 2, 2019 at 1:16 PM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I hit 50K today.
    I did a drail and fill on the transmission pan only. Roughly 4 of 12qts. the fluid was not burnt or bad at all. But I figure ill do this every 20K now.
    I also did my rear diff at 5000 miles and then again 45000 miles. The Rear is bad, ill continue to do it every 40K. I did the front at 10K but haven't done it again since i don't 4wd very often.
    I have not touched the transfer case... It is a very special oil that NO ONE matches and its like $75 a qt or something crazy. So I hope you don't mess up your transfer case since it's not a normal 75W85-90 like the diffs are.
    I also trust no one to work on my truck... NO ONE.
    Watt maker, Beep88 and SRM18TRD like this.
  17. Jun 2, 2019 at 1:35 PM
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    No, just new steel crush washers for the rear diff. The new borg Warner t/c on the tundra doesn’t use crush washers (npt threads instead). In that photo I posted, I was serving my 15 4Runner. This is the correct sealant for the tundra t/c treads tho..3.8 quarts for the tundra rear diff.3ED84EE9-0B63-4667-BC23-B658D0DCF8FC.jpg
