VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Feb 18, 2020 at 5:41 AM
    #2731
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    I appreciate it. However, I have an 07 non-flex fuel, so I'm wondering how thats possible. Also, I got a few interesting codes on my ECU after scanning with techstream, P2714 and P0894. Be curious to hear your thoughts around it. If my "throttle issue" is actually trans problems.
    I'm going to check fluids after I'm done basically rebuilding half of my truck.
    Thanks for the update
  2. Feb 18, 2020 at 6:06 AM
    #2732
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Damnit. Thanks. I'll hit him up on zendesk about this.
    osidepunker[QUOTED] likes this.
  3. Feb 18, 2020 at 6:13 AM
    #2733
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    @OVTune can I get that tune with gear lock and the options I already have just with the headers portion, with a higher RPM for my ecu thanks
  4. Feb 18, 2020 at 6:25 AM
    #2734
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I am sending out a ton of Tundra updates today. If you need something, reply to your original ticket / open ticket so I will see it and update it today
  5. Feb 18, 2020 at 10:18 AM
    #2735
    Chicko2020sx
    Chicko2020sx New Member
    Michael
    2020 Tundra SX
    Led headlights, Led fog lights, tonneau cover, ventvisors.
    I have a ovtune kit from my tacoma that I recently sold. I now have a 2020 tundra. What would a license for the tundra cost.
    shellshock likes this.
  6. Feb 18, 2020 at 10:58 AM
    #2736
    ZPMAN
    Minnesota
    Mat is back, put away the pitchforks!
  7. Feb 18, 2020 at 11:29 AM
    #2737
    NWATundra
    NWATundra New Member
    2013 White Tundra DC
    Just a heads up for the re-geared folks around here, I asked Mat about a 5.29 specific tune and he sent me one today. He said the gear ratio has been corrected in the ECU and it was set up for my gears and tires. He said it should help big time with my shifting. I’ll find out tomorrow when I can flash it. Thought some may want to know it is an option now.
  8. Feb 18, 2020 at 11:30 AM
    #2738
    coTony
    Tony
    Montrose, CO
    I just got my tune this morning also, will be updating here in a few hours
    AZTundra likes this.
  9. Feb 18, 2020 at 11:31 AM
    #2739
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yep! please let me know how it goes.
    Thank the Tacoma guys for doing all the back end testing on that. It helped us find and figure out how to recalibrate tire size and gear size in the ECU
  10. Feb 18, 2020 at 11:34 AM
    #2740
    coTony
    Tony
    Montrose, CO
    The gear and tire size is changed in the ECU? Not knowing how that works, I assume the speedometer is not effected by the ECU re-calibration. I have a Speedometer Recalibration Module on the truck is why I am inquiring
  11. Feb 18, 2020 at 11:34 AM
    #2741
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Does this only apply to 5.29 gears, or are there specific adjustments for 4.88 also?
    osidepunker likes this.
  12. Feb 18, 2020 at 11:35 AM
    #2742
    NWATundra
    I would bet there is a 4.88 option also, the Tacoma has a multitude of options for tire and gear size
  13. Feb 18, 2020 at 11:45 AM
    #2743
    Midway
    Midway New Member
    This is good to know. I have 4.88s, with 35s, and was doing a few WOT pulls yesterday, and on the last pull, the throttle seemed to cut out around the 80mph mark. I sent Mat my logs to Interpret. I could be completely mistaken, could be nothing.
    Does anyone know what our speed limiter is pre set to?
  14. Feb 18, 2020 at 12:08 PM
    #2744
    coTony
    Tony
    Montrose, CO
    The 80 mph was around the speed I was at when the throttle was cut on mine and then it would not shift out of the lower gear it was in for quite a while. I am 5.29 on 35's
  15. Feb 18, 2020 at 1:51 PM
    #2745
    coTony
    Tony
    Montrose, CO
    Can someone please point me to the information on how to use the new flash program? A dialog comes up with a bunch of choices but nothing for Tundra. I just got my file I have been dying to install and do not want to screw anything up. I never had to select all this information before. I wen to the first page and did not see anything in the first comment then went to the blog using the link on the first page. Thanks in advance
  16. Feb 18, 2020 at 2:05 PM
    #2746
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Are you in the flash MANAGER, or the flash TOOL? I was sent flash TOOL 1.3.1 last week. I don't think the manager is used to flash. It was confusing because the flash tool didn't have the logging program with it...I had to locate that with the flash manager 1.3.0 download.
  17. Feb 18, 2020 at 2:09 PM
    #2747
    UTTundra
    UTTundra New Member
    Lou
    Utah
  18. Feb 18, 2020 at 2:10 PM
    #2748
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Order 5199
    Hi Mathew,
    Still waiting on my base tune for 750 cc injectors and 7000 RPM redline, I have sent you the calibration ID 2 weeks ago but have not heard back.
    Emailed 3 times by now.
    Wondering if you can tune for the new USA TRD calibration ID of 3YWF4800 that I am able to load instead of the Canadian ID of 3YWF8900
    Also, I noticed that my MAF gets maxed out at 512 g/sec at high RPM.
    Are your MAF tables expanded beyond that or do I need to install a bigger intake pipe?
    Thanks
    Viktor
  19. Feb 18, 2020 at 2:24 PM
    #2749
    coTony
    Tony
    Montrose, CO
    WHAT??? I have the 1.3.0 Flash Manager that Matt sent me and I was told to use that. I did click on Update and it did nothing. I went to the old Flash Manager instruction page and it is for the older one. I dug all over and found instructions for 1.3.0 Flash Manager and used it. It told me it was successful so I assume it is loaded.
    Wen you only touch the software once every 2-3 months it is not something I remember easily plus this is the first time I launched the Flash Manager, i only used the logger with the new software. I had to wait for the updated file for 5.29 to continue so the 1.3.1 version you have is new to me
  20. Feb 18, 2020 at 2:27 PM
    #2750
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    :ohsnap: I wondered if you would partake in the OV tune
    ViktorG[QUOTED] likes this.
  21. Feb 18, 2020 at 3:12 PM
    #2751
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    @OVTune wondering if you’re done sending out tunes for the day? As I still haven’t received a base revision tune. Been waiting a while. #5512
    Thanks
  22. Feb 18, 2020 at 3:41 PM
    #2752
    Tundra_power
    Tundra_power New Member
    Nick
    Yes stock fuel curve for long tubes are 12.5 with traction control off. Probably higher with traction control on because it pulls fuel when you rip the tires or lose traction. To me i rather have a little rich afr and alot more igntion. And when your normally driving afr stays at 14.7 till 4000rpms and than it goes rich. Bullydog and maybe ov tune only tuners that change afr and igntion timing. When dap says you can either run 87 or 93 thats sucks because its not tune for a specific octane there for no igntion timing. Only throttle response and torque management is gone. When i put on premium or trail tune for bullydog you have to run 93 if not it will ping like crazy because the tune wants to see the 91 plus octane. Toyota really made no room for improvements besides what i just mention. Maybe 15 to 20 max and that leaning out the afr to like 13.5 running 93. Each can tune out their will be identical in terms of power torque might vary but with all the research iv done i say go with ov tune or bullydog. I run bullydog i got it for 340 to my door and i have it set on trail tune running 93 afr is 12 thats with intake, exhaust and headers. If your willing to pay the big bucks than go with ov tune either way both will be great.
  23. Feb 18, 2020 at 3:55 PM
    #2753
    spm58
    spm58 New Member
    Anyone try and flash their truck and get a message saying "there was a problem preparing the selected file. Probably it's corrupted or has unsupported format"
  24. Feb 19, 2020 at 5:44 AM
    #2754
    coTony
    Tony
    Montrose, CO
    How was your fix for the gearing issue? Interested to hear
  25. Feb 19, 2020 at 6:01 AM
    #2755
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    sending more today and throughout the week
    Working on obtaining this file. if you have the CUW for it that would be super helpful
  26. Feb 19, 2020 at 6:17 AM
    #2756
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    @OVTune any chance you saw the comment i made about the two trans codes im getting, and wondering if its related to the "throttle issue" P0894 and P2714 . did some research and there was a TSB from toyota saying that the p2714 might be caused by a ecu/tcu issue and a reflash was required.
    It could be tune related. But wanted to bring it to your attention. I could have a bad shift selenoid and just be low on fluid causing slipping, which i will check and address. But wanted to discuss with you.
  27. Feb 19, 2020 at 6:18 AM
    #2757
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  28. Feb 19, 2020 at 6:23 AM
    #2758
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have you tried deleting and redownloading it? Your antivirus may be messing with the download as well.
  29. Feb 19, 2020 at 6:34 AM
    #2759
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    We shall be watching....
    TruckyTruck, mzim and shellshock like this.
  30. Feb 19, 2020 at 7:25 AM
    #2760
    NWATundra
    Just got it flashed and my shifting was way smoother. The ecu is reading a much more accurate speed than before. I haven’t done any hard pulls or high speed yet. It didn’t affect my Speedo, it is still reading dead on with the hypertech.
Thread Status:
