VIPER CUT:lower front bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by PaulROahu, Feb 7, 2023.
  1. Feb 7, 2023 at 8:07 PM
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    decided to document my VIPER CUT lower front bumper end caps to clear my 37” tires.
    During my research only found at best measurements to cut the bumper end caps. nothing really about the brackets, lower plastic inner fender, mounting points. Hope this helps the next DIY VIPER CUT mods.
    cut measurements: 2” on inner vertical cut, 1” on lower fog lamp, 6.25” on inner bend and 5.5” on outer edge bend, inner painter tape as stencil for curve. Used flat Dremel to cut plastic end cap. then sanded for easier instal of fender trim later. Did not take pics as other threads have these. I’m more focused on the other info for the DIY will need.
    cut the lower fog lamp bracket and lower metal mounting bracket with edge grinder, after looking from front, ended up cutting more to clean up view from lower front. drilled a hole on inner fog bracket to use a mounting point for zip tie later. sanded and painted.
    Lower front inner plastic fender, made cuts at bottom bend then drilled a hole on bottom inner flap for zip tie point. after test fit ended up cutting more again for cleaner front lower view. removed the outer fender mounting bracket clip to cut off center section then test fit bracket on cut fender cap. drilled hole on middle and screws together. sanded and washed
    mounting liner used factory (2) 10mm bolt on top outside mounting, push pin on frame just under coil revisor, (3) zip tie on fog lamp with previous hole drilled. NOTE: zip tie all the way forward as this clears the tires at full lock. 6 anchor points and liner doesn’t move. keeps factory look. NO HEATING, just push forward and secure. keeps fog lamp housing covered. To complete the factory look added fender trim.
    +6” straight clearance, and +5” at full lock. Note: previously did a .75” bumper spacer and BMC to clear my 35” tires….Now 37” should be no problem….except maybe gas mileage…hehe
    if interested please see my build thread:2017 Platinum 4x4 MGM build
  2. Feb 7, 2023 at 8:18 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    That’s clean work. :thumbsup:
    PaulROahu[OP] likes this.
  3. Feb 12, 2023 at 8:21 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    day time right side pics
  4. Feb 12, 2023 at 8:33 PM
    WaStateTundra
    WaStateTundra New Member
    2014 4WD 1794 Attitude Black 170k miles
    Looks awesome. Hope the trend continues!
  5. Feb 12, 2023 at 8:46 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    thanks first off want to give credit to “DEANER713” for giving us the cut measurements. i just wanted to give my experience and how to for those that are looking for a clean factory look with out the melting/bending/hacked up/removing things. I was researching for about 2 months most of which was Tacoma viper cuts.
    best i can say is measure 3x before you cut, and take your time. my project took me 2days as my first cuts were not high enough and did not like the view from the front. so next day measured, cut, drilled, re-fabricated parts from the cut pcs ie; end bracket mount clip to fit the shorter size, trimming the inner plastic mounding to follow the cut line and still keep it looking factory like.
    I hope this gives others ideas on how to tackle this project for better bigger tire clearance.
    WaStateTundra[QUOTED] likes this.
  6. Feb 14, 2023 at 8:35 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I would have done this had I not put a CBI Baja instead.
  7. Feb 14, 2023 at 12:11 PM
    Tonkatoytaco
    Tonkatoytaco New Member
    Louie
    Maryland
    2017 Platinum XP MGM
    LRO 3/1 Leveling Kit, Dirty Deeds 10" exhaust, Bully Dog Programmer, AFE Super stock Intake with TB Spacer, Custom Rough Country Grill, Andres Devil Horns, Caliraised Fog lights, Morimoto XB Headlights, HRS taillight, Boost Auto tow mirrors, LED interior lights and Reg, light, Trail edition bed compartment, TRD rear sway bar, weathertech floor mats and window visor, Nitto Ridge grappler.
    What material did you use to cover the corners after you cut it? Do you have a link to it?
  8. Feb 14, 2023 at 12:32 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Great write up! Turned out awesome!
    RobertD likes this.
  9. Feb 14, 2023 at 12:57 PM
    RobertD
    Robert
    DFW, Texas
    We want pics!
  10. Feb 14, 2023 at 1:07 PM
    Berdine
    Binghamton, NY
    The pics are there from him
  11. Feb 14, 2023 at 1:35 PM
    RobertD
    Robert
    DFW, Texas
    Oh :rofl::rofl:
    I thought you were saying you did it too!
  12. Feb 14, 2023 at 3:38 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    used fender trim from Amazon the one without the glue
    Tonkatoytaco[QUOTED] likes this.
  13. Mar 1, 2023 at 10:37 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    after driving my OCD kicked in and added (2) more zip tie point to lower plastic liner.
    drilled holes for zip tie to pass through and secured to metal fog lamp bracket, tightened only enough to prevent liner from flexing during driving and still keeping factory shape. now have (3) factory mounting points and (3) zip tie points for stability…happy with my Viper Cut DIY project. next week installing Icon UPA and Falken Wildpeaks AT3W 37”/12.5”/20”
  14. Mar 1, 2023 at 10:56 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Lets see some zoomed out pics of the whole truck. Front and side.
    AggiePhil likes this.
  15. Mar 1, 2023 at 11:01 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
  16. Mar 13, 2023 at 6:40 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Looks great! 37" tires on the Tundra do not look like 37" tires on a Jeep.... but they are a huge tire.
    Are you going to regear it? If so, what ratio would you run for 37's?
    I have 5.13 gears in my Jeep but have no idea what would be used for the Tundra.
  17. Mar 13, 2023 at 7:04 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @PaulROahu job well done :cheers:
    Should come from the factory lookin like that!
  18. Mar 13, 2023 at 8:21 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Nitro 4.88 to keep it close to factory
    chugs likes this.
  19. Mar 13, 2023 at 8:27 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @dirtydeeds can guide your hand on this. You'll want to go 5.29s on the Tundra for anything bigger than 35s.
    PaulROahu[QUOTED][OP] likes this.
  20. Mar 14, 2023 at 6:45 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    anyone know what he stock ratio is?
  21. Mar 14, 2023 at 6:50 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    4.30 if I'm not mistaken
  22. Mar 16, 2023 at 9:10 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Can you post some “normal” pics from chest height, looking at the truck from a little ways away? What I’ve found is that down low, these cuts usually look pretty good. But from eye level, they look kinda weird. Especially from the side where you can see into the area behind the bumper.
  23. Mar 16, 2023 at 9:17 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    my OCD made sure that all angles were correct, tried to keep it looking factory as possible, some people had no idea i had a viper cut due to the view from inside the fender well still looked factory, painted the bumper bar black, even looking at eye level of cuts were all clean. Even the other Tundra owners thought i bought these bumpers that way
  24. Mar 16, 2023 at 9:38 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    just took pics from chest level
    CornbreadTRd likes this.
  25. Mar 16, 2023 at 10:07 PM
    CornbreadTRd
    CornbreadTRd New Member
    PDX
    2020 Tundra Quicksand
    That's nice and clean. I like it! Literally looks factory
  26. Mar 16, 2023 at 10:11 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    thanks i’ve looked at all viper cuts and no one explained how to do a clean inner fender well DIY. went and did a total of 3 cuts till my OCD was satisfied. like a Toyota staff said he thought i bought it that way until i told him it’s DIY.
  27. Mar 17, 2023 at 10:15 AM
    AggiePhil
    College Station, TX
    Is that really just a 0.75" bumper spacer? Looks like a lot more. Also, is that what's causing the bumper to look like it's sagging in the middle and higher at the edges?
  28. Mar 17, 2023 at 1:33 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    0.5”bumper spacer and moved bolt another 0.25”. Viper fender is bolted to the factory bracket, but the bottom bolt i cut in half and remounted to fit the new fender to secure the bottom half(grid photo look at bottom right, you can see the bottom bolt relocation mount)
  29. Mar 17, 2023 at 1:41 PM
    AggiePhil
    College Station, TX
    I probably didn’t explain myself very well. Why does the lower part of the bumper look like it dips toward the middle of the truck? Kinda looks like a smiley face.
  30. Mar 17, 2023 at 6:36 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    i have a 3/4” bumper spacer that pushed it out a bit
