Warn vs Smittybuilt 12K synthetic
Discussion in '2nd Gen Tundras (2007-2013)' started by jelloburger, Dec 30, 2019.
  1. Jan 13, 2020 at 9:36 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Smitty’s are unquestionably great winches.
    This must be a really old comparison review. It says Warn doesn’t come with a wireless remote. My 10K Xeon Warn has the wireless remote and was installed about 5 years ago.
  2. Jan 13, 2020 at 9:47 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Are the stock cables long enough? I might do the same if no cable mod is required.
  3. Jan 13, 2020 at 10:07 AM
    jelloburger
    jelloburger [OP] New Member
    @gosolo - my Warn EVO 12k came with a remote that can be wired/wireless.
    The irony here was that I was about to get the Smittybuilt, until I read their own comparison chart vs "leading competitor" aka Warn. Some of those things I could care less about, but the things I did care about it was a better option for me to go with Warn, namely the warranty and the IP68 waterproof rating.
    gosolo and NewImprovedRon like this.
  4. Jan 13, 2020 at 10:20 AM
    jelloburger
  5. Jan 13, 2020 at 12:14 PM
    timsp8
    NY
    The Warn warranty is better but the X20 is also IP68 rated. I wanted a Xeon platinum but found a good deal on the X20 on Black Friday. It’s not installed yet so I haven’t even tried it out though.
    jelloburger[OP] likes this.
  6. Jan 13, 2020 at 1:52 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    No, stock cables not long enough. I just bought some longer battery cables
  7. Jan 13, 2020 at 2:38 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I'll be mounting my Smittybilt 12k X20 in the next couple weeks (once the snow stops flying). My main consideration was cost, the Warn was about double the price and the smitty seems like it is a reliable enough option for the 3-4 times a year I'll use it. I'll let everyone know if I have trouble but my cheap ass thought about it on a cost per use basis and the Warn was too hard to justify.
    jelloburger[OP] and gosolo like this.
  8. Jan 13, 2020 at 3:59 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, when I went to get my knee replacement, I talked to several doctors and decided that the best doctor just wasn’t worth that much more money. I found a good doctor who would do the job for half as much. Figured I only use the knee occasionally so why spend those hard earned dollars. Probably will spend the money I save on a facelift and a tummy tuck.....
    Said, nobody....ever.
  9. Jan 13, 2020 at 4:12 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    not really comparing apples to apples there are we...
    a better comparison would be buying a snap on 10mm socket vs a kobalt. both will do the same job but 1 is going to cost twice as much. will it last longer yes... will it matter probably not.
  10. Jan 13, 2020 at 5:20 PM
    jelloburger
    Finished re-installing the winch and bumper, hooked up the LED fog lights and amber running LED lights. Pretty easy the second time around :p, but getting it perfectly "finessed up" against the body lines a bit of a PITA, but it's done. Also, this time around I installed the winch foot forward versus foot down. This gives me peace of mind that now that winch would literally have to destroy the frame before it could ever come loose whereas I suppose it's possible (but highly improbable) in a foot down position you could sheer the bolts off. I took @thetwood advice, made up some cables (see the link above) and routed them into the engine bay. I chose to go to the passenger side, namely because the winch wiring connection was on that side and was just easier to route. Additionally, I decided to mount it on top of the airbox (stealing your idea for Velcro @thetwood :)). I'll post a pic once I have it mounted.
    thetwood and gosolo like this.
  11. Jan 13, 2020 at 5:51 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    If I buy a winch it will be a Warn non VR series. Their other models are assembled in the USA with many of the important components being made in house. The VR series is 100% foreign parts and assembly.
    NewImprovedRon likes this.
  12. Jan 13, 2020 at 5:59 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yeah, you’re right, but it was a fine story!
  13. Jan 15, 2020 at 3:27 PM
    jelloburger
    After MUCH contemplation and shade tree mechanic ruminating, I finally fabricated a "quick release" bracket out of some scrap aluminum I had. A few cuts, some drill and tapping and below is what I came up with. Not sure if you can see what's going on here, but basically it's a "permanent" bracket that is fixed to the front of the truck then a second plate attached to the winch controller that then mates to the top of the bracket. I mounted it here to allow for the remote cable to pass through the grill if needed without issue. Also, to move the controller, I just remove the 2 hex screws and simply move the controller where needed. I can still access the oil dipstick and trans fluid reservoir so really shouldn't need to move the controller, but can be moved in under 60 seconds. What's more, I didn't need to drill a single hole in the truck, was blessed to have some existing holes right where I needed them. :) Forgive the less than respectable finished product, when the weather cooperates I'm gonna remove everything, clean up the edges and spray.
    thetwood likes this.
  14. Jan 16, 2020 at 9:52 AM
    jelloburger
    Made some "gator skins" from an old water pump belt. Trying to protect the paint on bumper/shackles from the swinging going down the road. Yes, I had to paint some eyes on them, they look like little gator heads to me, sorry, I couldn't help myself. :)
