Vibration while pressing on gas
Discussion in '2nd Gen Tundras (2007-2013)' started by spetznaz, Feb 17, 2020.
  1. Feb 17, 2020 at 5:11 PM
    spetznaz
    spetznaz [OP] New Member
    Hi all
    I'm getting a rumbling vibration all throughout the cab while pressing on gas only. As soon as I let off gas the vibration goes away after about a second or less. Also above 65mph vibration goes away.
    This is in 2wd and does not seem to depend on rpm. Only speed...
    Also I've been hearing a squeak when starting from a stop. Sounds like metal on metal rubbing on a rotating part (like the sound it would make if something touching the rotor) soon as I hit about 10-15mph it goes away. I've checked there is nothing visibly rubbing or near any rotating parts
    2007 sr5 with 237k
    Any thoughts?
  2. Feb 17, 2020 at 6:01 PM
    Ricardowelch
    Ricardowelch New Member
    Welch
    Have you tried to check the carrier bearing? It could be a worn out.
  3. Feb 17, 2020 at 6:10 PM
    spetznaz
    Yes was thinking that too have not checked it. I was also thinking yoke assembly on the driveshaft is that a possibility?
    Would the carrier bearing feel loose? Or how would this be checked
  4. Feb 18, 2020 at 9:11 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    How old are your tires? There was a similar thread elsewhere and the culprit was a tire balance issue.
  5. Feb 18, 2020 at 9:15 AM
    spetznaz
    Tires are new...
    Checked the bearing last night and it's totally shot...
    So there we go :)
    bleach likes this.
