Vibration between 25mph - 35mph
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Nov 13, 2020.
  1. Nov 13, 2020 at 12:34 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Hi all, need your input. I've had a shaking from the rear for a while now and can't seem to locate the issue.
    It's most noticeable when I'm accelerating quickly. it's strongest right at 25mph and slowly goes away till I hit 35mph and is completely gone. It'll stop if I take my foot off the gas pedal. If I punch it after 35mph I don't have this vibration. Not as noticeable going down hill but I'm guessing cause I don't need to give it as much gas as going up hill.
    *Asked a driveshaft shop and they said an out of balance driveshaft wouldn't cause a vibration at such a low speed and if my u joints were bad I'd feel it at higher speeds as well.
    *I changed my tires and balanced so I'm writing off tire balance. *I removed my rear sway bar just to check and still shaking. *Checked engine and transmission mounts and they are good.
    Sounds like grinding gears... GRRRRRRRRR when I punch it/when it vibrates. Gets noticeably louder in the cab during vibration. Not a death wobble but something isn't right and it's driving me crazy!
    Before I move on to my next theory of it being my slip yoke, would like your opinions on this. Anyone had an issues like this before?
    Thanks!
  2. Nov 13, 2020 at 12:48 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    do you have a lift kit? if so, how much?
  3. Nov 13, 2020 at 12:57 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Yes, 2" in front about 1" in rear. Thought about lowering the center bearing but it's not much of a lift to cause issues I would think.
  4. Nov 13, 2020 at 1:46 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    wheel bearing?
    Voss[QUOTED][OP] likes this.
  5. Nov 13, 2020 at 2:08 PM
    Professional Hand Model
    Hand Protectors
    You just did your new lift, right?
    Was this happening prior?
  6. Nov 13, 2020 at 2:36 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks I'll look into it
    Quick google search... and I may be wrong but the vibration and sound go away if I take my foot off the gas pedal. From what I read the wheel bearing would still make the grinding sound even when not accelerating.
  7. Nov 13, 2020 at 2:37 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Yes it was there before the new suspension as well...
  8. Nov 13, 2020 at 6:39 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Rear end / third member issues? LSD? Had a Blazer with LSD that would shudder if the fluid wasn't changed regularly. The friction modifiers needed refreshing every 15k. Also bearings in there and gears that could be out of whack.
    Voss[OP] likes this.
  9. Nov 13, 2020 at 7:54 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Not sure what a third member is, will need to look into it but I don’t have LSD. Wish I did lol.
    How would someone check if gears are out of wack?
  10. Nov 14, 2020 at 6:26 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I just went through this exercise (tires/balancing, carrier bearing, u-joints, drive shaft balance, etc.), and finally took it to the local shop where they identified the problem as the right front wheel bearing. And indeed it was!
    Stuck in the '00s and Voss[OP] like this.
  11. Nov 14, 2020 at 7:05 AM
    Voss
    Valod
    2003 AC TRD 4x4
    DUDE!!!! My front wheel bearing had rust in the area where the axel connects to it. Only area with rust. Someone in another thread mentioned my bearing could be bad.
    Where were you feeling the vibration?
  12. Nov 14, 2020 at 7:17 AM
    Hand Protectors
    I remember you asking about that rust on the splines. Could be you are on the something. Might have to tear her back down again. :annoyed:
  13. Nov 14, 2020 at 7:20 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Lol. Honestly Ill GLADLY take it apart again if it leads to getting rid of this vibration. Same side I had to take apart cause I missed the axel washer too. 3rd times the charm hopefully.
  14. Nov 16, 2020 at 7:05 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I’ll be replacing the bearings and hubs on both sides. Also rebuilding the driver axel as advised by a friend who’s a mechanic. I brought up the vibration to him and he said a sure indication of a bad bearing would be fine rust particles and when there are fine rust particles it usually means the housing is messed up too, “50/50”. I hadn’t even mentioned the rust to him. Well hopefully I’ll have a smooth ride soon enough.
  15. Dec 5, 2020 at 5:27 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Changed the bearings, hubs and everything else. Seems like not many places are willing to press the old bearings out. In the end the virbaration is gone but still feel a little something from the rear. I almost feel like my mind is playing tricks on me but it gets louder in the cab right around 25mph and seems like it’s coming from rear.
  16. Dec 5, 2020 at 5:36 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Have you drained and filled the rear diff and transfer case?
  17. Dec 5, 2020 at 6:11 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Just did the rear diff last week and transfer case was done about a year ago.
  18. Dec 12, 2020 at 11:32 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Greased all 9 zerk fittings on both front and rear driveshaft and the vibration is almost completely gone.
    Gmillz85, Pucks18, Lil Steve and 3 others like this.
  19. Dec 16, 2020 at 4:31 AM
    w666
    Maryland
    This suggests that one or more u-joints are bad. The grease temporarily compensated for some of the slop in the joint, masking the problem. Soon the grease will spin out and the problem will return
    Voss[QUOTED][OP] and N84434 like this.
  20. Dec 16, 2020 at 5:11 AM
    Voss
    Valod
    2003 AC TRD 4x4
    My thought as well
  21. Dec 16, 2020 at 12:32 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I went to the driveshaft shop today to have them check my Ujoints. Turns out I have some work to do tonight. My mechanic who I had take the slip yoke out to clean and re-grease about a year ago didn't put the yoke back in the correct spot. The driveshaft shop had placed arrows on the driveshaft when they balanced it and the yoke to driveshaft arrows are nowhere near each other. I've been driving around with an out of balance driveshaft. Hopefully this is the cause of the vibration.
    Schcoman, w666, GIN•OKUMA and 3 others like this.
  22. Dec 16, 2020 at 12:47 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That would do it...
  23. Dec 16, 2020 at 1:00 PM
    rock climber
    Sucks, but at least you know what's wrong now.
  24. Dec 16, 2020 at 2:07 PM
    Hand Protectors
    Another Goofy Mechanic Blunder story. :annoyed:
  25. Dec 16, 2020 at 4:06 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Tundra2 and Voss[QUOTED][OP] like this.
  26. Dec 16, 2020 at 6:34 PM
    Voss
    Valod
    2003 AC TRD 4x4
    DFF9F457-468F-4927-9AF0-54272C6DF928.jpg My slip yoke... think there needs to be some grease in here.
    Anyone know how much I need to torque tHe drive shaft bolts?
  27. Dec 16, 2020 at 7:12 PM
    Voss
    Valod
    2003 AC TRD 4x4
    So besides my slip yoke having a hole in its rear where grease spills out, the driveshaft doesn’t line up with the differential connection when aligned correctly.
    mechanic must’ve allowed the wheels to rotate when they took off the driveshaft.
  28. Dec 16, 2020 at 7:43 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Arrows aligned, no more vibration! I feel like I just got laid.
  29. Dec 17, 2020 at 4:57 AM
    Hand Protectors
  30. Dec 17, 2020 at 6:36 AM
    w666
    Maryland
    There ought to be a way to charge mechanics with malpractice...
    abcinv and Voss[QUOTED][OP] like this.
