Want to level truck
Discussion in 'Suspension' started by fingers1126, May 4, 2018.
  1. May 4, 2018 at 8:21 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Bilstein 6112s, assembled at the 1.9in setting. Perfectly level. You don't need to be messing with the rear. If you buy them assembled from a place like Boss 4X4, the install is 1-2 hours and not bad at all. With only 2 inches of lift, you don't have to mess with the UCAs. For the price, performance, and simplicity, there is no better option in my opinion.
    -Jim
    tinman10101 likes this.
  2. May 4, 2018 at 8:28 AM
    Odb1987
    Odb1987 New Member
    I have 5100’s at middle setting. Rear is stock. 6112’s are good but more expensive. Both of these are solid choices.
  3. May 4, 2018 at 9:31 AM
    fingers1126
    fingers1126 [OP] New Member
    What is every ones take on the Eibach shock system ? similiar to billy's ???
  4. May 4, 2018 at 10:33 AM
    MistrRoboto
    Virginia Beach, VA
    The Toytec Eibach gets great reviews but it's non adjustable 3 in. So you have to lift the rear, and debatably get into UCA territory.
  5. May 4, 2018 at 10:38 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    I am not sure why you don't want to lift the rear? Shackles are simple and easy to add with the Eibach kit.
  6. May 4, 2018 at 10:45 AM
    MistrRoboto
    Virginia Beach, VA
    Speaking for myself, not the OP... few reasons. Parking garage clearance... 1 more inch in the front/rear and I couldn't park where I need to. Getting a dirtbike into the bed of a lifted truck is just that much harder. More shit to mess with. 3/1 adds potential complexity of UCA upgrade which is time and $$$. Alignments are trickier. 2/0 lift fits 285/70/17 which is a great tire size. 2/0 also looks proper with the stock tires, where as 3/1 looks silly so you need to upgrade immediately.
    I love the 3/1 lifts, and had an ICON setup on my FJ, but there are plenty of reasons to just keep it simple with 2 in the front.
    -Jim
  7. May 4, 2018 at 10:57 AM
    fingers1126
    Just looking to level off started with a $70 pair of inserts now I’m on the $1000 range I only drive truck back forth to work and around city . Not going off road and such just looking to even out the truck . Without refinancing my house .... that’s all
  8. May 4, 2018 at 10:57 AM
    fingers1126
    What he said
  9. May 4, 2018 at 10:59 AM
    fingers1126
    So how does 5100’s all four corners stock springs middle setting. 1.57 I think . Should be good to go ? Do I need diff drop kit or numb stops ? Any thing else ???
    Anyone else running this combo feel ride is good ....
  10. May 4, 2018 at 11:03 AM
    MistrRoboto
    Virginia Beach, VA
    Diff drop is to reduce stress and angle on the front CV axles - and I think you mentioned to me you have a 2wd... so no front CV axles.
  11. May 4, 2018 at 11:05 AM
    fingers1126
    i have 4wd
  12. May 4, 2018 at 11:06 AM
    fingers1126
    you running stock springs?
  13. May 4, 2018 at 11:07 AM
    MistrRoboto
    Virginia Beach, VA
    Ah. Not sure where I read about 2wd, maybe it was a recent PM. My bad! The TRD PRO comes with a level stance, so 2 inches taller in the front than the standard Tundras, and DOES NOT have a diff drop. I installed the diff drop kit with my 2 in lift and it reduced a little bit of the angle, but it wasn't that severe to begin with.
  14. May 4, 2018 at 11:07 AM
    MistrRoboto
    Virginia Beach, VA
    6112's, which does not reuse any components of the stock front suspension.
  15. May 4, 2018 at 11:09 AM
    fingers1126
    ok i see the 6112's come with springs i believe.....
  16. May 4, 2018 at 11:10 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I'm running 5100's on all four corners, front on the middle setting. Very happy with this setup on my pavement queen, ride is better than stock but not at all harsh and easy to align and keep aligned. Truck sits almost totally level which is the look I wanted and at the middle there's no need for a diff drop.
  17. May 4, 2018 at 11:14 AM
    fingers1126
    this is info looking for , what im looking to do and end result , you just see so much stuff out there drop diffs , bump stop's, upper contorl arms so on and so on . I want to make improvements not cause damage its a brand new truck well year old lol but only 6k on od so shows how far i drive lol .. Thanks for the input
  18. May 4, 2018 at 11:28 AM
    duece292
    Greg
    Green Bay, WI
    :thumbsup: IMO 5100's are a great basic setup. I don't get off the road much and when I do its usually just your average dirt/gravel forestry roads. The fronts come with bump stop spacers that are really nothing more than a washer. Until you go 2 1/2" or more in the front there's no need for a diff drop. Easy to align and will keep you within factory specs, easy on upper and lower ball joints, no need to change UCA's. There's really no downside. Would I have loved to do a 3/1 and 295 tires? Hell yes!!! But I also like to park inside my garage. :D
  19. May 4, 2018 at 11:39 AM
    #49
    This helps get rid of the "rake".....[​IMG]
    Big J, Challenger1 and duece292 like this.
  20. May 4, 2018 at 11:46 AM
    #50
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Step Tubes BakFlip VP Dee Zee Bed and Tail gate mats Pop A Lock tailgate lock Smitty Built M1 Rear Bumper Weather Tech mats Interior LEDS Remote control Bed Lights Cabelas seat covers
    I will have mine done in a couple of weeks with 5100 on middle setting. Adding Nitto RG's 275/70/18 on stock rims. I will post pics when complete.
  21. May 4, 2018 at 12:47 PM
    #51
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I am running this setup and the ride is better than the stock (yellow) TRD shocks.
    MistrRoboto and Black Wolf like this.
  22. Oct 8, 2018 at 8:33 PM
    #52
    JamesWiz
    JamesWiz New Member
    James
    5100 just in front? Stock on rears?
