VLEDS footwell lights-blowing fuses
Discussion in 'Lighting' started by Hammerdog, Feb 23, 2020.
  1. Feb 23, 2020 at 3:28 PM
    Hammerdog
    Hammerdog [OP] YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I give up. Made the mistake the first time and didn’t disconnect the negative battery cable. Replaced the fuse, same thing put the negative cable back on, cut the lights on, boom, blows the fuse... anyone have any ideas? This was supposed to be a easy plug and play relaxing mod...
  2. Feb 23, 2020 at 3:31 PM
    timsp8
    NY
    Sounds like something is cross wired. I didn’t disconnect my battery when I installed mine and didn’t blow any fuses. Unplug them and do 1 at a time to see which one has a short.
  3. Feb 23, 2020 at 3:38 PM
    Hammerdog
    Robbie
    Louisa VA
    I only hooked one of the footwell lights up, if that is what you are saying. I’ve tried numerous times and just quit because I blew numerous fuses.
  4. Feb 23, 2020 at 3:42 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So the circuit works Until you hook up a footwell light? If so, then the short is with the footwell light itself.
    If not, then its the other way around. Let us know what you find.
  5. Feb 23, 2020 at 3:43 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    @T-Rex266 installed these I believe. Might have some insight.
    T-Rex266 likes this.
  6. Feb 23, 2020 at 3:47 PM
    timsp8
    NY
    Try a different one. My kit came with 4 lights and extensions. If you have more than one, plug that one in. What happens if you put the factory bulb back in? Does it work?
    Blowing fuses is usually a bad ground. But the lights are self contained so sounds like it has a short in it somewhere.
  7. Feb 23, 2020 at 3:53 PM
    Hammerdog
    Robbie
    Louisa VA
    Here is what I did . Disconnected battery. Hooked VLEDS connector up, reconnected battery, open door or cut on lights, the trucks interior lights for a second or two, then blows the fuse. Put the normal bulb back in, no issues. The VLEDS have never lighted up. I feel like I’m missing something...
  8. Feb 23, 2020 at 3:57 PM
    Hammerdog
    Robbie
    Louisa VA
    Same with my kit 4 lights and extension. Thanks for the advice, please keep it coming, it’s got dark here , so I’m into the beer for now. I’ve been sick with a chest cold for almost a week, so my thoughts may not be clear.
  9. Feb 23, 2020 at 4:12 PM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    The socket your plugging into has very tiny little metal strips in it I would check to see if they got bent and are touching each other
    NewImprovedRon likes this.
  10. Feb 23, 2020 at 4:21 PM
    Hammerdog
    Robbie
    Louisa VA
    A1783AA8-589B-4F19-B2C9-7F80E42C2BEE.jpg They look good to me
    they look good to me.
  11. Feb 23, 2020 at 4:24 PM
    NCTundra1980
    Stephen
    2019 SR5
    Have you tried the original bulb again? If the original bulb is working without blowing a fuse, it sounds like something is shorted with the led strip. If you tried all the strips and all are blowing the fuse and the original bulb is not I would call vled and see What they say about it. Maybe they have a bad batch with something shorted or maybe you can ohm it out or something
  12. Feb 23, 2020 at 4:26 PM
    NCTundra1980
    Stephen
    2019 SR5
    Try one strip at a time could be the extension wire
    Sas likes this.
  13. Feb 23, 2020 at 4:37 PM
    Hammerdog
    Robbie
    Louisa VA
    Original bulb work. I have not tried each light strip, just the adapter plug and one of the light strips. I’ll try tomorrow with a different light strip... really was looking forward to looking like a pimp with my red floorboards...
  14. Feb 23, 2020 at 4:44 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
  15. Feb 23, 2020 at 4:48 PM
    NCTundra1980
    Stephen
    2019 SR5
    Good luck let us know what u find
  16. Feb 24, 2020 at 9:39 AM
    Hammerdog
    Robbie
    Louisa VA
    I called VLEDS, very helpful. They are going to send me another connector. Excellent customer service! Hope this works.
    paradizecityz likes this.
  17. May 1, 2020 at 5:39 AM
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    Curious to know if the new lights VLEDS sent you fixed the issue. I'm considering getting this kit from them.
  18. May 1, 2020 at 6:06 AM
    Hammerdog
    Robbie
    Louisa VA
    Oh snap, forgot to update. Yes they immediately sent me another connector and it fixed the issue. It’s a great kit and they stand behind there products.
    Ely010606 and TxLock21[QUOTED] like this.
