Vibration under braking
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, Jul 7, 2020.
  1. Jul 7, 2020 at 5:16 AM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    2002 : Vibration while braking, not always there though. It certainly is more noticeable after the brakes are worked over a bunch.
    Classic warped rotor? If so, will this kit be a good replacement:
    https://www.amazon.com/2000-TOYOTA-TUNDRA-Rotors-Replacement/dp/B009YM21GG
    BTW: my calipers are stamped 13WL, hence this kit over the 13we.
    Also, easy enough for a shade tree mechanic? I seem to remember doing this on a pathfinder years ago and it was quite straight forward.
  2. Jul 7, 2020 at 6:44 AM
    Professional Hand Model
    Hand Protectors
    Very straight forward. Might as well clean everything up and spray paint all the paintable components while in there. Wire brush, rusty primer, and some GLOSS black will do it nicely. Make sure to buy some Sil-Glyde and grease all your slide pins and the backs of brake pads. Use Anti-Seize on your metal to metal mating surfaces like rotor to axle and wheel to rotor.
    Never knew about the Pin/Pad Greasing until research. Makes and big difference in action of the brakes as well as sound reduction. My rear drums were squealing in harmony in reverse mode and a little grease quieted them.
  3. Jul 7, 2020 at 9:09 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Where did you grease the rear drums? My do the exact same thing, reverse only.
    So I am not hijacking, it is a pretty straight forward job. I prefer to by my brake parts local so if they are wrong, it is easy to swap. Nothing like having a truck down for a few days waiting for online parts. Pickup a bottle of CRC Brake quiet, two cans of brake clean, rags, pads/rotors. I know some people will only replace one or the other but as cheap as they are, I always replace the pads/rotors together.
    robabeatle[OP] likes this.
  4. Jul 7, 2020 at 9:15 AM
    Hand Protectors
    I’ll try pulling the FSM later, but here is a basic shot. The red dots are greased behind the shoe backing.
    jpink and SouthPaw[QUOTED] like this.
  5. Jul 7, 2020 at 9:19 AM
    SouthPaw
    2000 Limited 4x4 AC
    Thank you.
    I think as cheap as they are, I will probably just replace everything so I don't have to worry about it again.
  6. Jul 7, 2020 at 9:40 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I find it so fascinating how close the pads sit to the rotors when not in action
  7. Jul 7, 2020 at 4:14 PM
    Hand Protectors
    It freaked me out too, until I became internet expert.
    Darkness likes this.
