vibration/hopping during braking.
Discussion in '1st Gen Tundras (2000-2006)' started by angrygopher, Mar 27, 2021.
  1. Mar 27, 2021 at 9:05 PM
    angrygopher
    angrygopher [OP] New Member
    2005 Tundra
    Greetings!
    New user here. Have an issue with my 05 access cab 4WD and looking for some advice. Its intermittent, but i'm getting a strange bouncing when under moderate to heavy braking. At first I thought it was warped rotors, but I've changed the front rotors TWICE. I thought I may have gotten a bad set, but the vibration is still there with the 2nd set.
    Also had the rear drums turned and serviced, thinking it may have been coming from the rear, but that didn't make a difference either. I can hit the e-brake at 50+ mph and the truck slows smooth as glass. Therein lies the first strange symptom: Using the emergency brake is always smooth, but regular braking causes the pulsing.
    The other strange thing is it isn't consistent. I can hit the pedal on the highway and sometimes she'll slow down like shes a brand new truck. Other times I'll hit them and the truck will go into a bouncing fit, hopping up and down. Its not in the steering wheel, either; its the whole front end. It almost feels like death wobble.
    I don't regularly tow anything, and it doesn't matter how long i've been driving or how hard I've been braking beforehand. It can be the first stop at a red light in the morning, or the last in the line of a dozen stops when the brakes are good and hot. Sometimes its there and sometimes its not, sometimes its really there, and has me almost hitting my head off the roof.
    Only other symptom I notice is there has been a weird, low "rumbling" noise coming from under the cab since this started happening. Its very faint, but its noticeable while cruising. Carrier bearing looks good, all the joints are greased, slip joint moves back and forth nicely, there's nothing to indicate any axle issues, but.. I don't know. I thought maybe it was a wheel bearing and took it to a mechanic buddy to look at, but after a quick ride and came back scratching his head. Said bearing play wouldn't cause bouncing like that. He's stumped, and I'm a little concerned.
    Thoughts?
  2. Mar 27, 2021 at 9:14 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Any of the calipers hanging up? I’d also check all your bushings on the front end (sway bars, control arms, etc).
  3. Mar 27, 2021 at 9:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i have a similar issue, but mine is consistent at 40 mph hitting the brakes.. doing the ECGS needle bearing after seeing how much my axle flops around on the driver side. just havent had time to do it recently
    i've done new brakes, carrier bearing, ETC.
    SouthPaw likes this.
  4. Mar 27, 2021 at 10:50 PM
    Nick T
    Nick T New Member
    Nick
    Check your control arm bushings, ball joints, tie rod ends.
    Sounds like "sometimes" when you brake, the arms are set and do not bounce, other times the arms are bouncing around because of the torn bushings and or the rack has loose tie rod ends causing the whole truck to vibrate.
    My guess is tie rod ends.
    MT Madman likes this.
  5. Mar 28, 2021 at 3:04 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Also when was your last alignment?
  6. Mar 28, 2021 at 6:28 AM
    Concur with the others on worn suspension components. I would go through the front end bushings and ball joints. Also check the U-joints in the driveline. When was the last time the brakes were bled and adjusted? If the rears aren't engaging the fronts are doing all the stopping.
  7. Mar 28, 2021 at 7:09 AM
    Professional Hand Model
    Hand Protectors
    Miles on vehicle? History of suspension work or original?
  8. Mar 28, 2021 at 7:52 AM
    angrygopher
    2005 Tundra
    I'm at 137K. Last alignment was last spring when I put new tires on and replaced the factory struts at 120k. (I went with stock bilsteins) Was inspected in the early fall by a dealer, who actually commented how clean the truck was underneath. Neither they, nor my mechanic mentioned anything looked worn, but I'm going to take it back and throw in on his lift and check the front arms and tie rods this week. Would a worn bushing cause the rumbling, though?? That's what's throwing me off.
  9. Mar 28, 2021 at 7:58 AM
    Hand Protectors
    Unsure. Mine didn’t rumble with a tired front.
    Calipers could seize/unseize. Check by Hand for overheating on the Caliper during this condition to rule it out.
    My 13WE Calipers had a couple seized pistons in the unbraked position. Discovered this during new Calipers install upgrade to 13WL.
  10. Mar 28, 2021 at 8:18 AM
    empty_lord
    05 rollover special
    Worn bushings definitely could, but that tends to be consistent
