Victory4x4 Bedside Molle Accessory Panel! Just released, Intro pricing!
Discussion in 'Deals & Group Buys' started by brimy311, Feb 12, 2019.
Thread Status:
Not open for further replies.
  1. Feb 14, 2019 at 11:43 AM
    brimy311
    brimy311 [OP] New Member
    Kalamazoo
    2018 Tundra Platinum
    Install video posted in first post!
    TheBeast likes this.
  2. Feb 14, 2019 at 11:49 AM
    TheBeast The Beach
    but WAIT ! there is more ! :D:D
    great video
  3. Feb 15, 2019 at 3:46 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    My wallet just got a whole lot lighter. Please don't make anymore Tundra products. Thanks!
    brimy311[OP] likes this.
  4. Feb 15, 2019 at 3:48 PM
    brimy311
    Kalamazoo
  5. Feb 15, 2019 at 5:34 PM
    chickunfut
    Fort Worth, TX
    2007 Tundra Crewmax
    Yes, I ordered all three mounts for the bed and I haven’t even installed the diff skid plate that I got a couple days ago!
    Seriously though, thanks for making these parts for the Tundra. I’ve been searching for some bed mount solutions for awhile. The diff skid was just the cherry on top..
  6. Feb 16, 2019 at 10:44 AM
    brimy311
    Kalamazoo
    I updated the first post to include the front molle accessory panel.
  7. Feb 19, 2019 at 10:49 AM
    brimy311
    Kalamazoo
    Anyone else what these before the intro pricing ends?
    jgraphix73 likes this.
  8. Feb 20, 2019 at 6:45 PM
    cpatts9747
    cpatts9747 New Member
    Corey
    15 tundra sr5
    Are there any mounting options for people who don't have the bed rail system?
  9. Feb 20, 2019 at 6:57 PM
    oogabooga289
    oogabooga289 New Member
    Superstrut/Unistrut from the hardware store for a cheap deck rail alternative.
  10. Feb 22, 2019 at 6:13 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    Id love to see what people are mounting on these!
    It looks like an awesome place for a lot of things I have disorganized in my rear floor board (ratchet straps, recovery gear, bike pump, some tools, but I just don't know about all that stuff staying out in the elements. I'm a no tonneau cover kind of guy so I don't know if this is going to be my solution. Are there bags that are waterproof for this kind of thing?
  11. Feb 23, 2019 at 5:23 AM
    brimy311
    Kalamazoo
    Front accessory panel install video:
    TheBeast, jgraphix73 and Toytec Lifts like this.
  12. Feb 23, 2019 at 7:57 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Will a Hi-Lift still mount up over top if a 4G Rotopax were mounted onto this?
    Will a 2G Rotopax mount onto the side molle?
    Just trying to work through various configurations in my mind as I plan out my setup.
    Thanks @brimy311
  13. Feb 23, 2019 at 8:28 AM
    brimy311
    Kalamazoo
    1.) No it will not.
    2.) the side panel doesn’t have mounting locations for a mount. But you could probably mount one with a little enginuity.
  14. Feb 23, 2019 at 8:41 AM
    Krezz
    Kevin
    Sounds good on both fronts!
    It wasn't crucial for my idea anyhow, but just mapping out various plans.
    Thanks for the quick reply!
  15. Feb 26, 2019 at 2:17 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Job done (almost)!
    Super impressed with the quality and how solidly these mount. You can shake the truck by grabbing these, and they wont budge.
    A couple notes:
    1) as you can see I have the OEM tri fold cover. That install pushed down the rail. No real problem; just line things using the built in adjustability of these panels, and away you go. With one exception: we REALLY had to push the panels into the side as we bolted it down thru the holes drilled in the bed. I'm not sure if my rails were kicked out resulting in the panel kicking out, resulting in lots of force needed to push the panel back into the bed wall or what. But that took some doing. Found myself wishing these bolts were 1/2" longer, even after ensuring the mounting brakets were at their full extension.
    2) speaking of those mounting brackets... Brian I'm sorry if your ears were ringing because your name was mentioned a few times, surrounded by various expletives. WTF were you thinking telling people to install the bracket AFTER the panel was fit to the bed rail? :D I watched your install vid again; sure enough, there's a sneaky little cut away as you go to mount them yourself. What a PITA. On the second panel, I put the bracket on first, before putting the panel on the rail, and cut my install time down by half. I strongly suggest others ignore that particular part of the install vid and do the same :p
    3) I received two extra bolts, a random undersized flange nut, and was shorted one proper sized flange nut. No prob; need to run to the hardware store anyway. But I suggest checking your hardware before you start.
    4) Sliding the brackets into and down the rail was a little challenging. I guess the OEM bolts holding the rail on to its mounts stick out a little more than expected. Nothing a little gentle persuasion with a hammer and nylon tipped punch couldn't solve.
    5) Still got a little work to do; here's a mock up "his and hers" shot of our 'match day' setup. The Quick Fists are just ziptied on for now. Looks like this is going to work just fine.
    I'm one happy camper! Thanks Brian and Victory4x4 for coming up with this!
    PS: Shout out to @KevinK for working thru the rifle mounting thought process with me. Turned out just as we figured!
  16. Feb 26, 2019 at 2:20 PM
    TheBeast The Beach
    for when SHTF :)
    Cement likes this.
  17. Feb 26, 2019 at 2:40 PM
    Outbound
    Aaron
    Northern Alberta
    Man...you guys are turning out some awesome products. I'm almost second guessing hanging on to my 1st Gen. I could buy so many more mods if I had a 2nd or 3rd gen!!
  18. Feb 26, 2019 at 5:25 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Sure wish I had seen this video prior to my attempt at installation late today. Need to include a link to the video in the packaging. Please for the next guys that order the panels. :thumbsup:
    Like Cement, I am missing a few parts - bolts and matching nuts/washers in order to be able to complete my installation.
    Realistically, all the bolts, washers and nuts should be stainless. I have a cap on my truck, but stainless bolts, washers and nuts would be the way to go.
    Overall, this beast is SOLID. Very heavy duty and well made.
    Cement likes this.
  19. Feb 26, 2019 at 5:28 PM
    #49
    brimy311
    Kalamazoo
    Sorry for the hiccups! Thanks for being patient as we work through these wrinkles.
    Customer service can get you the bolts you need in the mail tomorrow. Just let them know what you need!
    I’m going to go check the bins, worried the inventory got mixed up with sizes.
    We don’t like to use stainless because they cross thread easy nd chew up the threads. At that point, you have to cut the bolts to get them appart. Then there is an issue with stainless causing stains on the powder coat. We’ve had great luck with the zinc coated bolts in this application.
  20. Feb 26, 2019 at 5:34 PM
    #50
    tundracap
    NC
    Hey Brian, no worries man. We're just glad you are able to take on new projects like this that people want to mod their trucks with in such a short time. Great customer service and very quick response from you as always.
    TheBeast, Cement and brimy311[OP] like this.
  21. Feb 26, 2019 at 5:35 PM
    #51
    Cement
    Cement ...
    True that. All good here. Appreciate it Brian.
  22. Feb 26, 2019 at 6:01 PM
    #52
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Sweet. I want two. And the one in front of my kid's car seat. And the sliders.
    Nice option for the windoors.
    Cement[QUOTED] and brimy311[OP] like this.
  23. Feb 26, 2019 at 8:59 PM
    #53
    ITOWJKS
    ITOWJKS New Member
    2018 Tundra Limited Cavalry Blue
    I love those bedside molle accessory panels but I had to remove the bedside rails in order to install a Leitner Designs Active Cargo System, which would also interfere with the bed stiffener. On the other hand, the front molle accessory panel is in my list of "future" upgrades, too bad a missed the "intro" price!
    How about an ARB twin compressor mount (preferably under the hood)???
  24. Feb 27, 2019 at 9:53 AM
    #54
    jgraphix73
    jgraphix73 New Member
    Richard
    2010 Tundra Crewmax
    I do...but let me check my bed as I have a bed rug now. I just want to make sure I can get access or if I need to cut holes in them.
    Also, what LED lights are you using for the bed in the front panel demo video?
  25. Feb 27, 2019 at 10:16 AM
    #55
    Outbound
    Aaron
    Northern Alberta
    A little tip for those that do want to use stainless, dab a little bit of grease on the threads before spinning them in. It helps prevent the cross threading issue. I went through that headache when mounting stuff on my boat. The grease worked like a charm.
  26. Feb 27, 2019 at 10:34 AM
    #56
    brimy311
    Kalamazoo
    I have one last panel in stock from the first batch. You shouldn't have to cut the bed rug, assuming it's just on the floor of the bed? I have a bed mat, so that is about the same thickness.
    They are @mattgecko lights.
    jgraphix73[QUOTED] likes this.
  27. Feb 27, 2019 at 12:16 PM
    #57
    ITOWJKS
    ITOWJKS New Member
    Is the front molle still applies for the intro pricing?
  28. Feb 27, 2019 at 12:18 PM
    #58
    brimy311
    Kalamazoo
    It's technically over, but if you call in to Shiloh and ask her nice I'm sure she could extended it to you. 269-353-1184 ext 20
  29. Feb 28, 2019 at 4:29 AM
    #59
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Did some arranging last night
    escuzi_me, Cement and brimy311[OP] like this.
  30. Mar 1, 2019 at 11:15 AM
    #60
    tundracap
    NC
    Finally got to complete installation of the drivers' side panel.
    I have a lot going on in my truck bed. Cap, Bedslide, gear I can't live without (in my mind).
    Moved the fire extinguisher to the other side after these photos as I have gear to mount where it is in the pix here.
    Need to get additional MOLLE pouches for stuff.
    The only significant thing I would change about the panels themselves would be to have the small narrow sections over the wheel wells MOLLE as well. It wouldn't eliminate the ability to store a hi-lift jack there is needed, and would increase the usability of the panels storage capacity, at least for me.
    And whatever you do when mounting, follow @Cement's comment and mount the lower brackets BEFORE you mount the panels. Leave the forward bolts loose enough yo can push them in or out as needed. I had to push the forward end out to get it flush with the sidewall in order to be able to use the provided short hex bolt.
    For tightening the nut outside the bed, I just clamped a vice grip to my allen wrench so the bolt wouldn't spin.
    I still say all the bolts, nuts, and washers should be stainless. I would have preferred the nuts be nylock nuts. The bolt ends end up sticking out into the bed are going to draw blood and cussing before it's over. Unfortunately for me, the bolts for mounting the panels to the rails are 1.25" long and my local Lowe's only had 1.5" carriage bolts in stock, so the 4 additional ones I had to buy stick out even farther. I used closest to the cab in hopes of less change of damaging me or cargo later.
    Overall, I have been wanting something like this for a good while, and this is a very heavy duty, well made panel set.
    Good stuff Brian. Thanks for following up on the MOLLE panel suggestion.
    escuzi_me and Cement like this.
Thread Status:
