VLEDS Footwell Lighting Install
Discussion in 'General Tundra Discussion' started by Sas, Jul 27, 2018.
  1. Aug 12, 2018 at 12:41 PM
    Am I to splice into something with this?
  2. Aug 12, 2018 at 12:43 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    There should be an adapter with the kit that plugs in where the bulb went. Should look something like the second pic.
  3. Aug 12, 2018 at 12:50 PM
    Sas
    OKC, OK
    Yeah, those little connectors go on the ends of the wires. Here's a video.
  4. Aug 12, 2018 at 12:59 PM
    Are these supposed to slide over one another?
  5. Aug 12, 2018 at 1:03 PM
    Sas
    OKC, OK
    Yep. It looks like they won't go together correctly when you begin to fit them together, but they do connect securely. Note what the instructions say about polarity. This is where it gets fiddly and you need to check each strip to make sure you have all your connections correct and that everything lights up when they're all connected together before wiring everything in. If you have different connectors that you like I'd honestly just use those instead of the ones that came in the kit.
    NewImprovedRon likes this.
  6. Aug 12, 2018 at 1:13 PM
    Screw this polarity lol. Can’t get the 2nd strip to light
  7. Aug 12, 2018 at 1:15 PM
    Sas
    OKC, OK
    Yeah, it's friggin' :annoyed: as shit. You have to unhook one of those little connectors and flip the wires over then clamp it down again. I didn't have any left after I was done because 2-3 of them broke.
  8. Aug 12, 2018 at 1:15 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    My hands are delicate ;)
  9. Aug 12, 2018 at 1:16 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I had to purchase 2 kits, after i screwed up all the connectors and wires for the 1st one, i trashed it and tried again.
  10. Aug 12, 2018 at 1:18 PM
    Sas
    OKC, OK
    It's honestly going to save some headache and frustration by running up to Walmart or something and buying a couple of packs of T-taps or other connector that is meant for 18-22 gauge wire.
  11. Aug 12, 2018 at 1:25 PM
    Ok- it’s all connected and working. Now, I need to run it somehow to the passenger side
  12. Aug 12, 2018 at 1:32 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I ran mine across the firewall and tucked all the wires in the center
    Sas[OP] and T-Rex266[QUOTED] like this.
  13. Aug 12, 2018 at 1:43 PM
    Sas
    OKC, OK
    If you're running them under the driver and passenger seats as well then you'll probably want to pop out the center console cover so you can run the wires easier. It's easiest to start if you open the storage lid and begin working from where the center console meets the storage box. Wedged a body trim tool as a starting point for reference.
    Here's a good video on removing it (start it 1:00 in if you have your battery disconnected, otherwise 1:30 in):
  14. Aug 12, 2018 at 1:49 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Didnt go that route either. I just tucked wires up under the plastic skirt of the center console. Its loose enough to fish wires up under but tight enough to hold the wires in.
  15. Aug 12, 2018 at 1:55 PM
    Complete. Thanks!
  16. Aug 12, 2018 at 1:57 PM
    Sas
    OKC, OK
    Right on. Mine was already off because I was already doing another mod at the same time.
  17. Aug 12, 2018 at 1:59 PM
    Sas
    OKC, OK
    Nicely done! :thumbsup:
    T-Rex266[QUOTED] likes this.
  18. Apr 20, 2019 at 5:29 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Hmmmmm. So is this kit worth $40?
  19. Apr 20, 2019 at 5:36 PM
    #49
    Sas
    OKC, OK
    If I were doing this again, I would just buy the LED's and the footwell adapter so you don't have to tap anything to get power. Then just clip the connectors they use and wire them in yourself using whatever connectors you want. I wasn't a fan of their connectors at all.
