Vision soft 8
Discussion in 'Wheels & Tires' started by Lupe, Feb 7, 2019.
  1. Feb 7, 2019 at 12:30 PM
    Lupe
    Lupe [OP] New Member
    Lupe
    2006 Tundra
    Hello fellow members
    I need some help. I brought some vision soft 8 16x8 and well after reading around i found out they might not fit due to the caliper unless running a spacer. Also if they do fit what would be the biggest tire i could run on stock height? P265/70R16 with som rubbing? Thanks in advance!!!
  2. Feb 7, 2019 at 2:54 PM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    I dont see why the calipers would cause issue, stock size is 16" and they tuck inside the wheel.
    Lupe[OP] likes this.
  3. Feb 7, 2019 at 3:13 PM
    4RunnerKid
    4RunnerKid New Member
    Oceano, CA
    '19 Cement CM SR5 4x4
    TRD Pro Bilsteins w/ single CB shim, 285/75-17 Falken AT3, Method 701, debadged, ceramic coated, Husky liners
    the caliper sticks out past the wheel mounting surface, so steel wheels do not fit because they essentially come straight out from the wheel mounting surface. hope that makes sense...
    Lupe[OP] and bmf4069 like this.
  4. Feb 7, 2019 at 3:35 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Some 16" wheels do not fit, regardless of steel or aluminum. Just depends on the shape of the inner wheel.
    If they do fit, 265/70 will work well with no rub. 265/75 is slightly bigger and may rub a bit.
  5. Feb 8, 2019 at 5:23 AM
    Lupe
    Lupe
    2006 Tundra
    hope they fit :(.
    But yeah i have been doing a lot of reading and read that some 16 in wheel will not fit. And these well they are steel.
  6. Mar 1, 2019 at 10:48 AM
    socal147
    socal147 None Specified
    Patrick
    Oak Hills Commiefornia
    2019 Tundra Tonka
    Stock is so temporary
    Did it work ?
    I like soft 8's but don't see many here. I was thinking 17's only because I have 20" wheels now. Might help with caliper clearance also.
  7. Mar 2, 2019 at 9:37 AM
    Lupe
    Lupe
    2006 Tundra
    SOLD Please delete
  8. Sep 18, 2019 at 7:37 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Has anyone had luck with fitting the Vision soft 8's over a 1st gen Tundra? I called Discount Tire today and they told me that it will not clear the caliper the way the hub sits inside the barrel, it rubs the front caliper.
  9. Sep 18, 2019 at 9:52 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    The -12 offset of the wheels in the OP may be a plus. I had the same wheels in a 17” on my Tacoma with a 0 offset. My Tacoma brakes are smaller than the Tundra’s and the caliper had maybe 1 mm clearance to the wheel. I literally felt lucky that they fit because it was all that I had money for at the time.
  10. Sep 18, 2019 at 10:35 AM
    SouthPaw
    2000 Limited 4x4 AC
    I opted to go with the Vision Turbines. They were on sale and can be installed today. I didn't want to risk them not fitting or having fitment issues.
