Vibration when accelerating
Discussion in '2nd Gen Tundras (2007-2013)' started by AZ wheeler, Apr 14, 2024.
  1. Apr 14, 2024 at 9:26 PM
    AZ wheeler
    AZ wheeler [OP] New Member
    Eddie
    Glendale, AZ
    2008 Tundra Crew Max 4X4, 2003 Toyota Tundra AC SR5 4X4
    Icon 1-3" STAGE 3 SUSPENSION SYSTEM, Icon TUBULAR UCA DJ KIT, Icon Rebound 17x8.5, Falken - Wildpeak AT3 285.75.17,
    I have an 08 crewmax, when accelerating I have a vibration. Would this be the cause?
  2. Apr 18, 2024 at 6:46 PM
    LaMobyDick
    LaMobyDick New Member
    2009 Crew Cab 5.7
    So far, new stereo, nerf bars, removed the plastic bedliner from hell and used Herculiner instead, replaced the rear bumper with a tougher one, and also replaced all the lights for LED. Besides rescuing this truck from a pothead up north I'm not planning on going full monster, just to update a bit what the guys at Toyota masterfully created.
    Causes can vary, but if your truck is lifted more than 2.5 inches, there's a chance the angle of the draft shaft changed up to a point that it induces vibration over certain speeds.
  3. Apr 18, 2024 at 6:58 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Serious question, or sarcasm? Because the answer would be “Absolutely yes” or “Nah, it’s fine”, respectively. :)
    Greasing a wee bit more often would certainly increase the u-joint life.;)
  4. Apr 19, 2024 at 8:53 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you lifted the rear at all, even an inch, it may need a carrier bearing drop installed. Tundras are finicky when lifting the rear, some trucks need the drop kit, others dont.
    Lube your driveline zerks.
    Do the above first and if you still have an issue report back.
  5. Apr 19, 2024 at 2:13 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That U-joint is completely shot. If the others have seen the same amount of grease, they’re likely not too far off of that. Zero point to greasing the pictured u-joint unless it’s more fun to replace when it’s all greasy.
