Voice Command button on steering wheel
Discussion in 'Audio & Video' started by ntvkayn808, Sep 11, 2019.
  1. Sep 11, 2019 at 7:30 AM
    ntvkayn808
    ntvkayn808 [OP] New Member
    Kenika
    Cambridge, Ohio
    2010 Tundra SR5 DC
    When using voice command button on steering wheel via bluetooth handsfree on my 2010 Tundra, it won`t recognize command or it will advance to something different (ex: "main menu" > "redial or call cannot be placed"). Then it will disconnect for no apparent reason...maybe a loose wiring? Any wiring diagrams out there or anyone with similar trouble?
  2. Sep 11, 2019 at 7:40 AM
    Tierhog
    Tierhog SIG-AHOLIC
    California
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories
    If none of the commands work, and did prior, I'd check for updates and force a hard reboot.
    Disconnect negative terminal. Get in drivers seat and pump the breaks 10 times or so (The idea is to drain any residual juice in the electrical system) . Reconnect battery.
    Check functionality.
    As goofy as this seems..
    Its worked on other Toyotas (after changing a battery)
    Its free.
    Other than that... A ten year old head unit.... Eh....
    Welcome to the forum!
