Vibration Issue
Discussion in '1st Gen Tundras (2000-2006)' started by histonskier, Jun 12, 2022.
  1. Jun 18, 2022 at 10:28 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Yeah, from the description I wouldn’t initially suspect suspension or wheels/tires either, but if the driveline is checking out that’s the next stuff I’d look at next.
  2. Jun 18, 2022 at 10:42 AM
    Aerindel
    Aerindel New Member
    Montana
    I'd check CV axles next, but yeah, this is kinda a weird one.
  3. Jun 18, 2022 at 11:36 AM
    histonskier
    histonskier [OP] New Member
    Montana
    Ya i dont think it could be tires or suspension since it shakes when I Jack it up and put it in drive. Would a problem with the rear diff or transfer case make sense?
  4. Jun 18, 2022 at 2:16 PM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    did you spin the tires by hand while in the air, front and back to feel for binding?
  5. Jul 17, 2022 at 9:17 PM
    histonskier
    Montana
    Hey sorry for not updating sooner. I was out of town for a while and finally figured out the issue the other week after I took it to a shop. I had a misfire in one of the cylinders. It felt different from my friends truck who had the same issue and It wasn't throwing a check engine light for some reason so I didn't expect it. Thanks for the responses. Now I gotta fix the crack I put near the drain plug of my transfer case. Tried JB Weld but it didn't hold. Gonna grind it down and redo it maybe. Really don't want to have to replace the whole case.
    jake22si likes this.
