Vibration when braking
Discussion in '2nd Gen Tundras (2007-2013)' started by jtx0741, Mar 5, 2020.
  1. Mar 5, 2020 at 7:22 AM
    jtx0741
    jtx0741 [OP] New Member
    2013 Tundra
    I have a 2013 tundra crewmax texas edition with 172k miles on it.
    lately it started shaking while braking at highway speeds. while driving approximately 80 if I apply the brakes, it will usually shake between 65-50 mph. then it's gone or significantly minimized to where it ain't noticed. the best way I can describe it is a bouncing on the brake and some shaking on the steering wheel. I've read that bad rotors are the #1 cause and replaced the front rotors and pads. still shaking.
    not being a truck guy I was talking to co workers about it. it feels as though the shakes originate from the passenger front side. I noticed while doing the change that the shock was leaking.
    can that be a cause for the vibration? they told me it could cause it, along with bad ball joints.
    any thoughts on what could cause this? everything (except the rotors and pads) is stock.
    also I just recently replaced my tires, and have got them balanced and an alignment. below is a pic of the passenger side.
    thanks in advance for any input.
  2. Mar 5, 2020 at 7:32 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I would first have the tire balance checked, preferably at front end specialty shop different from the tire store. Just because you had your new tires balanced and aligned does not mean that it was done properly.
    The leaking shock is not the cause of the problem, but any force unbalance causing vibration is probably not being damped as much as it could be. Shocks are not intended to damp wheel unbalance.
    Chris Fix on checking and replacing your ball joints:
    https://www.youtube.com/watch?v=62bVn7E8gyk
  3. Mar 5, 2020 at 7:40 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    check tire balance first, that is cheap. Id replace both front shocks since it is leaking (replace them in pairs or all of them on truck), then have ballpoints checked.
  4. Mar 5, 2020 at 8:13 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    172,000 miles...
    yea you have some worn out parts..
    jack up front end, secure truck with stands... shake wheels....
    look close at suspension parts... look at rack n pinion. there are mount bushing that wear....
  5. Mar 5, 2020 at 8:46 AM
    jtx0741
    2013 Tundra
    I had it checked at a Firestone Complete auto care. not sure of the reliability, but they have been doing them for over a yr with no problems up until recently.
    wouldnt the unbalanced wheels cause the truck to shake while driving all the time?
    I ordered the 2 strut assemblies to replace them as a pair.
    I'll try jacking up the truck and shaking it. would I be able to see a specific point on the rack and pinion where the bushing would be? should there be any play in them?
