Want to get rid of Kings for a softer/smoother ride
Discussion in 'Suspension' started by Cuban11182, Jan 31, 2022.
  1. Feb 1, 2022 at 8:56 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yes sorry i was talking about the front springs but if the fronts are good then ignore my post.
  2. Feb 1, 2022 at 8:57 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    We have a lot of details on comparing those two here: https://accutuneoffroad.com/fox-vs-king-oem-coilovers/
    We usually recommend Fox over King due to their quality of parts being used. Makes them last longer. They also have a 2.0 rear option which may be fine for your truck. The 2.0 shock would allow for a much softer/smoother ride.
  3. Feb 1, 2022 at 9:04 AM
    Cuban11182
    Cuban11182 [OP] New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    285/70R17 Cooper AT3 with Icon Rebound rims. From the factory wheels I increased 3lbs per rim/tire. I have all the sidewall, lol.
    Airlift as well. I have the daystar cradles so they're floating. That is a valid point with the internal jounce bumpers. Maybe I'll put my gopro back there and see if that's the cause. Good call!
  4. Feb 1, 2022 at 9:30 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Ditch the air bags and any spacer lift you got in the rear because Kings ( or any shock brand for that matter) is not providing you any lift in your rear. Get a proper leafpack from Deaver, Alcan, ARB, Dobinson etc to provide your lift...
  5. Feb 1, 2022 at 9:33 AM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I'm not after a lift in the rear. The Kings are setup to be level up front and the rear has no spacers, shackles, etc. The bags were there for towing and hauling. Seeing that the Deaver F85 and Icon AAL will raise the rear up a little isn't something I'm after, but if the ride is greatly improved then it's worth a shot.
    What I will do is see of any of them make springs for no lift but progressive rates. I think that would be up my alley.
    cavalry bear likes this.
  6. Feb 1, 2022 at 9:39 AM
    GiantsFanDan
    The stock leaf pack sucks for ride. Once you replace the pack it make a huge difference but all usually have 2in lift. Your ride will be way more planted
  7. Feb 1, 2022 at 9:41 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Do you still have the parts you removed to install the kings? If so throw those back on and see if the ride softens up. That will at least help you know if your leaf packs are to blame. While you're on the old shocks get your Kings set up.
    I say this because leaf packs are nothing but compromise. Want a soft ride? Say goodbye to payload. Want to keep that payload and have a soft ride? Say hello to 3" of lift, and it still will buck when not loaded. Ordering leaf packs takes a sure mind and isn't cheap. Plus of you change your mind on them theyre hard to sell unless you get lucky enough to find a local buyer who wants them.
  8. Feb 1, 2022 at 9:44 AM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I do not. When stationed down in Miami I gave them to a subordinate who needed new ones for his older Tundra.
    Darkness[QUOTED] likes this.
  9. Feb 1, 2022 at 9:47 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh I see, I read the part about giving older stuff away but wasn't sure if that was the original parts.
  10. Feb 1, 2022 at 10:01 AM
    Tundra1D6
    I have some nice almost new sport shocks and struts. Send me those kings and I’ll send you mine ;).
    Have you looked at the Falcons? Some people talk a lot about those.
    Darkness likes this.
  11. Feb 1, 2022 at 10:22 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I'm running King 2.5.s with reservoirs and adjusters with 700lb coils and Alcan leafs with Coachbuilder Plus 3 Shackles, my ride is smooth as silk. Really planted on road and great off. I also have about 300 lb additional weight on the front with bumper, winch and lights. Before the bumper the front was pretty rough.
    Skew12 likes this.
  12. Feb 1, 2022 at 11:06 AM
    Vang530
    Vang530 New Member
    Ditch the load e tires, ditch the air bags or get daystar cradles, and get custom accutuned fox 2.5s.
    I'm running 37s Load D's @ 32 psi and my accutuned fox 2.5s ride better than my 1st gen raptor.
    AccuTune Offroad likes this.
  13. Feb 1, 2022 at 11:20 AM
    pandapro
    pandapro New Member
    Trade for TRD Pro Fox shocks in the mean time? ;)
  14. Feb 1, 2022 at 2:45 PM
    Burdturger
    Burdturger New Member
    Trade ya my bilsteins Fer ya kings :bananadance:
  15. Feb 2, 2022 at 4:48 AM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Thank you everyone for the suggestions. My plans going forward are to swap out the E rated tires for D rated Toyo tires in my size (287/70R17). I'm going to try the add a leafs and I'm going to pull my Airlift setup as I think this my be the culprit. If it is, I'll see about either getting the Firestone bags and/or getting leaf springs custom made (although I don't carry anything in the bed on a daily basis, may do a cap eventually).
    Thanks again for all the suggestions and advice. It's greatly appreciated.
    pandapro and AccuTune Offroad like this.
  16. Feb 2, 2022 at 12:53 PM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    2Tall if you're ever in the Fort Bragg/Fayetteville NC area, hit me up. I owe you some beers/drinks and dinner.
    Pulled the Airlift bags @ the recommendation of 2Tall. Smooth as butter. I guess I hadn't really run the Kings without the bags since I got them around the same time. The bags are on a shelf in the garage and will probably be tossed. Now to find some bump stops for the ones that I cut.
    Vang530, des2mtn and 2Tall[QUOTED] like this.
  17. Feb 2, 2022 at 3:01 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Glad I could help you out bud! Check out Duro Bumps or Wheelers Off-road for bump stops that are an upgrade from stock.
  18. Feb 5, 2022 at 9:28 AM
    ultra1988
    ultra1988 New Member
    2019 tundra
    I had load E coopers and the ride was horrible, even with the stock suspension. I switched them out for Bridgestone revo 3 load E and the difference is significant. I would like load range C or D eventually, but it’s clear that tire manufacturer/quality makes a big difference.
    I have kings also, front is fine but rear isn’t. I already put on coach builder shackles, minimal improvement. I have a deaver mini pack in the garage waiting to go on. No reason to get rid of the kings, just have them valved for what you want. One day I plan to take them apart and try valving them myself.
  19. Feb 5, 2022 at 9:30 AM
    #49
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Thanks for the suggestions. In truth, my ride has vastly improved by removing the Airlift bags. The internal jounce bumper is wht was causing the harsh ride. Since removing them, I have no complaints at all.
